  • da_kernel@hotmail.com
09 Mar 2025 20:37
Asus Motherboard + AMD5600gt was created by da_kernel@hotmail.com
Category: PathPilot
Hey guys, I'm trying to put my previous PC to use on my PCNC1100 S3 - pathpilot - 7i92t.  I get through the installation and it does freeze after I select my machine.  I have verified that the 7i92t does work as I borrowed another PC to test the 7i92t + PCNC1100 for functionality.  So I think it's some issue with my PC setup.
I get these errors during startup after the BIOS and before pathpilot:
Mother Board:  Asus a520M
CPU: AMD 5600gt
core perfctr but no constraints; unknown hardware
kobject: can not set name properly!
Any recommendations on bios settings or something to clear this?
thanks
  • scotta
  • scotta's Avatar
09 Mar 2025 19:45
Replied by scotta on topic Remora - Panucatt Re-Arm
Remora is still in active development but support for the LPC1768 is now legacy only. STM32 and RT1052 MCUs are now the go to with more boards available.
  • cakeslob
  • cakeslob
09 Mar 2025 15:59
Custom "MESA 7c81 Clone" PCB featuring a Raspberry Pi Compute Module 5
Category: Driver Boards
The serial steppers are nice because they are easy to setup and they are also very quiet. I dont know if there is an fpga firmware for it thought. The SPI ones, someone has done a custom firmware to work with those.
What is W13 doing? Is it just for swapping between the usb or the green connector?
Consider adding a jumper that can disconnect power to the FPGA or separate the 5v rail between FPGA and RPi5. I found it convenient having a separate jumper for that, incase you needed to either separate the power between the 2, or if you need to reset the MCU/FPGA, you dont need to turn off the RPi
When you are done will you post the design on that easyeda website so I can clone it to modify it? Im also hesitant about a 1 board thing, but I wanted to make something with a swappable MCU/FPGA , and the formfactor looks pretty decent sized.
  • PCW
  • PCW's Avatar
09 Mar 2025 14:54
Replied by PCW on topic Joint Error After large rotary move
Can you reduce the encoder scale? If not, probably best long term solution
would be for  the encoder driver to use 64 bit intermediate calculations.
I can take a look at this.
  • Lcvette
  • Lcvette's Avatar
09 Mar 2025 14:22
Move Machine to inside soft limits when Probe Basic on
Category: QtPyVCP
nice! please post up when its done, that is an interesting machine, look robust for a bench mill/
  • Niklas
  • Niklas
09 Mar 2025 11:47 - 09 Mar 2025 12:00
Thank you guys for the interest and the suggestions! I will try to respond to a few of them here:
"I have occasionally thought that there should be a niche for a similar board, but with on-board stepper drivers (Trinamic or some other serially-controlled driver)
That would, of course, need a dedicated HAL driver, but those can be surprisingly straightforward."
I was actually planing on designing a seperate IO Board featuring the Trinamic 5160 Drivers, as they would allow me to run high current stepper motors. They come with UART and SPI interface functionality but I haven't really seen an advantage in interfacing them serially. Maybe someone has a good argument as to why it would be worth it to go through the integration troubles?
"I like having the boards seperate, just in case my butter fingers cause one the voltage translation chips to blow a smoke valve and damage the PCB."
That was my thought process as well. I'm a little hesitant to put everything on one big PCB, as i feel like that would make errors more catastrophic. I also like the modularity of having seperate PCBs, especially in these early prototyping stages. I did actually bring the JTAG out, but realize that better labeling was neccesary, which I've since added.
"I am liking the look of this board. Did you do this in easyeda?
Suggestion, add the rpi 40pin header. Aside from being able to add stuff rpi side, I find it valuable for debugging the MCU/FPGA side of the board using a regular rpi without having to keep removing a cm module and you can use it as a backup incase you damage the 100pin hirose connectors or theres another RPi/chip shortage"
Yes, I did do this in EasyEDA. I started the project with EasyEDA becuase I foud the integration with the JLCPCB services appealing.
Including the 40pin Header is a great idea, which I will definitly add. Unfortunatly that will require major rerouting. Before rerouting everything I will continue collecting and thinking about additions/optimizations. That way I'll hopefully save money on design itereations.
I'd love to here if you guys have any other sugestions. The design philosophy behind this board is to make it the Compute Module 5 version of the Mesa Electronics 7c81, and I will probably finish this project making exactly that but I'm also open to brainstorming other ideas for potential future projects.
Thank you everybody!
