  • spincycle
  • spincycle
29 May 2025 04:38
Replied by spincycle on topic Bridgeport VMC760 retrofit
Category: Milling Machines
Nope!
Mesa cards and servos are on there way though1 Ill make a more detailed post of my progress in the next day or two.
To answer your question. With a forklift.
  • kubes
  • kubes
29 May 2025 04:24
Huanyang GT Series VFD Issues was created by kubes
I am trying to get a Huanyang GT VFD to work with LinuxCNC. When I start Linux CNC or via halrun..
halrun
loadusr -W hy_gt_vfd -d /dev/ttyUSB0 -p none -r 38400 -s 1 -t 1 -S1410 -F60 -f10
twopass:pass0: loadusr -W hy_gt_vfd -d /dev/ttyUSB0 -p none -r 38400 -s 1 -t 1 -S1410 -F60 -f10
hy_gt_vfd: device='/dev/ttyUSB0', baud=38400, parity='N', bits=8, stopbits=1, address=1
read_modbus_register: error reading freq-fb (register 0x3000): Connection timed out
set_motor_off: error writing 5 to register 0x1000: Connection timed out
I can successfully connect and send commands via mbpoll and the command line
$ mbpoll -m rtu -a 1 -0 -t 4:hex -v  -r 0x1000 -b 38400 -P none /dev/ttyUSB0 0005
debug enabled
Set start reference=4096
Set rtu baudrate=38400
Set rtu parity=none
Set device=/dev/ttyUSB0
1 write data have been found
Set data=5
Word[0]=0x5
mbpoll 1.0-0 - FieldTalk(tm) Modbus(R) Master Simulator
Copyright © 2015-2019 Pascal JEAN, https://github.com/epsilonrt/mbpoll
This program comes with ABSOLUTELY NO WARRANTY.
This is free software, and you are welcome to redistribute it
under certain conditions; type 'mbpoll -w' for details.
Opening /dev/ttyUSB0 at 38400 bauds (N, 8, 1)
Set response timeout to 1 sec, 0 us
Protocol configuration: Modbus RTU
Slave configuration...: address = [1]
                        start reference = 4096, count = 1
Communication.........: /dev/ttyUSB0,      38400-8N1
                        t/o 1.00 s, poll rate 1000 ms
Data type.............: 16-bit register, output (holding) register table
[01][06][10][00][00][05][4D][09]
Waiting for a confirmation...
<01><06><10><00><00><05><4D><09>
Written 1 references.
I've tried different baud rates, etc and the same results.  Works via the command line, but not via the hal.
Any ideas?
  • cmorley
  • cmorley
29 May 2025 03:36
Replied by cmorley on topic woodpecker.ini - cant be loaded
Hello,
I have RIP installation LCNC 2.10
I cannot woodpecker.ini in sim configs.
Is it bug or dont I have some packages?
zdenek@cnc:~/linuxcnc/linuxcnc-zz912$ linuxcnc
LINUXCNC - 2.10.0~pre0
Machine configuration directory is '/home/zdenek/linuxcnc/linuxcnc-zz912/configs/sim/woodpecker'
Machine configuration file is 'woodpecker.ini'
Starting LinuxCNC...
Note: Using POSIX realtime
Found file(REL): ./core_sim.hal
Found file(lib): /home/zdenek/linuxcnc/linuxcnc-zz912/lib/hallib/simulated_home.hal
[QTvcp.QTVCP.QT_MAKEGUI][CRITICAL]  'MachineLog' object has no attribute 'setFrameShape' (qt_makegui.py:213)
[QTvcp][CRITICAL]  Aborted from Error Dialog
 Qtvcp encountered an error.  The following information may be useful in troubleshooting:
LinuxCNC Version  : 2.10.0~pre0
  File "/home/zdenek/linuxcnc/linuxcnc-zz912/bin/qtvcp", line 607, in <module>
    _qtvcp = QTVCP()
  File "/home/zdenek/linuxcnc/linuxcnc-zz912/bin/qtvcp", line 307, in __init__
    window.instance(filename=self.PATH.XML)
  File "/home/zdenek/linuxcnc/linuxcnc-zz912/lib/python/qtvcp/qt_makegui.py", line 202, in instance
    instance = uic.loadUi(filename, self)
  File "/usr/lib/python3/dist-packages/PyQt5/uic/__init__.py", line 241, in loadUi
    return DynamicUILoader(package).loadUi(uifile, baseinstance, resource_suffix)
  File "/usr/lib/python3/dist-packages/PyQt5/uic/Loader/loader.py", line 66, in loadUi
    return self.parse(filename, resource_suffix)
  File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 1037, in parse
    actor(elem)
  File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 828, in createUserInterface
    self.traverseWidgetTree(elem)
  File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 806, in traverseWidgetTree
    handler(self, child)
  File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 273, in createWidget
  File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 503, in createLayout
  File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 546, in handleItem
  File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 264, in createWidget
    self.stack.push(self.setupObject(widget_class, parent, elem))
  File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 230, in setupObject
    self.wprops.setProperties(obj, branch)
  File "/usr/lib/python3/dist-packages/PyQt5/uic/properties.py", line 417, in setProperties
    getattr(widget, 'set%s%s' % (ascii_upper(prop_name[0]), prop_name[1:]))(prop_value)
AttributeError: 'MachineLog' object has no attribute 'setFrameShape'
 (qtvcp:557)
'QTVCP' object has no attribute 'panel'
/home/zdenek/linuxcnc/linuxcnc-zz912/scripts/linuxcnc: řádek 990: 14734 Neoprávněný přístup do paměti (SIGSEGV)                     $EMCDISPLAY -ini "$INIFILE" $EMCDISPLAYARGS "${EXTRA_ARGS[@]}"
task: 0 cycles, min=0.000005, max=0.010430, avg=-1.000000, 0 latency excursions (> 10x expected cycle time of 0.010000s)
LinuxCNC terminated with an error.  You can find more information in the log:
    /home/zdenek/linuxcnc_debug.txt
and
    /home/zdenek/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
Fixed in master.
