  • dbtayl
  • dbtayl
19 Nov 2024 22:57
Replied by dbtayl on topic Metal way covers
Metal way covers
Category: Show Your Stuff
Take your pick- Amazon, eBay, Ali Express- just search for "accordion way cover", "accordion bellow", etc. and you'll find it. Random examples I'm not specifically suggesting:
www.amazon.com/uxcell-Machine-Rubber-Acc...Pleats/dp/B0087ZCY86
www.ebay.com/itm/315803295816
  • PCW
  • PCW's Avatar
19 Nov 2024 22:52
Replied by PCW on topic Configuring hardware jog buttons
Category: HAL
Also, not related to the jog question but you can avoid the debounce
by setting the "slow" parameter for the assosciated inmux  pins.
  • Sziggy_NC
  • Sziggy_NC
19 Nov 2024 22:34
Replied by Sziggy_NC on topic 7i97t Spindle has 0v or 10v
Sadly the choke didn't seem to change the behavior of the spindle. Maybe I am using the wrong style? It is salvage from some e-waste a few years back. I picked it of the few I have since the wire diameter was similar to the 20awg I was using to wire up the mesa card.  I'll attach a photo.
In an attempt to re-scale the spindle output, I was mapping out the actual speed vs the commanded speed. That was when I noticed some odd behavior. It has me wondering if I still have something wrong in the hal or ini.When commanding a speed below around 500 rpm, the spindle runs in reverse. Ex. M3 S100 runs the spindle counter clock wise at 370 rpm. When that command should have run the spindle clock wise at 100 rpm. After I start commanding S500 and up, the spindle resumes the correct rotation. Although, M3 S500 results in 20 rpm. Every commanded increase in rpm after that point is very nearly equal to actual rpm. Ex. Increasing S500 to S600 results in a reported speed of 120 rpm.
The spindle driver board has a wire for both forward and reverse. I control this with a SPDT relay. I checked this relay just in case, but it was not active while going in reverse below M3S500. When an M4 is commanded the relay does become active as it should. M4 commands behave identically to M3, but reversed. Commanded speeds below S500 are clock wise, and speeds at or above S500 are counter clock wise.
When I say actual rpm, this is read from showhal on spindle-vel-cmd-rpm. I have verified it in two ways, 1) the spindle driver has a tachometer on it, 2) I counted the rotations in one minute while the spindle was running at about 20-22 rpm.
My spindle PID are all set to 0. Is this normal for an ac spindle servo?
I will re-attach the hal & ini
  • digiex_chris
  • digiex_chris
19 Nov 2024 21:41
Flex Gui forces machine into Manual mode when any other process switches to MDI
Category: Other User Interfaces
I gave it a try today, and with my example script it's behaving better, but if you speed the loop up, it still shows up. This is with the following loop:
while True:
        print("Loop")
        print_mode()
        c.mode(linuxcnc.MODE_MDI)
        c.wait_complete()
        print_mode()
        c.mdi("G1 X0.1 F1000")
        c.wait_complete()
        print_mode()
        c.mdi("G1 X0.2 F1000")
        c.wait_complete()
        print_mode()
        time.sleep(0.1)
as you can see below, there is still something checking and reverting back to manual mode in between commands.
I have a branch set away with a sim config for my actual project I'm setting up that this bug reproduces with the actual UI I've been playing with, if if that helps (VERY work in progress :D ): github.com/digiexchris/qtpyvcp_grinder_t...ee/flexhal-mdi-issue
should be able to cd into rpi_grinder_touch and execute linuxcnc ./rpi_grinder_touch.ini and it should run it for you. Just take it out of estop, power on, and hit run. homing is optional to duplicate the issue. the script that's running as a loadusr module is in grinder-backend.py
Loop
Current mode: Manual
Current mode: MDI
Current mode: MDI
Loop
Current mode: MDI
Current mode: MDI
Current mode: MDI
Loop
Current mode: MDI
Current mode: MDI
Loop
Current mode: MDI
Current mode: MDI
Current mode: MDI
Loop
Current mode: MDI
Current mode: MDI
Must be in MDI mode to issue MDI command
Loop
Current mode: MDI
Current mode: MDI
Current mode: MDI
Loop
Current mode: MDI
Current mode: MDI
Loop
Current mode: MDI
Current mode: MDI
Current mode: MDI
Loop
Current mode: MDI
Current mode: MDI
Loop
Current mode: MDI
Current mode: MDI
Current mode: MDI
Loop
Current mode: MDI
Current mode: MDI
Loop
Current mode: MDI
Current mode: MDI
Current mode: MDI
Loop
Current mode: MDI
  • Grotius
  • Grotius's Avatar
19 Nov 2024 21:30
Replied by Grotius on topic Ethercat auto configurator.
Category: EtherCAT
Maybe we can add a node configurator.
This then can be used to simulate the ethercat devices, by adding controls, like buttons, etc. for interaction.
And eventually it could be used as a plc controller, when adding logic just as classicladder.
It seems beckhoff has twincat for linux, running on debian. But it is not open source.
Did they write the ethercat master for linux themselfves?
They say in linux you can run multiple instances of twincat.
  • Unlogic
  • Unlogic
19 Nov 2024 21:29
Replied by Unlogic on topic Configuring hardware jog buttons
Category: HAL
Make sure that you have a jog speed set, for example:
setp halui.axis.jog-speed 100
  • gardenweazel
  • gardenweazel's Avatar
19 Nov 2024 21:18 - 19 Nov 2024 21:19
Replied by gardenweazel on topic Inconsistent values from Versaprobe
Category: Qtvcp
Posting some additional debug details in anticipation of getting some resolution.
