  • dunnitagain
  • dunnitagain
09 Jun 2025 23:57
Linuxcnc 2.4.5 with Ubuntu 10.04 , Terminated with Error!
Hello , Newb here. Just bought 2 , very nice Bridgeport and Jet mill retrofits , with Microkentics Steppers and PICO Universal Stepper cards , from the estate of a friend. Machines are very nicely built.
They sat idle since 2013, the Cmos batteries were dead . Ive been working on the .ini file of the Jet mill , to correct the homing sequence.
Everything was great , fixed the Z Axis homing . Powered down the control to plug the A axis in . Now on power up , it will not load Linuxcnc 2.4.5.
Is there a way to decode the error message , to see what i need to change, to return functionality ?
   The computers are bare bones machines, no network capabilities , just USB.
             Where can I look , or were do I Start ?
  • tar_san
  • tar_san
09 Jun 2025 23:21 - 10 Jun 2025 06:03
Replied by tar_san on topic Problems with Lichuan Ethercat servo drive
Category: EtherCAT
Thank you. I tried both V1.04 and V1.11.
But I couldn't make servo drive move in LinuxCNC main screen.
I didn't see any error on screen,  but servo drivers didn't become "Servo On" state when I pushed "PowerOn"
Where do I need to check ? ( I used to use another tiny LinuxCNC system and machine , but it was stepper.., I used step conf. )
Do I have to set some servo parameter from switches on servo driver ?
( No load is connected to servo motors for now. )
Servo Driver Panel shows "20ry" (2 is blinking.)
I tried both V1.11 and V1.04 and this configuration,
forum.linuxcnc.org/ethercat/52341-proble...rive?start=60#304887
I have 3 sets of Lichuan Servo (Driver+Motor), I want to use them as XYZ CNC.
  • kubes
  • kubes
09 Jun 2025 23:02 - 11 Jun 2025 17:03
Connecting a tool setter and touch probe at the same time
I did not see any other input other than motion.probe-in, is this used for both a tool length setter and a touch probe?  My HW will support several inputs, and I would like to have each hard-wired in, without the need to swap cables, etc.
Is there a dedicated motion input for a tool length setter? If not what is the best means to have to separate HW inputs?
Thanks!!!
09 Jun 2025 22:59
Replied by tommylight on topic Career in LinuxCNC/machine building
Hmmmm ... :
-walk around your area, see what businesses use CNC machines and for what and how = maintenance, service, maybe CAD/CAM and/or machine setup
-see what other businesses have offices there, what they do, drop buy any that do any manufacturing = contracting work, jobs to small for contracts are especially good as no one wants to do them
-drop buy other mom/pop shops, see if there's anything automated that can help them, or streamlining their work
-any foto/video studio, ask if they need sets/props built as needed, cam cranes or robots etc
-any food restaurants that want their logos engraved/cut/3d printed/scratched on glass = see my glass engravers here on forum, add LED's as needed
-leave your phone number to all of them
-and this is very important: do not lie to them, tell them exactly about doing market research trying to find a business that helps them but does not interfere with their existing businesses, as a rule at least 70-80% of them will really appreciate this and will gladly advise you and offer ideas.
--widen the "walk" area
-repeat above
  • russkinch
  • russkinch's Avatar
09 Jun 2025 22:50
Replied by russkinch on topic Encoder for rigid tapping
Category: HAL
Aaah. Awesome. Thank you. I shall try this tomorrow and see how it goes. I will let you know once I have changed the settings.
  • Hakan
  • Hakan
09 Jun 2025 22:38 - 09 Jun 2025 22:52
Replied by Hakan on topic SANGE elec IO
SANGE elec IO
Category: EtherCAT
Run the "lcec_configgen" command and compare.
Also check for relevant error messages from the command "sudo dmesg"
Edit, and according to the xml you attached, output 8 to 15 is in syncmanager 1, but you'll see that.
  • PCW
  • PCW's Avatar
09 Jun 2025 22:32 - 09 Jun 2025 22:34
Replied by PCW on topic Encoder for rigid tapping
Category: HAL
Sounds like you have the encoder component set to counter mode
rather than quadrature mode (counter mode set to 1 rather than 0)
( another hint is your scaling, a 50 PPR encoder is 200 counts/turn
in 4x quadrature )
man encoder
Displaying 15271 - 15277 out of 15277 results.
Time to create page: 0.445 seconds
