  • machinedude
  • machinedude's Avatar
14 Aug 2025 15:49
Replied by machinedude on topic QTPYVCP+VISMACH+LINUXCNC ROLLED INTO ONE?
Category: QtPyVCP
this has already been implemented in qtpyvcp and does not require vismach. the model can be setup to be shown and run in main vtk ui backplotter natively and respond to gcode and subroutines etc. and is quite easy to setup.
if i would have know this last week when i was about ready to smash the pc because it fought me so much i would have been all over this in a heart beat :) i probably should have posted something before i started this to see what other have done :)
  • rodw
  • rodw's Avatar
14 Aug 2025 15:49
Replied by rodw on topic Search for Google document from rodw
Sorry, please try again, Yes, I had limited to .AU Sorry about that,
middle of the night here,,,,
  • mariomatix@yahoo.de
14 Aug 2025 15:47
Replied by mariomatix@yahoo.de on topic best practice Benutzervariablen anzeigen und speichern
Category: Deutsch
Über Debug kann man sich das im Fenster vorne ausgeben lassen. Z. B. #1234 = 12 + 32 ( debug, #1234 )
es gibt auch noch msg, und print, jenachdem ob es im terminal stehen soll oder vorne erscheinen soll
  • PCW
  • PCW's Avatar
14 Aug 2025 15:30 - 14 Aug 2025 22:02
Replied by PCW on topic Axyz retrofit - spindle wiring 7i96
Category: CNC Machines
Is the a 7I96 or 7I96S?
If 7i96S you should be able to use the 7I96S analog output
connected to the VFDs +5V output, CM, and VIN1
VFD   7I96S
REF   SPINDLE+
VIN1   SPINOUT
CM      SPINDLE-
Then you would use 2 isolated outputs to drive the VFDs FWD and REV pins, something like:
V+  --> OUT0+
OUT0- --> FWD
V+  --> OUT1+
OUT1- --> REV
  • machinedude
14 Aug 2025 15:13
Category: QtPyVCP
i have everything opening fine i just don't have the hal complexity for everything i want to have so it just a matter of building that out and using the qtpyvcp ui to wire it all together in the digital sense. this is basically a project that started out as me thinking it would happen quickly and then turned into a major project for me. now i got so much time in it i just have to keep going with it to see what happens :) i think i got past the really hard part so now i can start adding stuff to a bare bones setup test and if nothing crashed add some more stuff. i keep making progress with it it's just slow moving because i never did anything like this before. on the up side of the set backs i have not spent any money on real stuff lately so that ended up being a plus for me in that sense :)
  • MennilTossFlykune
  • MennilTossFlykune
14 Aug 2025 15:01
Replied by MennilTossFlykune on topic Search for Google document from rodw
Just enter a random made-up Australian address and you will get the option of "Standard delivery - Free"
  • Lcvette
  • Lcvette's Avatar
14 Aug 2025 15:00
Replied by Lcvette on topic QTPYVCP+VISMACH+LINUXCNC ROLLED INTO ONE?
Category: QtPyVCP
some examples below of things already done. to setup once you have your stl/step file components, to do this follow the below steps:
step 1: add new folder to your machine config directory, name is "machine"
step 2: add your stl or step files to the "machine" folder
step 3: create a yaml file, can use the below example as a template, to set the base component and orient and configure each component relation in space, and assign an axis for motion.
step 4: add a setting in the ini file for [VTK] to activate simulation by loading the new yaml file on startup.
Have fun!
Chris
  • Marc_P
  • Marc_P
14 Aug 2025 14:35
Replied by Marc_P on topic Search for Google document from rodw
Hello Rod.
Thanks for the Info.
Too bad I can't buy it. I have no link account and with the standard checkout it says "No suitable delivery method could be found"
Is there any other option? Like PayPal or something else?
