  • cmorley
  • cmorley
17 May 2025 04:09
Replied by cmorley on topic QTDragon and DTG readout
Category: Qtvcp
overlay DRO can be selected from the options button
  • cmorley
  • cmorley
17 May 2025 04:09
Category: Qtvcp
As a quick solution pull again:
  • djdelorie
  • djdelorie
17 May 2025 03:08
Two switches/sensors for tool length and 3d touching into motion-probe-in? Howto
I would avoid the mux option unless you're VERY comfortable with your programming skills. I used a mux on mine, and the first time I did something unusual with the toolsetter I broke it off because it hadn't been enabled.
I still use separate inputs, but now it's so I can apply a different software noise rejection on each input (the toolsetter tends to trip from the tool change)
  • epineh
  • epineh
17 May 2025 02:40
Hey Ollie, with Riocore I've got 4 axis closed loop to the controller going on my mill, well only one axis for now but I've tested the other 3 will work, so thanks heaps for that !
The only issue is that if you use line reciever ic's (26LS32) and RJ45 sockets it all takes up a lot of PCB real estate. I'm thinking of utilizing an off board encoder solution. The LS7366 chip looks like a good candidate, its a 32 bit quadrature counter that will decode at 20 MHz at 3 volts. (40MHz at 5V)
This chip uses SPI, which I honestly know nothing about, my question is if I was to make a seperate 8 axis encoder board to cover all the axis's MPG, spindle etc, would that work with your existing SPI plugin ? And I'm not sure if the LS7366 will daisy chain or if there needs to be an additional IO pin per device, in which case it may not be worth the overhead.
Cheers.
Russell.
  • MarkoPolo
  • MarkoPolo
17 May 2025 00:58
Replied by MarkoPolo on topic Error in tool_offsetview.py
Category: Qtvcp
Great.
Everything works fine, that's what I wanted. Thanks a lot.
It would be good to update the documentation, because old ngc files with "MACRODEFAULTS=true,false" settings will stop working for some users after updating "MacroTab".
Marek
  • Benb
  • Benb's Avatar
16 May 2025 23:58 - 17 May 2025 00:15
Replied by Benb on topic Install Probe Basic
Install Probe Basic
Category: QtPyVCP
Your amd pc is a new hardware and you might need debian 13 Trixie but again you did not have problems loading debian bookworm mistry! If you want to try Linuxcnc rip installation which might work with your amd pc since its compiled. I have atttached is a step by step procedure. It worked for me using i5 mini pc with debian 12 bookworm RT with xfce option for desktop environment.
edit: Once linuxcnc installed follow this procedure to instal qtpyvcp
This browser does not support PDFs. Please download the PDF to view it: Download PDF
  • Doc_emmet
  • Doc_emmet
16 May 2025 23:39
Replied by Doc_emmet on topic Install Probe Basic
Install Probe Basic
Category: QtPyVCP
Hello, it looks like I've found the error.
It's related to my Mini PC
GMKtec K11 AMD Ryzen 9 Gaming Mini PC 8945HS(8C/16T, up to 5.2GHz),
32GB DDR5 4800MHz RAM 1TB PCIE Mini Computer, Oculink,
Dual NIC 2.5GbE LAN/HDMI/USB 4.0/WiFi 6/BT 5.2/DisplayPort/USB4*2
When I install the software on my old Intel i7 4 cores,
there are no error messages and the jitter is also better.
But it won't install on a new AMD Ryzen 9 PC.
Thank you very much for your help.
