  • PCW
  • PCW's Avatar
24 Jun 2025 17:51
Replied by PCW on topic New with questions on LinuxCNC and Mesa
In general there is no real advantage to have the local rotary feedback
returned to LinuxCNC (and some electrical disadvantages) So a 7I95T
would have sufficient Encoder channels.
  • PCW
  • PCW's Avatar
24 Jun 2025 17:48
homing with Phase Z encoder on MESA 7i96s
Is the index input jumpered for TTL MODE? (W1 left)
Unless this is done, the results will be unpredictable.
  • Russell072009
  • Russell072009
24 Jun 2025 17:21
Replied by Russell072009 on topic New with questions on LinuxCNC and Mesa
Thanks for the info.
So the servo motors I'm looking at are integrated servo/driver/encoder and use stepper control signals. I'm under the impression that I would use a 7I95T card. Seeing as Y will have a slaved servo I'll be short one feedback channel. So I would get a 7I76 to plug in to the 7I95T correct? Then I will have all 7 feedback channels for the 4 servos and the 3 scales. It would also allow for future expansion of an A axis with feedback.
Now, If I go to run a spindle with encoder will that be handled by the 7I95T in addition to the 6 axis channels it has? Also, is this the only card I will need? It sounds like it runs ethernet to the PC and that is it.
  • JackRay
  • JackRay
24 Jun 2025 17:16
Replied by JackRay on topic homing with Phase Z encoder on MESA 7i96s
So, my signal goes to true, but doesn't return to false once the wire is removed from GND. moreover, it doesn't happen every time. sometimes it works, sometimes it doesn't?
  • PCW
  • PCW's Avatar
24 Jun 2025 16:53
Replied by PCW on topic Weiler DZ26 Millturn Conversion
Category: Turning
The standard 5i25_7i77x2.bit supports sserial on TB6
Do you have the added channel enabled in the hal file?
  • directandrew
  • directandrew
24 Jun 2025 16:50
probe basic conversational macros missing? was created by directandrew
Category: QtPyVCP
Hi all,I noticed that SOME conversational macros ( pocketing, Frame etc.) are currently missing from my install from last night? What key detail am I missing? I was under the impression they were part of the build? Im new to this and testing the software on my PC.
See pics
other than that, looks great!
Followed this install link kcjengr.github.io/probe_basic/quick_start.html
  • MacKaye
  • MacKaye
24 Jun 2025 16:42
Replied by MacKaye on topic Weiler DZ26 Millturn Conversion
Category: Turning
Hi, i made it run (badly) with the 7i77 alone but decided to add a 7i84U for some further inputs to revive all features the machine originally had.
I can´t seem to make the TB6 sserial connection work with any bitfile included in the 5i25 repository. Its 6i25 P3 to P1 7i77 and TB6 to 7i84. Is there something available or something that might just work?
Best,
Lukas
  • PCW
  • PCW's Avatar
24 Jun 2025 16:12
Typically, unless you need linear encoder feedback, you can use servo/closed loop drives that
just have local feedback, (no feedback to LinuxCNC) so you don't need encoder inputs, other than
one for the spindle if you want to do spindle synchronized moves.
For a simple system, I would consider a 7I96S or 7I76EU (the main difference is the the 7I76EU has
more digital I/0.) If you are sure you want to add encoder feedback a 7I95T would make more sense,
though you can add an encoder daughtercard to a 7I96S or 7I76EU (7I85/7I89 = 4/8 added encoders)
  • Russell072009
  • Russell072009
24 Jun 2025 15:35
New with questions on LinuxCNC and Mesa was created by Russell072009
I am new to the hobby CNC game. I currently have a little 3018that runs GRBL I bought to get my feet wet. My day job is CNC electronics maintenance so I have some experience with industrial controllers. What I would like to do is get a machine running with dual feedback. The biggest issue I have with the little guy is step loss. From what I have found you can run "closed loop" stepper systems which sort of solve the problem but not really so I want to build a system that will do exactly what I want and I was told LinuxCNC and a Mesa controller is the way to go. I have looked at the Mesa site and am thoroughly confused on the options. I see that I'm probably going to want an ethernet connection for real time. I'll have Linux running on a stand alone laptop so I want the controller external. I also know I'll need drivers for the servos and power supplies. Which controller and which daughter boards I need are the problem. I will build a 3 axis gantry machine with a slaved pair of Y motors. I would like future expandability options for a 4th axis down the road. I want all 3 axis to run rotary feedback on the motors as well as linear scales for each axis with machine primary positioning done from the scales and compared to the encoders. This is how industrial CNC machines run. Is this something that LinuxCNC and Mesa control boards can handle? If so can anyone help me out with selecting the mesa boards I would need to accomplish this?
  • bcorley
  • bcorley
24 Jun 2025 14:26
Laser Head Height Sensor – Looking for a Beta Tester
Category: Plasma & Laser
A test device would be great. What information do you need to get it to me?
  • JT
  • JT's Avatar
24 Jun 2025 14:21
Flex GUI 1.2.2 Released was created by JT
Category: Flex GUI
Flex GUI now has HAL I/O controls for a checkable push button, a check box, a spin box and a double spin box.
JT
  • electrosteam
  • electrosteam
24 Jun 2025 10:31
Replied by electrosteam on topic WiFi Problem on Raspberry Pi
Borrowed a dongle, TP-Link TP-WN722N, from a Forum Member.
Got an external antenna from another Form Member.
Much swapping and shifting around between bench, cubicle and cabled as far from cubicle as lengths would allow.
Dongle, antenna, 4GB and 8GB, power supplies, LC2.9.2 and LC2.9.4, etc etc
The Dongle works fine, Ebay says $15.
Eventually replaced the monitor on the mill with the one from the bench.
SUCCESS.
Even works in the cubicle with door open without the dongle.
Who would have thought !
Suggestions welcomed on what to do with the faulty monitor.
I am in Kingswood if you want to drop by and take it off my hands.
Thanks to all for the help,
John.
  • meister
  • meister
24 Jun 2025 10:06 - 24 Jun 2025 10:08
Replied by meister on topic LinuxCNC Machine Vision
there is already some opencv stuff included:
github.com/multigcs/riocore/blob/main/ri...ons/camjog/camjog.py
  • matasbuk
  • matasbuk
24 Jun 2025 08:58
Replied by matasbuk on topic 7i95t smart serial
7i95t smart serial
Solved it myself, had to set sserial_port_0=00xxxxxx
  • matasbuk
  • matasbuk
24 Jun 2025 08:30
7i95t smart serial was created by matasbuk
7i95t smart serial
Hello, can I connect both 7i83 and 7i84U to Mesa 7i95t? I need analog output for the spindle and 7i84U for IO expansion. If I connect them both, only the card in the first port gets recognized.
Displaying 14626 - 14640 out of 15153 results.
Time to create page: 0.390 seconds
