  • PCW
  • PCW's Avatar
30 Jun 2025 21:10
homing with Phase Z encoder on MESA 7i96s
Did you check the home switch operation?
That is, does  joint.2.home-sw-in go true (change from red to yellow in halshow)
when you manually trip the home switch?
  • Ac1dburn
  • Ac1dburn
30 Jun 2025 20:35
Thank you for the reply scotta,
I'm assuming you meant to say LPC1769
As I'm not using an LPC1768 on the turbo. I'll take a look at what you sent and report back
  • scotta
  • scotta's Avatar
30 Jun 2025 20:28
The LPC1768 is legacy and I suspect that you have installed the current version of the remora component for LinuxCNC. The data packet was updated since the LPC1768 development stopped.
Try this component
github.com/scottalford75/Remora/tree/mai...NC/Components/Remora
You're very close by the looks.
  • Bertho
  • Bertho
30 Jun 2025 20:26
How to write multipule data ( byte) mesambccc
A fix for the indicated problem has been committed to the master branch. It also includes several other fixes to provide better support for this and other devices by introducing byte types and some extra attributes.
The following mbccs file I suggest to use as a starting point. It only works with the new patches because it uses the new byte-types. Also, many types have been corrected to use the proper signed types and sizes. The interval is set to let the commands loot at 10Hz. There is probably no point in hammering the device with queries continuously.
Extra configuration may be necessary because some pins need to have a very specific values when you write (according to the docs; these are record written in a transaction). It will require starting the driver in suspended mode and use a hal-file to do pin setups before taking the driver out of suspend.
There are many issues that need to be addressed in this configuration. See also the comments in the below code. I do not know what exactly you are trying to do, but some reads are static data and some writes are probably one-time setup values that never will change during operation (and should therefore be initlist entries). Static data is not normally what you continuously want to read or write in a loop.
It is probably a good thing to try to define exactly what you are trying to achieve and control in the modbus communication. What running data is extracted/used elsewhere and what running parameters are to be live tuned. Remember, read function will read continuously and write functions will write every single change to a pin.
<?xml version="1.0" encoding="UTF-8"?>
<mesamodbus baudrate="115200" parity="E" stopbits="1" interval="100000">
  <!-- Note the interval setting: 100000 us (10 Hz) -->
  <!-- It may be necessary to start suspended (suspend="true") to setup pins before starting to send data -->
  <devices>
    <device address="0x02" name="mrje70a">
      <description>Manual for MR-JE-_A device communication:
  title: "MR-JE-_A SERVO AMPLIFIER INSTRUCTION MANUAL (Modbus RTU Protocol)"
  link:  https://dl.mitsubishielectric.com/dl/fa/document/manual/servo/sh030177/sh030177c.pdf
See chapter 6 for modbus types.
      </description>
    </device>
  </devices>
  <initlist>
    <!-- There should probably be some commands here... see comments below -->
  </initlist>
  <commands>
    <command device="mrje70a" function="R_REGISTERS" address="0x2b01" unaligned="1">
      <pin name="cfp" modbustype="S_CDAB" haltype="HAL_S32" />
    </command>
    <command device="mrje70a" function="R_REGISTERS" address="0x2b0f">
      <pin name="volt" modbustype="U_AB" haltype="HAL_U32" />
    </command>
    <command device="mrje70a" function="R_REGISTERS" address="0x2b2d">
      <pin name="power" modbustype="S_AB" haltype="HAL_S32" />
    </command>
    <command device="mrje70a" function="R_REGISTERS" address="0x2001" unaligned="1">
      <pin name="rpa01" modbustype="S_CDAB" haltype="HAL_S32" />
    </command>
    <!-- Not sure this should be read all the time -->
    <command device="mrje70a" function="R_REGISTERS" address="0x2801" modbustype="U_AB" haltype="HAL_U32">
      <pin name="rnument-2801" modbustype="U_A"/>
      <pin name="position" modbustype="S_CDAB" haltype="HAL_S32"/>
      <pin name="speed"/>
      <pin name="accel"/>
      <pin name="decel"/>
      <pin name="dwell"/>
      <pin name="subfunc" modbustype="U_A"/>
      <pin name="mcode" modbustype="U_A"/>
    </command>
    <!-- NOTE: The following command is only read *once* because EEPROM data is static data -->