  • grandixximo
  • grandixximo's Avatar
29 May 2025 03:30
Replied by grandixximo on topic scurve trajectory planner
The best way to know is testing for yourself, it all depends on what you mean by "real work", if you find issues for your use case politely post them here.
I did my own testing, and it is getting closer to my "real work", it is very exciting, but there is still a lot of work, and I'm extremely impressed and grateful to Grotius and co to be tackling this, much appreciated...
  • rodw
  • rodw's Avatar
29 May 2025 03:17
Replied by rodw on topic Mini wannabe datron build
Category: CNC Machines
Should be fine
  • ihavenofish
  • ihavenofish
29 May 2025 03:16
Replied by ihavenofish on topic Mini wannabe datron build
Is this the correct type of modbus usb adaper?
www.digikey.ca/en/products/detail/dfrobot/FIT0737/13688358
Will get here friday if I order it now.
  • COFHAL
  • COFHAL
29 May 2025 03:16
Replied by COFHAL on topic Mesa modbus and pktUart
Category: Other User Interfaces
Interesting. But for us newbies, how do we use this mesambccc command? There's a detailed description, but no example of how to use it.
  • rodw
  • rodw's Avatar
29 May 2025 02:59
Replied by rodw on topic Linuxcnc wood lathe insufficient torque
Generally people use separate power supplies. Something like a Meanwell MDR-60-24 24 volts and a similar one for 5 volts. Meanwell MDR-10-5?
These are not expensive.
  • DavidR8
  • DavidR8
29 May 2025 02:55
What encoder resolution? was created by DavidR8
I want to add a rotary encoder to my mill spindle so that I can do rigid tapping.
I see that there are choices for PPR from 100 to 600. I'm going to be using a Mesa 7i96 card.
Is there a reason to pick one resolution over another?
  • rodw
  • rodw's Avatar
29 May 2025 02:45
Mesa 7i95t connection to Thermal Dynamics 60i
Category: Plasma & Laser
50:1 would be OK with with thcad 5 volt scale.
on 10v scale, Use 20:1 which is 200 volt full scale. That will be more accurate. It will probably go off that scale briefly when piercing but  it won't matter as we don't care about the voltage until it settles back to cut voltage of about 130 volts. The THCAD can handle the over voltage.
  • kworm
  • kworm
29 May 2025 02:16
Hi Rodw,
My automation card divider is 50:1 by default but can be set to 80:1, 40:1, 30:1, 20:1, and 16.7:1. Would you still suggest the 20:1 or would the default 50:1 work just as well?
  • rodw
  • rodw's Avatar
29 May 2025 01:39
Replied by rodw on topic Modbus via Ethercat (Beckhoff)
Category: EtherCAT
 As you mentioned before usb to rs485 is an option, I will go that way until I will be able to spend the next bucks for an ethercat VFD.
I think once you get that going, you will find it works so well, you will never go to an ethercat VFD.
Does Optidrive have a separate ethercat interface module for your VFD? A number of manufacturers do.
  • rodw
  • rodw's Avatar
29 May 2025 01:31
You don't need a relay as your card has 2 amp relays built in to the high current outputs, Use one for the torch on. Adding a relay would just add an additional failure point and add some lag into the signal.
I think your plasma has the same divider as the TD  A120 I had. In which case, use a 30:1 divider without any scaling resistors on the THCAD's 10 volt scale. If you do have a 20:1 divider (I didn't)  you could use that. set the frequency divider to 1/32 and scale the sticker frequency by the same amount when configuring qtplasmac
You do need to use a pull down resistor on the ArcOK input which is discussed in the QTP manual.
  • cmorley
  • cmorley
29 May 2025 01:28
Replied by cmorley on topic Keyboard shortcut rempaping
Category: Qtvcp
oops here is the new file.
  • cmorley
  • cmorley
29 May 2025 01:25
Category: Qtvcp
Here is a slightly different file to try. replace the one I gave before.
I think there still will be a focus problem if you click the gcode display then spacebar.
But clicking the window or graphics display should refocus so space bar works again.
If you can confirm these things, I will look further into the gcode display problem.
Focus problems are always a pain!
Displaying 15346 - 15360 out of 16110 results.
Time to create page: 0.654 seconds