  • PCW
  • PCW's Avatar
14 Aug 2025 14:30
Connect Mesa 6i25 HDR26 with 7I52S HDR50
Category: Driver Boards
1. No, just ground them
2. See #1
3. Because the 7I52 (which supports RS-422/RS-485 Serial) and 7I52S use the same PCB
4. The FPGA source and HM2 driver support muxed encoders, so as long as the pinout file
    is correct, there's nothing else needed
  • PCW
  • PCW's Avatar
14 Aug 2025 13:57
System hangs repeatedly with certain combinations of operations
This suggests to me that it may hang at the first G1 after the speed setting (M3 S10000)
  • spindle.N.at-speed - (bit, in) Motion will pause until this pin is TRUE, under the following conditions:
    • before the first feed move after each spindle start or speed change;
    • before the start of every chain of spindle-synchronized moves;
    • and if in CSS mode, at every rapid to feed transition. This input can be used to ensure that the spindle is up to speed before starting a cut, or that a lathe spindle in CSS mode has slowed down after a large to small facing pass before starting the next pass at the large diameter. Many VFDs have an at speed output. Otherwise, it is easy to generate this signal with the HAL near component, by comparing requested and actual spindle speeds.
14 Aug 2025 13:12
Replied by tommylight on topic Connect Mesa 6i25 HDR26 with 7I52S HDR50
Moved to "driver boards".
14 Aug 2025 13:11
Replied by tommylight on topic multiple estops on separate pins
Rod, i did not read your post past "estop-latch is the right way to go", and you know the reason why.
Sorry, this time i should have continued.
Thank you.
  • Pashtet
  • Pashtet
14 Aug 2025 13:06
Custom M codes don't work on Rasberry Pi 5 + Messa 7i95
Category: G&M Codes
Friends, thank you all for your help. I solved the problem through digital outputs and remap.
Something like this -
O<auto_control_off> SUB
  M65 P0
O<auto_control_off> ENDSUB
M2
O<auto_control_on> SUB
 M64 P0
O<auto_control_on> ENDSUB
M2
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
RS274NGC_STARTUP_CODE = G21 G40 G90 G94 G97 G64 P0.025
USER_M_PATH =/home/pi/linuxcnc/configs/GRINDER_CNC/macros
SUBROUTINE_PATH =/home/pi/linuxcnc/configs/GRINDER_CNC/macros
REMAP = M20 modalgroup=10 ngc=auto_control_on
REMAP = M21 modalgroup=10 ngc=auto_control_off
But another task appeared - to run scripts for turning off bits when pressing the "Stop" or "Emergency stop" button. It is necessary to stop additional equipment, as for example, the spindle and cooling stop.
  • juergen-home
  • juergen-home
14 Aug 2025 12:53 - 14 Aug 2025 12:56
Connect Mesa 6i25 HDR26 with 7I52S HDR50 was created by juergen-home
So I made something up to connect  6i25 HDR26 with 7I52S HDR50.
Some questions about that:
1. Do I have to connect /TX3BENA and /TX0BENA with i/0 pins and config them to low in the .hal file?
2. Can I pull /TX3BENA and /TX0BENA low to GND to save I/O ports?
3. What reason only Differential outputs TX0B and TX3B can be Tristated, do they have a special purpose?
4. Is ENCMUX managed by the 6i25 or do I have to handle the mux things in the .hal myself?
There are a few more questions but this is enough for today.
