  • unknown
  • unknown
13 Feb 2025 20:14
Replied by unknown on topic Raspi 5 SPI setup
Raspi 5 SPI setup
That is fine, as long as there are entries under /dev everything is fine.
  • scotta
  • scotta's Avatar
13 Feb 2025 20:06
I deleted xhc-whb04b-6.hal still an error
I no longer have the problem of " MOTION: num_joints is 33, must be between 1 and 16"
I post you the .ini and .hal files in
File Name: NVEM_2025-02-13.hal
File Size:4 KB
File Name: NVEM_2025-02-13.ini
File Size:3 KB
LINUXCNC - 2.9.0~pre1+git20230208.f1270d6ed7
Machine configuration directory is '/home/manu/linuxcnc/configs/NVEM'
Machine configuration file is 'NVEM.ini'
INIFILE=/home/manu/linuxcnc/configs/NVEM/NVEM.ini
VERSION=1.1
PARAMETER_FILE=linuxcnc.var
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=halui
DISPLAY=qtvcp qtplasmac
COORDINATES=X Y Z
KINEMATICS=trivkins coordinates=XYZ
Starting LinuxCNC...
Found file(REL): ./NVEM.hal
Debug file information:
Note: Using POSIX realtime
motmod: already exists
./NVEM.hal:6: waitpid failed /usr/bin/rtapi_app motmod
./NVEM.hal:6: /usr/bin/rtapi_app exited without becoming ready
./NVEM.hal:6: insmod for motmod failed, returned -1
8403
Stopping realtime threads
Unloading hal components
The error gives a hint - motmod: already exists
Looks like you are loading it twice in your hal file. Try removing the 2nd line. From above EMCMOT=motmodloadrt [KINS]KINEMATICS
loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD #num_joints=[KINS]JOINTS[TRAJ]SPINDLES
loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[KINS]JOINTS num_spindles=[TRAJ]SPINDLES
  • scotta
  • scotta's Avatar
13 Feb 2025 19:59
Im confused --
RPI5 - linuxcnc 2.9.2 (from iso on linuxcnc download page)  I get same results on linux on a x86 system
I have a Novusun V5 that I loaded with ....Remora-RT1052-cpp/blob/main/Firmware/remora-rt1052-3.1.3.bin
I've run halcompile on remora-nv in Remora-NVEM-main/LinuxCNC/Components/Remora-nv
i can ping 10.10.10.10
I can tfpt put the python processed config.txt ...  I cant load tftpy for some reason so save & use the file created in /tmp
using the remora-nvem-basic when I take it out of E-Stop I get
Bad payload = 0
any suggestions
thanks
Les
For the RT1052 use the remora-eth-3.0 component that is included in that repo.
Remora-RT1052-cpp/LinuxCNC/components/Remora-eth at main · scottalford75/Remora-RT1052-cpp · GitHub
  • COFHAL
  • COFHAL
13 Feb 2025 19:55
Replied by COFHAL on topic caxis.comp status
caxis.comp status
The c-axis component does not have, as orient does, a pin to indicate that it has reached the commanded position. I need to know when the spindle is in position in order to activate an output. Any idea how to do this?
  • Traken
  • Traken
13 Feb 2025 19:51 - 13 Feb 2025 20:05
Servo Oscillation Issue at ±6.6V 5i25 + 7i77, Analog Control
Category: Basic Configuration
P I went down to 10 and it was still the same, I don't know if it can be called oscillation, maybe I called it wrong, the axis accelerates and when it reaches a speed above 8.3 m/min there is a loud sound as if the servo lost its position and was trying to make up for it. Should I record a video or halscope? What pins should halscope show when moving? I will add that I made a mistake with 3.3V, it happens at 6.6 V because I have a 2:1 screw servo ratio
  • Aciera
  • Aciera's Avatar
13 Feb 2025 19:48
Replied by Aciera on topic scurve trajectory planner
Maybe you guy's can also verify the output.
What would be the quickest way to get this installed for testing things?
  • Aciera
  • Aciera's Avatar
13 Feb 2025 19:43 - 13 Feb 2025 19:44
Replied by Aciera on topic Manual Tool Change
Manual Tool Change
Category: HAL
Not sure if this helps but 'hal_manualtoolchange.py' is a userspace hal component that needs its pins connected to iocontrol in hal so it can create the popups when a change is requested and pass the information on to iocontrol when the change is completed:
net tool-change iocontrol.0.tool-change => hal_manualtoolchange.change
net tool-changed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
  • frosted_jono
  • frosted_jono
13 Feb 2025 19:43
Replied by frosted_jono on topic Bad character U.
Bad character U.
Category: AXIS
I did read about the incremental moves for X and Y, but seems like that doesn't work for the lathe I am using.
Interesting idea about the Fanuc.
  • frosted_jono
  • frosted_jono
13 Feb 2025 19:41
Bad character U.
Category: AXIS
Yes this has fixed it! Thanks again.
  • Thayloreing
  • Thayloreing
13 Feb 2025 19:38 - 17 Feb 2025 00:52
help with guidance spindle was created by Thayloreing
I configured the spindle orientation with m19, it worked well, but I have a problem that even though I set the same degree every time, it finds different positions of the spindle, for example I give m19r0 it finds a point and stops, but I do the same command again and it doesn't find the same point it goes to another point and stops, in other words it keeps changing the degree 0 of place, sometimes it does this several times in the same place, out of nowhere it goes to another point and if I do it a few more times it stays there. At this point, out of nowhere he changes the point again, can you help?
  • PCW
  • PCW's Avatar
13 Feb 2025 19:32
How low did you adjust P?
 What is the oscillation frequency?
  • COFHAL
  • COFHAL
13 Feb 2025 19:21
Using Spindle and Axis C commands simultaneously
Could you share with me your configuration to use the servo that controls the spindle and also to use it with the C axis?
  • Traken
  • Traken
13 Feb 2025 19:16
Lowering P does nothing further, at this point oscillation occurs and F error is displayed. Pastes my configuration files for reference. I tried to power the 7i77 from a separate power supply, it didn't change anything.
File Name: Frezarka.hal
File Size:14 KB
File Name: Frezarka.ini
File Size:6 KB
  • Boogie
  • Boogie
13 Feb 2025 19:03 - 13 Feb 2025 19:05
Replied by Boogie on topic Potential All-in-One Single Board Computers
Right. Is there RB Pi oriented ISO image for Linuxcnc? I'm thinking about RB Pi5 + Mesa combo and QtPlasmaC. I can see RB Pi5 8GB RAM version is now USD 100.
  • beauxnez
  • beauxnez
13 Feb 2025 18:58 - 13 Feb 2025 19:06
File Size:4 KB
File Size:3 KB
VERSION=1.1
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=halui
COORDINATES=X Y Z
8403
Displaying 18976 - 18990 out of 19425 results.
Time to create page: 0.489 seconds