  • Doc_emmet
  • Doc_emmet
16 May 2025 23:35 - 16 May 2025 23:42
Install Probe Basic
Category: QtPyVCP
  • Benb
  • Benb's Avatar
16 May 2025 23:20
Install Probe Basic
Category: QtPyVCP
Try loading this dependencies and then install Linuxcnc (these dependevies are for the so called run in place RIP Linuxcnc installation, its a compiled installation) but it might help you with your deb method installation (in my case I refer rip). At the command prompt issue the following command:
Sudo apt install –y debhelper-compat dh-python libudev-dev docbook-xsl asciidoc imagemagick asciidoc-dblatex autoconf automake bwidget gettext intltool libboost-python-dev libepoxy-dev libgl-dev libgl1-mesa-dev libglu1-mesa-dev libgtk2.0-dev libgtk-3-dev libmodbus-dev libgpiod-dev libeditreadline-dev libusb-1.0-0-dev libxmu-dev po4a psmisc python3-dev python3-tk python3-xlib tcl8.6-dev tk8.6-dev xvfb yapps2 dblatex dvipng fonts-dejavu graphviz groff inkscape python3-lxml source-highlight texlive-extra-utils texlive-font-utils texlive-fonts-recommended texlive-lang-cyrillic texlive-lang-european texlive-lang-french texlive-lang-german texlive-lang-polish texlive-lang-spanish texlive-latex-recommended w3c-linkchecker xsltproc texlive-xetex
  • Philip Lydin
  • Philip Lydin
16 May 2025 23:16
Replied by Philip Lydin on topic el5151 reseting counts
Category: EtherCAT
  • Philip Lydin
  • Philip Lydin
16 May 2025 22:30
el5151 reseting counts was created by Philip Lydin
Category: EtherCAT
Im hooking up a spindle encoder on my lathe to a el5151. The abz inputs goes to the el5151 but in halshow i see how it every turn resets the encoder counts and position. Im guessing this would create problems when using sync motion? It also doesnt have a velocity pin so is it okay to use the software encoder counter to get the velocity. When i do this i get a very noisy signal where it goes to 20 the 500 then 1000 then 200 etc. Just all over the place. Is it bad too use a lowpass filter to smooth it?
  • Doc_emmet
  • Doc_emmet
16 May 2025 22:24
Install Probe Basic
Category: QtPyVCP
Thank you very much for your help. I first installed www.debian.org/devel/debian-installer/ as described without any errors. Then I run:
cd ~
cd Downloads
sudo dpkg -i linuxcnc-uspace_2.9.3_amd64.deb
and I get these messages. Why these dependency problems? Or are these messages normal?
dg@LinuxCNC:~/Downloads$ sudo dpkg -i linuxcnc-uspace_2.9.3_amd64.deb
[sudo] Password for dg:
(Reading database... 119436 files and directories are currently installed.)
Preparing to unpack linuxcnc-uspace_2.9.3_amd64.deb...
Unpacking linuxcnc-uspace (1:2.9.3) via (1:2.9.3)...
dpkg: Dependency problems prevent configuration of linuxcnc-uspace:
linuxcnc-uspace depends on python3 (<< 3.12); but:
Version of Python3 on the system is 3.13.3-1.
linuxcnc-uspace depends on libboost-python1.74.0 (>= 1.74.0+ds1); but:
Package libboost-python1.74.0 is not installed.
linuxcnc-uspace depends on libboost-python1.74.0-py311; but:
Package libboost-python1.74.0-py311 is not installed.
linuxcnc-uspace depends on libgpiod2 (>= 1.5.1); but:
Package libgpiod2 is not installed.
linuxcnc-uspace depends on libmodbus5 (>= 3.1.4); but:
Package libmodbus5 is not installed.
linuxcnc-uspace depends on libpython3.11 (>= 3.11.0); but:
Package libpython3.11 is not installed.
linuxcnc-uspace depends on libtk8.6 (>= 8.6.0); but:
Package libtk8.6 is not installed.
linuxcnc-uspace depends on libudev-dev; but:
Package libudev-dev is not installed.
linuxcnc-uspace depends on iptables; but:
Package iptables is not installed.
linuxcnc-uspace depends on blt; but:
Package blt is not installed.
linuxcnc-uspace depends on mesa-utils; but:
Package mesa-utils is not installed.
linuxcnc-uspace depends on python3-tk; but:
Package python3-tk is not installed.
linuxcnc-uspace depends on python3-numpy; but:
Package python3-numpy is not installed.
linuxcnc-uspace depends on python3-opengl; but:
Package python3-opengl is not installed.
linuxcnc-uspace depends on python3-configobj; but:
Package python3-configobj is not installed.
linuxcnc-uspace depends on python3-xlib; but:
Package python3-xlib is not installed.
linuxcnc-uspace depends on libgtksourceview-3.0-dev; but:
Package libgtksourceview-3.0-dev is not installed.