    <command device="mrje70a" modbustype="U_CDAB" haltype="HAL_U32" function="R_REGISTERS" address="0x1010" interval="once" unaligned="1">
      <pin name="rnument-1010" modbustype="U_A"/>
      <pin name="eesave-all-parms"/>
      <pin name="eesave-comm-parms"/>
      <pin name="eesave-app-parms"/>
      <pin name="eesave-factory-parms"/>
      <pin name="eesave-point-table"/>
    </command>
    <command device="mrje70a" modbustype="U_CDAB" haltype="HAL_U32" function="R_REGISTERS" address="0x2c12" unaligned="1">
      <pin name="rnument-2c12" modbustype="U_A"/>
      <pin name="rextindsp-1"/>
      <pin name="rextindsp-2"/>
      <pin name="rextindsp-3"/>
      <pin name="rextindsp-4"/>
    </command>
    <command device="mrje70a" modbustype="U_AB" haltype="HAL_U32" function="R_REGISTERS" address="0x6041">
      <pin name="status"/>
    </command>
    <command device="mrje70a" modbustype="U_AB" haltype="HAL_U32" function="R_REGISTERS" address="0x6040">
      <pin name="rcontrolword"/>
    </command>
    <command device="mrje70a" modbustype="S_A" haltype="HAL_S32" function="R_REGISTERS" address="0x6061">
      <pin name="mode"/>
    </command>
    <!-- This is probably not something you want to read all the time. -->
    <!-- Does this change? it is written down below, see comment there. -->
    <command device="mrje70a" modbustype="S_AB" haltype="HAL_S32" function="R_REGISTERS" address="0x2d60">
      <pin name="rtargetpt"/>
    </command>
    <command device="mrje70a" modbustype="U_CDAB" haltype="HAL_U32" function="R_REGISTERS" address="0x6099">
      <pin name="rnument-6099" modbustype="U_A"/>
      <pin name="rhps-spd-switch"/>
      <pin name="rhps-spd-zero"/>
    </command>
    <!-- *** Write commands follow *** -->
    <!-- Setting the control word will need to be setup properly on the pin *before* the driver starts sending data. -->
    <!-- It also might be an initlist entry -->
    <command device="mrje70a" function="W_REGISTERS" modbustype="U_AB" haltype="HAL_U32" address="0x6040">
      <pin name="ctrlwordwt"/>
    </command>
    <!-- Setting the operational mode should most likely be done in the initlist -->
    <command device="mrje70a" function="W_REGISTERS" modbustype="S_A" haltype="HAL_S32" address="0x6060">
      <pin name="wopermode"/>
    </command>
    <!-- Setting the point table reference will need to be setup properly on the pin *before* the driver starts sending data. -->
    <!-- If it is to be in the command list, then writeflush polarity must be considered -->
    <!-- It might be required to be an initlist entry, as this is most likely a static config -->
    <command device="mrje70a" function="W_REGISTERS" modbustype="S_AB" haltype="HAL_S32" address="0x2d60">
      <pin name="wtargetpt"/>
    </command>
    <!-- Setting homing speed should probably be done in the initlist -->
    <!-- *** This write requires pin setup /before/ it is sent. *** The wnument-6099 should to be set to 0x02. -->
    <command device="mrje70a" function="W_REGISTERS" address="0x6099" modbustype="U_CDAB" haltype="HAL_U32">
      <pin name="wnument-6099" modbustype="U_A"/>
      <pin name="whps-spd-switch"/>
      <pin name="whps-spd-zero"/>
    </command>
  </commands>
</mesamodbus>
  • JackRay
  • JackRay
30 Jun 2025 20:08
Replied by JackRay on topic homing with Phase Z encoder on MESA 7i96s
Are you saying that my .ini file is misconfigured and that's why I can't detect my Z homing?
  • Tntmold
  • Tntmold
30 Jun 2025 19:46
Replied by Tntmold on topic General Questions about using ethercat
Category: EtherCAT
I have linuxcnc loading but the steppers still won't move.  Ethercat Slaves shows drive is in OP mode, but when I use "ethercat upload" to check drive parameters, I see that the drive is not in CSP mode.  Where is this supposed to happen?
  • PCW
  • PCW's Avatar
30 Jun 2025 18:41 - 30 Jun 2025 18:42
Troubles to get started with SD240 Retrofit
Category: Turning
You are missing the "servo-thread" for the "jogincr" component
that is:
addf hm2_7i80.0.read servo-thread
addf pid.x.do-pid-calcs servo-thread
addf pid.z.do-pid-calcs servo-thread
addf pid.s.do-pid-calcs servo-thread
addf jogincr
addf hm2_7i80.0.write servo-thread
should be:
addf jogincr servo-thread
  • PCW
  • PCW's Avatar
30 Jun 2025 18:35
Replied by PCW on topic Lo ejes dejaron de moverse
That is a realtime network error.
