  • Todd Zuercher
  • Todd Zuercher's Avatar
03 Apr 2025 15:23
Replied by Todd Zuercher on topic What do you really get for a $350 desk top engraver ?
Category: Show Your Stuff
I think Andy is on the right path. I can't think of anything other than shaft misalignment that would cause a stepper motor shaft to snap like that.
  • PCW
  • PCW's Avatar
03 Apr 2025 14:59
PCIe - No parport registered at "0x " . This is not Always an error.Continuing.
Rather than a pop-up error message, it seems this would better be just a message
in the log, so if you are trying to debug a parallel port issue, you get notified, but you don't
have a constant nuisance alarm when things are OK.
  • Masiwood123
  • Masiwood123's Avatar
03 Apr 2025 14:44
Replied by Masiwood123 on topic bandit controller retrofit
feedback is a linear measuring scale for all axis, in case those remain, I can additionally take a card that would read them as an encoder
  • scotth
  • scotth
03 Apr 2025 14:43
Replied by scotth on topic ENCODER_RATIO function implementation.
The EGB would add or subtract pulses to the table for helical gears based on hob height, as well as handling hob and table speed.
  • Masiwood123
03 Apr 2025 14:41
I bought the strongest driver of 7A, I will try as soon as I find some time to connect the existing motor in a bipolar connection with higher voltage and lower amperage, so we will see, if one works I will buy two more drivers and I think the problem would be solved, the controller in that case 7i96s for example.
  • scotth
  • scotth
03 Apr 2025 14:29
The first CNC hob I worked with was a Pfauter PE 150 with an Allen Bradley 7300 and the Pfauter EGB (electronic gear box). 1983
  • ffffrf
  • ffffrf
03 Apr 2025 14:22
Using a servo as a spindle and positional axis - keep getting vague errors
cheapo 1kw servo motor
motor model A2M-80SV03230
driver S2SVD20
It works well and was generally easy to get running, atleast without the whole switching between c axis and turning
  • andypugh
  • andypugh's Avatar
03 Apr 2025 13:17
The message is something that i introduced, and it means that the parport_pc kernel driver has not found the card. However that doesn't mean that the LinuxCNC driver won't work.
github.com/LinuxCNC/linuxcnc/commit/7bd5...dedfd986fb84f6a9c4a6
It's not easy to know what to do in this scenario. There needs to be some indication that there is not _necessarily_ a parport at the give address (but, also, there might be...)
  • andypugh
  • andypugh's Avatar
03 Apr 2025 13:02
Replied by andypugh on topic Home location on CNC Lathe
Category: Basic Configuration
You could set up a prox or mechanical switch in the saddle to detect the tailstock and abort homing. This might be easier to wire than a dedicated tailstock detector, given that you are probably already running a bunch of wires to the saddle.
My own lathe has resolvers, and I modified the Mesa resolver driver to work in conjunction with the LinuxCNC .var file to give me absolute homing (most of the time) That means that most of the time my lathe homes without moving at all.
wiki.linuxcnc.org/cgi-bin/wiki.pl?Psuedo-Absolute_Encoders
  • andypugh
  • andypugh's Avatar
03 Apr 2025 12:56
Why do I get the feeling this is not the first time you've looked at failed (or suspect) industrial components?  Spend any time involved with, or doing, NDT/NDE?
I spent 12 years at Sheffield University doing postdoctoral research on cracks of various sorts.
  • spumco
  • spumco
03 Apr 2025 12:10
The moment is greater further from the shaft end, and a ball bearing isn't particulary stiff against torsion. Also the step that the bearing butts against, if machined poorly, might be a stress raiser.
  • andypugh
  • andypugh's Avatar
03 Apr 2025 12:07
Replied by andypugh on topic ENCODER_RATIO function implementation.
I have never found a use for encoder_ratio, at least partly because it relies on software-counting of the A and B phases.
If you are using a Mesa card then encoder_ratio won't help you.
But gear hobbing is nevetheless very possible. I do it regularly. I invented the idea of electronically geared hobbing, but I probably didn't invent it first :-)
wiki.linuxcnc.org/cgi-bin/wiki.pl?Hobbing
Note that due to a problem with a certificate on the server that hosts the Wiki, https won't work. This means that to download the linked zip file you will need to copy the URL, edit out the "s" in "https" and then paste the URL back into the address bar. Sorry about this.
  • spumco
  • spumco
03 Apr 2025 12:03
Replied by spumco on topic Home location on CNC Lathe
How do other people deal with that ?
Most CNC lathes I've seen with a moveable tailstock I've seen fall in to the category of 'Operator Beware'.  Z-home is set to max positive travel, minus the tailstock length and bit for clearance.  If you've got the tailstock anywhere else and locked down you're in trouble.
I've seen one lathe - can't remember the brand - with a tailstock-in-place switch.  If the tailstock was parked in the usual location (right end of bed) the machine homed normally.  If the tailstock was not present at the switch homing wasn't permitted - an operator message "reset tailstock" was flashed on the screen.
I don't know what the procedure was if the tailstock were removed completely for long jobs... maybe an OEM-approved switch bypass device that indicates to the control the new do-not-exceed Z-pos value?
Cooking up a switch-based homing interlock shouldn't be too hard, but I'm not sure exactly how to go about it without writing a custom homing sequence.
  • andypugh
  • andypugh's Avatar
03 Apr 2025 11:51
Wouldn't misalignment between motor and driven component tend to break outboard of the bearing?  That's assuming the bearing didn't come with lots of negative preload from the factory, of course.
This is one of those cases where, given the final result, I can think of a plausible explanation. But that would be true in either case...
Displaying 17281 - 17295 out of 17647 results.
Time to create page: 0.562 seconds