This is from a single job that I ran yesterday. Exact same job run 3 times, as you can see there were 2 failures
and finally on the third try I was successful.
The second FAIL and the PASS are nearly identical.
Please chime in if you have any clues. I am using the subroutine from qt_auto_probe_tool.ngc
  • viesturs.lacis
  • viesturs.lacis
19 Nov 2024 21:05 - 19 Nov 2024 21:05
Replied by viesturs.lacis on topic Yaskawa incremental encoder and Mesa 7i48
Category: Driver Boards
Aciera do you have any idea if there is more detailed description available about the C channel patterns of Yaskawa encoders?
  • floris
  • floris
19 Nov 2024 20:58
Best version for Parport machine and how to install
Category: Installing LinuxCNC
Hey guys,
I first installed Linuxcnc 2.7 a few years ago just to have a look at it. Recently I finished the mechanics of my machine, which has dual Y steppers.
I found a good tutorial to add the second stepper in the HAL and INI, but I found out that 2.7 is quite old and the method described in the tutorial wouldn't work. I decided to do a fresh install of 2.9 per download page (LinuxCNC 2.9.3 Debian 12 Bookworm PREEMPT-RT ISO).
I did a latency test and got terrible results (120000ns while I got 15000ns on the previous install of 2.7). From what I can gather, this is due to the PREEMPT kernel. I can see a pinned post on the forum for "RTAI deb", but I have no idea how I would install this on my machine since it is not connected to the internet.
As you may be able to tell, I'm a bit out of my depth here. What I'm looking for is idiotproof instructions on how I can get 2.9 with the RTAI kernel on my PC, preferrably in a way that is as simple as installing the ISO.
Hope you guys can help.
  • Axolito
  • Axolito's Avatar
19 Nov 2024 20:26 - 19 Nov 2024 20:31
Mecanumeric / Charlyrobot retrofit was created by Axolito
HelloI've been working for a while on retrofitting a “small” Mecanumeric / Charlyrobot milling machine (the second one is the real manufacturer but they merged) at my work.
I work in a fablab in a high school in France. This machine has been at the school for many years, and originally ran on a Windows XP PC with specific software.The motherboard in the machine had a number of problems which I won't go into now, including a slightly scratched tool sensor.....I suggested modernizing it, making it more upgradeable and easier to repair.
So I had a few items purchased, including drivers and a Mesa 7i96S card. I reverse-engineered the wiring and managed to implement it pretty much as I wanted. The control panel was made from MDF using the big CNC machine, an Arduino using the great Arduino Connector project and a salvaged industrial touchscreen. I've added the ability for LinuxCNC to detect the opening of the cover to prevent the execution of a program. And to deal with minor oversights, I've added a relay to activate and deactivate the vacuum cleaner.
Finally, I've designed a small, unpretentious tool probe (which I can show if you're interested) with a microswitch and 3D printing.
More photos coming soon
  • scotta
  • scotta's Avatar
19 Nov 2024 20:03
Does this look ok to get the encoder PV1 counting? PV1 should be the MPG socket. I don't know if I have a hardware issue or code issue. Also does the nvmpg.so need to be compiled first? I'm using an adum1200 to bypass the opticouplers. PV1 does not count when I move the encoder in Halshow
Hi, are you using the nvmpg or just an encoder?
The nvmpg component does the communication for the screen updates and button press receptions. The nvmpg LinuxCNC component needs to be enable in the ini file to use the remora-nv-mpg.hal file. Encoder pulse counting is done in software on the LinuxCNC side. So slow speed counting.
Encoders require the QDC module to be enabled in the config.txt file.
eg  Remora-RT1052-cpp/LinuxCNC/ec500-rt1052-DMA-ENC.txt at main · scottalford75/Remora-RT1052-cpp
Example encoder hal file
Remora-RT1052-cpp/LinuxCNC/remora-ec500-DMA_closed_loop/remora-ec500_closed_loop.hal at main · scottalford75/Remora-RT1052-cpp
  • Axolito
  • Axolito's Avatar
19 Nov 2024 19:54
Replied by Axolito on topic Flex GUI translation
That's very kind, thank you.
  • royka
  • royka
19 Nov 2024 19:23
Replied by royka on topic Real-Time Kernel with Orange Pi 4 LTS
Check with "ls -l /boot" if all links are correct. With Armbian for example the Image file is a link to the used kernel. To relink you can use "sudo ln -sf your-rt-kernel Image" and also check for the uinitrd link and to use the right dtb for that kernel version.
I saw that it's a rk3399 indeed, but here it also worked great for a s912 sbc so it might be a good base for yours too.
  • JT
  • JT's Avatar
19 Nov 2024 18:32
Replied by JT on topic Flex GUI translation
It's only those two buttons and I already have a fix in my mind as soon as work is over I'll implement that.
JT
  • CopperHead
  • CopperHead
19 Nov 2024 18:23
Replied by CopperHead on topic Defaults in QTplasmac
Category: Plasmac
Ok never mind i did have a very small blow out I didn't see in the tip. so that would account for the raised HC look
Displaying 17521 - 17535 out of 24295 results.
Time to create page: 0.474 seconds
