  • JT
  • JT's Avatar
16 Feb 2025 12:04
Manual homing does not move on any axis
What version of LinuxCNC are you using? That ini file is quite different than what the 2.9 version stepconf wizard generates. I see [AXIS_0] which should be [JOINT_0] and no [AXIS_X] section as a start.
JT
  • tftmarco0
  • tftmarco0's Avatar
16 Feb 2025 12:00
Tried every net solution for days to install linuxcnc
Category: Installing LinuxCNC
My USB hard drive is much newer and I know it is good, so I am trying everything I can think of to get linuxcnc on this system. The "boot loader" I believe is in the ISO with everything else it needs to install and I did load it onto both internal and external USB drives. I did try to sign up to the Debian forum, but got the violin questions backwards, now they think I am a robot AI and won't let me join for a month.
  • Hakan
  • Hakan
16 Feb 2025 11:56 - 16 Feb 2025 11:57
EtherCAT IO and frequency counter for plasma cutter
Category: Show Your Stuff
No, not internal homing but I did get the following error issue when starting up.
I reckon it is the encoders that aren't starting at zero. At least when they have been running and restart QtPlasmaC, linuxcnc expects pos-fb to be zero, but the motors are where they are which is not zero usually. Also when the motors are enabled they move slightly.
I did two things for that
1. Zero the encoder just before starting by adding a startup command
#! /bin/bash
ethercat -p 0 download 0x2010 0 1
ethercat -p 1 download 0x2010 0 1
linuxcnc QtPlasma.ini
No encoder feedback on Z.
2. During the first five seconds after "machine on" there is a much larger following error limit, then it goes down to standard following error limit.
Used the timedelay and the ini component for that.
  • aikiaviator
  • aikiaviator
16 Feb 2025 11:53
Replied by aikiaviator on topic MESA 7i96S and Input config
Category: Basic Configuration
Hi Rodw,
Sorry, did not quite understand.
So to clarify, you are saying just pin to input as per the others and set to Invert and this will take care of the "non-default (i.e. NO)" position of NC? IN other words, it will set its default position to ON, whereas all the others are set to OFF. Is this correct?
Separately, is there any need to put a resistor in line as I have seen elsewhere when talking about using a alternate.
Is there anything I have missed?
  • tftmarco0
16 Feb 2025 11:46
"HDD? Perhaps its a legacy device" I think it is a legacy device with “UEFI: IPv4 Realtek PCIe FE family controller” and “UEFI: IPv6 Realtek PCIe FE family controller” on it somehow. I did reformat it a few times during the partitioning set up. Not sure how "Realtek" keeps coming back unless it is hiding somewhere else or remaining after reformatting.
  • tftmarco0
16 Feb 2025 11:35
After Disable secure boot and enable legacy, I got a new error screen with similar message, about not finding the the boot disk. The USB drive is good.
  • rodw
  • rodw's Avatar
16 Feb 2025 11:31
The top left one.
Netinst CD image for AMD64
  • tftmarco0
16 Feb 2025 11:22
What image or installer at
"www.debian.org/devel/debian-installer/" should I try? Best fit for my system?
  • Lcvette
  • Lcvette's Avatar
16 Feb 2025 11:20
Replied by Lcvette on topic Losing some values after PB restart
Category: QtPyVCP
You are on a very old version, chances are you have the wrong subroutines for the version you are on. Update to the latest stable version to resolve.
  • ytiuqibu
  • ytiuqibu
16 Feb 2025 11:20
Manual homing does not move on any axis was created by ytiuqibu
Have just completed a rebuild and rewire of our shop built CNC router.
Rebuild required, amongst other things, a replacement of breakout board which is now a cheap 5-axis parallel port board.
Switches on either end of each axis are wired, in series, to a separate input.
Using Step Config all axes pass test movement and jogging appears fine on all axes.
Switches on all axes stop motion as expected and at present no spurious joint errors occur during jogging.
If I run an aircut using a "no limits" config file motion seems to be fine.
The problem comes when I attempt to manually home any axis using a config file with "min limit + home" configuration (actually most other configs I have tried do the same) - pressing the home  key appears to engage the axis motor (I can hear iy humming) but there is no motion.
I attach the ini and hal files for the current config but I am unable to determine if there is a software issue causing this.
Any advice would be appreciated.
  • rodw
  • rodw's Avatar
16 Feb 2025 11:20
Very cool, Are you using internal homing and limits on the drives?
I finally worked on a homing component for the ECT60 over the weekend but have not got as far as connecting up a hal file to it. I ran out of energy!
I decided to go back to basics and control the homing using the Ethercat pins direct. In fact I added a bunch of pins because I did some work previously before the current homecomp was released. I'm sure there are a bunch that need deleting once I get it working. Long term I'd like to get rid of the cia402 component. I'm not sure if I can do that in a home comp.
Have a look. any help appreciated
github.com/rodw-au/cia402_homecomp
  • tftmarco0
16 Feb 2025 11:17
I did try "Disable secure boot, enable legacy" options. I think that may have been the default setting, but I will try anything a few more times just incase it works this time. The internal hard drive was the first thing I tried to install to. but I started using the USB HD because it is newer and I new it was in good shape, also just to try another drive.
  • tftmarco0
16 Feb 2025 11:09
I will try to list all the sudos and the responses I tried. I gave up on trying to solve the lost install components that were suppose to be in the repositories.
  • IB_CnC
  • IB_CnC
16 Feb 2025 11:08
Replied by IB_CnC on topic Losing some values after PB restart
Category: QtPyVCP
I ran the update but it didn't solve the issue.
Strange thing is, first I was losing all values related to probing and tool setter.
Now my spindle zero is getting saved, but for example the Fast probe FR and Slow Probe FR aren't stored for some reason.
Any ideas?
  • rodw
  • rodw's Avatar
16 Feb 2025 11:04
Disable secure boot, probably enable legacy support. Where is your HDD? Perhaps its a legacy device.
Also, let Linux choose the partition type during installation. Its probably EXT4
Displaying 18751 - 18765 out of 19422 results.
Time to create page: 0.374 seconds
