  • NT4Boy
  • NT4Boy
01 Mar 2025 19:37
Replied by NT4Boy on topic HURCO KMB-1 Control Update
Category: Milling Machines
Peter,
Thank you. I can see the logic behind that, what I think was lost is the significance of the channel numbers and why I'd have to use the third channel for this card.
I think I see it like this. The sserial instruction is to the host card ie 0, (7i92, ) in my case. Plugged into which is a daughter, could be two of them, but only one (7i77) here, and that's therefore channel 1, and lastly, the smart serial card 7i73 that hangs off the 7i77must be channel 2
  • PabloSancez
  • PabloSancez
01 Mar 2025 19:37
Ethercat installation from repositories - how to step by step
Category: EtherCAT
I get it in version 2.9.4.
everything worked during the day, broke in the evening.
how can I fix this?
where to find "sticky threads"
  • PCW
  • PCW's Avatar
01 Mar 2025 18:55 - 01 Mar 2025 19:02
Replied by PCW on topic HURCO KMB-1 Control Update
The sserial_port_0 parameter sets the modes for sserial channels 0.N in
left to right order of channels so sserial_port_0=001xxxxx means set
sserial channel 0 -> mode 0
sserial channel 1 -> mode 0
sserial channel 2 -> mode 1
sserial channels 3..7 = x = disabled
The channels used in a a particular FPGA configuration can
be determined with mesaflash's --readhmid command
  • lwill
  • lwill's Avatar
01 Mar 2025 18:55
ESP32/S2/S3 LinuxCNC Controller (6 axis hardware step gen), USB plug-and-play
At the beginning of this post there was a demonstration using only USB Networking (No Ethernet).
Does this function still exist?
I was able to build and install to an ESP32-WROOM, but boardconfig keeps setting to "Wowki Simulator ESP32".
  • prokopcio
  • prokopcio's Avatar
01 Mar 2025 18:40
Laser Head Height Sensor – Looking for a Beta Tester
Category: Plasma & Laser
I suggest 20-70kHz (0-10mm) and 10kHz(or 0Hz) = collision
This is linuxcnc. We will not have collisions! :)
Maybe  collisions are 5 kHz and our rule is: if < 10 kHz, report a collision
in fact, anything below 20 kHz is a collision.
higher frequencies mean faster response, which is very important for collisions.
  • prokopcio
01 Mar 2025 18:34
hi blazini,
I also think that digital/serial transmission is a very good solution.
I have to think about it because the output that I have available in the sensor is an open drain output and it would require a simple converter but it is not a problem to add it. These are just a few basic elements to adapt to various interfaces such as RS485, RS422, RS232 or UART TTL.
I do not foresee standard protocols such as MODBUS etc. with bidirectional communication due to the too long time of exchanging transmission frames.
I do not want to use a high transmission speed so that the quality of the connectors and cables does not affect any possible distortions.
I want to transmit every 1ms only 4 bytes (start byte, 2 data bytes, crc) at a speed of 57600 but it is possible that I will change the assumptions.
Could you handle something like this?
If you have other ideas, they will be welcome
  • CopperHead
  • CopperHead
01 Mar 2025 18:06
Replied by CopperHead on topic Dreaming Question On Ohmic
Category: Plasmac
Ok. I wasnt sure if there might be a slight reading before touch. Couldn't a hall sensor be used to read height above material? I know when i was in the concrete industry we had laser sensors that would measure distance and turn off feed belts when a hopper was at a certain level of concrete.
  • rodw
  • rodw's Avatar
01 Mar 2025 17:58
Category: EtherCAT
Their key changed a while ago. You should not get this with 2.9.4
Otherwise there is a script on another sticky threads to fix this.
  • rodw
  • rodw's Avatar
01 Mar 2025 17:54
Replied by rodw on topic Dreaming Question On Ohmic
Category: Plasmac
Ya that's why I said or Better yet. I'm sure the fibre laser is using some form of ohmic as it doesn't touch the sheet I'm just not familiar enough with ohmic to know if it begins to receive a partial signal before it even makes contact. Ill look to see if i can find this opencv info
With ohmic, touching the surface acts like a switch so its either on or off.
  • rodw
  • rodw's Avatar
01 Mar 2025 17:50 - 01 Mar 2025 17:51
Category: Plasmac
I don't think so. The laser heads have capacitive height sensing built into them so they can read cut height without ever needing to probe and touch the surface.
Ohmic sensing uses  a physical probe and does not give that continuous height reading.
  • CopperHead
  • CopperHead
01 Mar 2025 17:42
Category: Plasmac
  • PabloSancez
  • PabloSancez
01 Mar 2025 17:40
Category: EtherCAT
hello! I used to successfully use the "sudo apt install linuxcnc-ethercat" construct and it worked well, but now something is broken... it is impossible to establish a connection with the server...
  • RDA
  • RDA
01 Mar 2025 17:30
Replied by RDA on topic Dreaming Question On Ohmic
Category: Plasmac
I don't think dragging the torch on the plate is a good way in achieving the shape of the plate.
I think I saw someone making this with opencv. I would assume it’s way faster and you can see also “gaps” from example already cut parts.
  • NT4Boy
  • NT4Boy
01 Mar 2025 17:11 - 01 Mar 2025 17:12
sserial_port_0=001xxxxx"  works for me
Maybe the third position is the third card?
Anyway, another step on the journey.
  • machinedude
  • machinedude's Avatar
01 Mar 2025 17:07
Replied by machinedude on topic Black Friday Deal got me :)
i guessing the 1-3 m/m is m/min? metric conversions between units is not exactly my thing :) but if that is the case 120ipm is the high side. so it looks like things move pretty slow. 1 inch tube would probably be on the small side and spin the fastest so that's around 38rpm give or take.
Displaying 18226 - 18240 out of 18761 results.
Time to create page: 0.394 seconds