linuxcnc-uspace depends on tcl8.6; but:
Package tcl8.6 is not installed.
linuxcnc-uspace depends on tk8.6; but:
Package tk8.6 is not installed.
linuxcnc-uspace depends on bwidget (>= 1.7); but:
Package bwidget is not installed.
linuxcnc-uspace depends on tclreadline; but:
Package tclreadline is not installed.
linuxcnc-uspace depends on tclx; but:
Package tclx is not installed.
linuxcnc-uspace depends on python3-pyqt5; but:
Package python3-pyqt5 is not installed.
linuxcnc-uspace depends on python3-pyqt5.qsci; but:
Package python3-pyqt5.qsci is not installed.
linuxcnc-uspace depends on python3-pyqt5.qtsvg; but:
Package python3-pyqt5.qtsvg is not installed.
linuxcnc-uspace depends on python3-pyqt5.qtopengl; but:
Package python3-pyqt5.qtopengl is not installed.
linuxcnc-uspace depends on python3-opencv; but:
Package python3-opencv is not installed.
linuxcnc-uspace depends on python3-espeak; but:
Package python3-espeak is not installed.
linuxcnc-uspace depends on python3-dbus.mainloop.pyqt5; but:
Package python3-dbus.mainloop.pyqt5 is not installed.
linuxcnc-uspace depends on python3-pyqt5.qtwebengine | python3-pyqt5.qtwebkit; but:
Package python3-pyqt5.qtwebengine is not installed.
Package python3-pyqt5.qtwebkit is not installed.
linuxcnc-uspace depends on espeak-ng; but:
Package espeak-ng is not installed.
linuxcnc-uspace depends on pyqt5-dev-tools; but:
Package pyqt5-dev-tools is not installed.
linuxcnc-uspace depends on gstreamer1.0-tools; but:
Package gstreamer1.0-tools is not installed.
linuxcnc-uspace depends on espeak; but:
Package espeak is not installed.
linuxcnc-uspace depends on python3-poppler-qt5; however:
Package python3-poppler-qt5 is not installed.
linuxcnc-uspace depends on psmisc; however:
Package psmisc is not installed.
dpkg: Error processing package linuxcnc-uspace (--install):
Dependency problems - leaving unconfigured
Processing triggers for libc-bin (2.41-7)...
Processing triggers for mailcap (3.74)...
Processing triggers for desktop-file-utils (0.28-1)...
Processing triggers for hicolor-icon-theme (0.18-2)...
Processing triggers for man-db (2.13.1-1)...
Processing triggers for shared-mime-info (2.4-5+b2)...
Errors occurred processing:
linuxcnc-uspace
dg@LinuxCNC:~/Downloads$ sudo apt install git
Try "apt --fix-broken install" to correct this.
Unmet Dependencies:
git: Depends on: liberror-perl but should not be installed
Depends on: git-man (> 1:2.47.2) but should not be installed
Depends on: git-man (< 1:2.47.2-.) but should not be installed
Recommends: Patch but should not be installed
linuxcnc-uspace: Depends on: py
  • snowgoer540
  • snowgoer540's Avatar
16 May 2025 21:43
Replied by snowgoer540 on topic Job not showing in position - 2.9.4 - v2.9-238.315
Category: Plasmac
Glad it got you going again!
The “lag” is due to the way internal MDI commands are dealt with, in conjunction with choosing a method that works well with the preview.
Always interesting to learn how people use the GUI. The feedback is good, helps drive feature updates, etc. (to the master branch, 2.9 is locked in from a QtPlasmaC standpoint).
IIRC, something was updated with G92 that made us completely disable it in the master branch. At any rate whatever the change was is eluding me, but it’s the reason G92 doesn’t behave as it used to for you. It isn’t anything we changed in QtPlasmaC.
The other way is the way to go anyhow.
Enjoy.
  • Roguish
  • Roguish's Avatar
16 May 2025 21:40
Replied by Roguish on topic QTDragon and DTG readout
Category: Qtvcp
Chris,, thanks.
but what is the MPG SCROLL thing ??
  • cmorley
  • cmorley
16 May 2025 21:16
Category: Qtvcp
No, not without a customization.
Displaying 16021 - 16035 out of 16106 results.
Time to create page: 0.396 seconds