1. Have you run a latency test on the PC?
2. What s PC hardware is being used?
3. Have you disabled all power management in the PC's BIOS?
4. What is the result of the command (typed in a terminal)
ip a
  • Johnnysacalu
  • Johnnysacalu
30 Jun 2025 14:31
Replied by Johnnysacalu on topic Lo ejes dejaron de moverse
He cambiado U5 y U7 ahora me salta este error
30 Jun 2025 13:55
Replied by tommylight on topic Puesta a tierra
Puesta a tierra
There are (often) cases where negative sides of power supplies must be wired together, but usually not at the power supply, it is done on equipment from one part to another. This avoids loops and keeps stuff at the same potential.
There are cases where this is not allowed at all.
So the short answer is yes and no, you have to know what you are dealing with to know if this can be done or not, and is not something you can just read on the internet, it requires deeper knowledge of the subject.
It is easier to answer if you give us exactly what you need to do.
  • kubes
  • kubes
30 Jun 2025 13:34
User error or a strange event on probing. Broken ruby tip.
Category: QtPyVCP
I was not implying there was an issue with the subroutines. While I don't use them as much as you, I have used them quite a bit without any problem. Additionally, my machine is a Bridgeport BOSS, which is quite rigid.
Having a log would provide the facts of what really happened, rather than relying on what I think I saw. Again, as probing has worked flawlessly, I was not 100% focused on the details. It looked like it triggered on the Z and kept going. I always test the probe connection prior to probing, with a manual trigger. So knowing if it triggered, how many times, the feedreate and movement, in chronological order, I could solve this definitively. I was thinking of saving the last 2-3 probes and rolling the logs so one the past probing, but not wasting disk space
  • hellvetica
  • hellvetica
30 Jun 2025 13:25
Robot reads the same position every time it is turned on.
The .txt file is actually a .sh file but I can't upload it here
  • Johnnysacalu
  • Johnnysacalu
30 Jun 2025 12:26
Puesta a tierra was created by Johnnysacalu
Puesta a tierra
No creo que sea real, pero lo pregunto los negativos de las fuentes de alimentación de diferentes voltaje hay que unirlos entre Ellos. También había escuchado algo sobre que todos estos conectados hay que llevarlos a la tierra AC Que me parece mal también, pero no entiendo así que lo pregunto. Gracias
  • Leo90
  • Leo90
30 Jun 2025 11:58 - 30 Jun 2025 11:59
EL2502 and EL2535 PWM Ethercat BECKHOFF Modules
Category: EtherCAT
Hi, I'm also looking forward to your conclusion because I need EL2502 too. Besides PWM, I also need duty cycle to controll a laser.
Thank you
  • michaeln
  • michaeln
30 Jun 2025 11:05 - 30 Jun 2025 11:08
Replied by michaeln on topic Axis 2 - touchscreen version of old friend
Category: AXIS
Hello,
i think there is an error and think it must be:
sudo chmod +x /usr/share/axis/tcl/axis2.tcl instead of sudo chmod +x /home/donno/Downloads/axis2/axis2.tcl
(third line with sudo)
[b][b][b][code][b][b][b][code][b][b][b][code][b][b][code]I tested this on Linuxcnc 2.10pre and works great !
 [attachment=56124]axis2.png[/attachment]
Maybe add a readme.txt in zip with instructions to install ??
[code]Setup Instructions Main
set display = axis2 in your ini
sudo cp -a /home/donno/Downloads/axis2/icons/. /usr/share/axis/images
sudo cp /home/donno/Downloads/axis2/axis2.tcl /usr/share/axis/tcl
sudo cp /home/donno/Downloads/axis2/axis2 /usr/bin
sudo chmod +x /usr/bin/axis2
sudo cp /home/donno/Downloads/axis2/glcanon.py /usr/lib/python3/dist-packages/rs274/
sudo chmod +x /usr/lib/python3/dist-packages/rs274/glcanon.py
Linuxcnc-DEV
sudo cp -a /home/donno/Downloads/axis2/icons/. /home/donno/linuxcnc-dev/share/axis/images/
sudo cp /home/donno/Downloads/axis2/axis2.tcl /home/donno/linuxcnc-dev/share/axis/tcl/axis2.tcl
sudo chmod +x /home/donno/linuxcnc-dev/share/axis/tcl/axis2.tcl
where "donno" should be your username
[/code][/b][/b][/code][/b][/b][/b][/code][/b][/b][/b][/code][/b][/b][/b][/code]
Displaying 14431 - 14445 out of 15150 results.
Time to create page: 0.749 seconds