(my configuration so far was in www.forum.linuxcnc.org/49-basic-configur...r-spindle-ccw#333214)
Conn
                                      P2 INTERNAL    FUNCTION
DIR 7I52S HDR50         7I52S HDR50    6I25 HDR26        6I25  .vhd                                                    „virtual DB
in  /TX3BENA                      1             1        IO17  IOPortTag & x"00" & NullTag & x"00",                    -- I/O 00
    GND                           2
out MENCA0 (Enc0 A)               3             2        IO18  IOPortTag & x"00" & MuxedQCountTag & MuxedQCountQAPin,  -- I/O 01
    GND                           4
out MENCB0 (Enc0 B)               5             3        IO19  IOPortTag & x"00" & MuxedQCountTag & MuxedQCountQBPin,  -- I/O 02
    GND                           6
out MIDX0 (Enc0 Index)            7             4        IO20  IOPortTag & x"00" & MuxedQCountTag & MuxedQCountIDXPin, -- I/O 03
    GND                           8
out MENCA1 (Enc1 A)               9             5        IO21  IOPortTag & x"01" & MuxedQCountTag & MuxedQCountQAPin,  -- I/O 04
    GND                          10
out MENCB1 (Enc1 B)              11             6        IO22  IOPortTag & x"01" & MuxedQCountTag & MuxedQCountQBPin,  -- I/O 05
    GND                          12
out MIDX1 (Enc1 Index)           13             7        IO23  IOPortTag & x"01" & MuxedQCountTag & MuxedQCountIDXPin, -- I/O 06
    GND                          14
out MENCA2 (Enc2 A)              15             8        IO24  IOPortTag & x"02" & MuxedQCountTag & MuxedQCountQAPin,  -- I/O 07
    GND                          16
out MENCB2 (Enc2 B)              17             9        IO25  IOPortTag & x"02" & MuxedQCountTag & MuxedQCountQBPin,  -- I/O 07
    GND                          18
out MIDX2 (Enc2 Index)           19            11        IO26  IOPortTag & x"02" & MuxedQCountTag & MuxedQCountIDXPin, -- I/O 09
    GND                          20
out ENCMUX                       21            13        IO27  IOPortTag & x"00" & MuxedQCountSelTag & MuxedQCountSel0P-- I/O 10
    GND                          22
in  TX5B                         23            15        IO28  IOPortTag & x"05" & StepGenTag & x"81",                 -- I/O 11
    GND                          24
in  TX5A                         25            17        IO29  IOPortTag & x"05" & StepGenTag & x"82",                 -- I/O 12
    GND                          26
in  TX4B                         27            19        IO30  IOPortTag & x"04" & StepGenTag & x"81",                 -- I/O 13
    GND                          28
in  TX4A                         29            21        IO31  IOPortTag & x"04" & StepGenTag & x"82",                 -- I/O 14
    GND                          30
in  TX3B                         31            23        IO32  IOPortTag & x"03" & StepGenTag & x"81",                 -- I/O 15
    GND                          32
in  TX3A                         33
    GND                          34
in  TX2B                         35
    GND                          36
in  TX2A                         37
    GND                          38
in  TX1B                         39
    GND                          40
in  TX1A                         41
    GND                          42
in  TX0B                         43
    GND                          44
in  TX0A                         45
    GND                          46
in  /TX0BENA                     47            25        IO33  IOPortTag & x"00" & NullTag & x"00",                    -- I/O 16
    GND                          48
in  +5V PWR                      49            18         +5V  BREAKOUT POWER OPTION +5V ?
    GND                          50            10         GND
                                                               /TX3BENA is an active low enable signal.
        BREAKOUT POWER OPTION +5V DB25 pins 22,23,24 and 25
        BREAKOUT POWER OPTION +5V HDR PINS 18,20,22,24,26
                                                               FIX GND HDR PINS 10,12,14,16
                                                               ‘M’ prefix on the interface encoder signals is to
                                                               indicate that they are multiplexed signals.
  • cmorley
  • cmorley
14 Aug 2025 12:52
Replied by cmorley on topic QTPYVCP+VISMACH+LINUXCNC ROLLED INTO ONE?
Category: QtPyVCP
There is a qt version of vismach in 2.9+. In theory you should be able to add it into any qt5 based screen.
I don't know much about qtpyvcp, maybe asked their devs if it's possible, or maybe they can port a version specifically for their screen.
linuxcnc.org/docs/stable/html/gui/qtvcp-vismach.html
Displaying 13726 - 13740 out of 14149 results.
Time to create page: 1.627 seconds
