  • RushA
  • RushA
03 Apr 2025 05:55
Replied by RushA on topic How to access rt pins in user space
hi, thanks!
Is there any code or links to refer to?
  • RushA
  • RushA
03 Apr 2025 05:50
hi,here's another question. I want to read from and write to the module (for example the shared memory module in realtime space) through pins in user space.How can I solve the problem? Is there any code about this?
  • ffffrf
  • ffffrf
03 Apr 2025 05:45
Using a servo as a spindle and positional axis - keep getting vague errors
sadly so yes, although i cannot help but think there must be a simpler way to do this with mux, just somehow switch between position and velocity modes depending on an input
  • Cherna
  • Cherna
03 Apr 2025 04:37
Replied by Cherna on topic PCIe to ParPort - chipset PCI 60806A works?
I'll have this information for you tomorrow.
Thanks for the help.
  • unknown
  • unknown
03 Apr 2025 04:34
Replied by unknown on topic PCIe to ParPort - chipset PCI 60806A works?
if you can run
sudo lspci -vvnn > lspci.txt
and attach the lspci.txt file (photos are difficult to work with if you want a proper answer) and I can give some answers.
  • unknown
  • unknown
03 Apr 2025 04:29
PCIe - No parport registered at "0x " . This is not Always an error.Continuing.
Just gone 3pm here in Sydney.
No something interesting.
I worked on a little project using an FPGA dev board to run MESA's hostmot2 firmware. First attempt was based on the 7c81 using either SPI (raspberry pi) or EPP (best on motherboard based parallel ports). The issue with the board I used is that the EEPROM need to be changed and the headers were already soldered on.
That same hardware can also be used with the LinuxcncRIO project.
Another project I had a go at was modding the 7i90 Smart serial firmware to support 4 encoders to run on a dev board.
For my latest I've grabbed a different dev board (eeprom is correct size & bought with the headers unslodered, but this time I'll be trying a Ethernet interface, chip is same as use on the Mesa products, so no having to rewrite a driver, which requires a couple of steps, first being working out the instructions of the softcore, working how the driver talks to the chip and then how it integrates with the rest.
Some pics, 2x17 ports from breakout boards (mesa 25 pin daughter boards can be used as well) and 4 extra pins for 2 smart serial ports or extra I\O.
First off is the FPGA from aliexpress:
The Ethernet board, this is experiment only, the FPGA board sits on top, disregard the type of 2x25 headers they can be changed to suit. Should have the boards in a couple of weeks.
One of the daughter boards from the orignal project.
  • Cherna
  • Cherna
03 Apr 2025 04:25
My worry was that I was missing something that led other (more knowledgeable people) to mark this chipset as not working with LinuxCNC, but as you said if it works, it works.
Hopefully this post helps someone in my same situation in the future.
Thanks a lot for your answer.
03 Apr 2025 04:18
Recruitment of a consultant for Linux CNC using a Mesa 7i97t board
forum.linuxcnc.org/10-advanced-configura...to-example-mesa-7i77
The same procedure and tuning is valid for 7i97T.
Especially mind the wiring of e-stop and drive enable, those can not be skipped.
First you have to get the drives running correctly, with no Mesa and no LinuxCNC. This i can not help with, the rest is quite easy, just follow the above and post here whenever you bump into something strange.
03 Apr 2025 04:11
  • unknown
  • unknown
03 Apr 2025 04:11
OK.
The Linux Kernel loads drivers based on the PCI ID, there's nothing special about it. If it sees a particular PCI ID it loads the driver that matches.
So the reason lInux will load the parport_serial is because that's what the card is reporting.
For Tommy, I replied with what might be the issue directly under your post. But without the PCI ID, end manufactures can change this usually via an eeprom or maybe some other method, there's not enough info to go on.
  • dlc mnl
  • dlc mnl
03 Apr 2025 04:05
Hello, I would like to see if anyone can help me with the Linux CNC configuration of a 7i97t Mesa board and a 7i75 board with Chinese T3D servo drivers. I would like to recruit an advisor who could help me and teach me with the configuration. Payment method to be agreed upon.
03 Apr 2025 04:05
Replied by tommylight on topic PCIe to ParPort - chipset PCI 60806A works?
If it works, do not change it.
Any card has a chance of randomly stopping working, things break/die/release the magic smoke, etc, but that is not a reason for changing a perfectly working card.
  • ContinenteCNC
  • ContinenteCNC's Avatar
03 Apr 2025 04:01
hmm, interesting finding.
Why does it use parport_serial if it is only a single parallel port with no serial ports? Or it has nothing to do?
What do you suggest as next step? Update linuxcnc to 2.9 or just the kernel?
(By the way, I am not an Aussie, I am Brazilian... Just 180 degrees apart xD)
Displaying 17311 - 17325 out of 17649 results.
Time to create page: 1.846 seconds