  • WKS-3D
  • WKS-3D's Avatar
09 Mar 2025 11:01 - 09 Mar 2025 11:05
Ist Linuxcnc kompatibel mit anderen CNC-Sprachen?
Category: Deutsch
Die Siemens und Heidenhain Steuerungen basieren auf Werkstatt orientierter Programmierung (WOP), im Gegensatz dazu die PAL-Programmierung.
LinuxCNC basiert auch auf PAL und hat sehr viel gemein mit Fanuc, aber eben nicht alles. Heidenhain oder Siemens Code kann man überhaupt nicht unter LinuxCNC laufen lassen.
"Pal ist die Sprache die in de rAusbildung gelehrt wird und die auch die Basis für die Sinumeric ist."
Ja, die ganz alten Siemens Steuerungen, aber die neueren (auch schon relativ lange) nicht.
  • jst
  • jst
09 Mar 2025 10:00
I'm also designed a mesa clone for a Raspberry Pi, currently in the process of testing everything.
Except for the reversed Sserial Pinout it looks like I got everything right.
You can take a look at my schematic for reference: github.com/jstjst/stmbl-fpga-master/blob...tmbl-fpga-master.pdf
Be careful the SPI In Out labels in the 7c81 schematic are reversed compared to the ucf file. Luckily I could fix that in the ucf file.
I routed some signals under the fpga, I see no problem with it. But try to have no completely hidden tracks so you can fix them if you got some connections wrong. In my opinion one of the more important things is the placement of the decoupling caps.
There are some pitfalls with the whole (fpga) programming (especially when using the Ethernet host interface). But with some reading through the forum I got everything pieced together, including recompiling mesaflash and linuxcnc. So it is totally doable (for reference, this is my first deep dive into linuxcnc and mesa/hostmot2, only used the RPi GPIO interface before, didn't use/own a mesa card).
Big thanks to Peter for providing the schematics and all the information that is on the forum!
  • stefan63
  • stefan63's Avatar
09 Mar 2025 09:38
Mesa 7I92TM goes offline shortly after starting LinuxCNC
Have you had any time to give a Dell OptiPlex 7050 a rub yet?
It would nice to get some feedback and recomendations regarding eventual tweaking :0)
Kind regards/Stefan
  • Aciera
  • Aciera's Avatar
09 Mar 2025 09:13 - 09 Mar 2025 14:02
G10 L20 P1 doesnt work if the program is stopped and rerun
Category: G&M Codes
Can you reproduce this in one of the included simulation configs?
If yes then please provide a minimal gcode example (ie one that can actually be run when loaded) along with a clear description of when you are stopping the program and tell us what linuxcnc version you are using.
If you cannot reproduce this in a sim config then please also attach your zipped config folder.
As it is I cannot reproduce this on either 2.9 nor on master.
  • robh
  • robh
09 Mar 2025 08:25
Replied by robh on topic Joint Error After large rotary move
91 turns is possible very much so ,
this is just a simple small part so a complex job would very much be way over that turn number.
wrapping sounds right as number does a odd sign change in the feedback counts
  • aikiaviator
  • aikiaviator
09 Mar 2025 02:33
Category: QtPyVCP
Unfortunately not yet, but am looking to get this cataloged for others as I have completed quite a few 3d printed parts to help support the PM728VT machine to CNC.
As such this can help others move across more quickly.
I want to make sure there is a positive ending before releasing the build program, just to make sure others get to a realistic endpoint. :-)
Currently using a laptop, and seems to be Ok. But may need to get a miniPC to run it all so just incrementally addressing each issue.
  • 109jb
  • 109jb
09 Mar 2025 02:17
Replied by 109jb on topic Lathe spindle index only?
Category: Basic Configuration
For the cross slide I oredered a 12mm ballscrew. If I can find room I will mount the ball nut under the cross slide table. If not, the screw I bought is long enough that I could mount the ballscrew on the back side of the cross slide table.
I'll be going out of town for a couple weeks, but when I get back I think I will do some examining for the encoder situation.
I saw a video of somone doing threading on linuxCNC using a missing tooth scheme. I may look into this more when I bored in my hotel room next week.
Thanks again for the comments
09 Mar 2025 01:07
SL57D Stepper Drivers, unsure how to read driver timings.
Leave them at default 5000 till you have everything working properly, then you can decide if you need to mess with timings. Usually there is no need.
  • ccatlett1984
  • ccatlett1984
09 Mar 2025 01:02
Displaying 17686 - 17700 out of 18704 results.
Time to create page: 0.436 seconds
