11 Feb 2025 23:04
Replied by tommylight on topic Feedrate doesn't go above 1500 when running jobs.
Category: Basic Configuration
There is also the [TRAJ] section with speed limits
MAX_LINEAR_VELOCITY = 25.00
so raise that to probably 100 as in the display section.
11 Feb 2025 23:00
Replied by tommylight on topic SOLVED Cant run created stepwizard file
From your error report
Linux parallel port 0 not found
But i have no idea what should be instead of it for RPI as i do not use them.
  • baikal718
  • baikal718
11 Feb 2025 22:53
Hey, guys.
I've been trying to get my feedrate above 1500 and can't seem to accomplish that. I've gone through the accel and velocity tests in pcncconf and found the numbers that work with my machine. I can jog at high feedrates, but any jobs or mdi commands cap me at a lovely 1500 feedrate. Can somebody look over my ini and tell me what line I've missed? Is it a Qtdragon setting?
Thanks in advance
  • yoshimitsuspeed
  • yoshimitsuspeed
11 Feb 2025 22:51
Replied by yoshimitsuspeed on topic Rack Tool Changer
Rack Tool Changer
Category: QtPyVCP
Realizing now I might have misinterpreted the above posts as meaning a useable version was available.
If that's not the case I'm curious how long it will be till it might be ready?
Not trying to rush things if it's not done, just trying to get a gauge on ETA after realizing maybe it's not already in the repo or ready for release.
  • LCR
  • LCR
11 Feb 2025 22:31
Problems with Lichuan Ethercat servo drive
Category: EtherCAT
So the answer is
5.2.1 Initialization parameters
Set P02-31 to 1 to initialize the drive parameters, and the drive needs to be restarted after the setting is completed.
P02.31
0: No operation 1: Restore factory values (except P00/P01 group) 2: Clear fault records
So NO that does not tune the drive.
  • PCW
  • PCW's Avatar
11 Feb 2025 21:56 - 11 Feb 2025 21:57
Replied by PCW on topic PWM with a 7i96 and 7i85
7I96 + 7I85 configuration with step/dir index on 7I85
and PWM on STEP04 pin. DIR04 pin is left as GPIO
so it can be used as enable, direction, or whatever.
File Name: 7i96p1_7i85dsdi.zip
File Size:124 KB
  • LCR
  • LCR
11 Feb 2025 21:32
Category: EtherCAT
Hi RodW
Thanks so much for your effort.
What I have done so far to get my gantry moving is just tie the home markers for the 2 X axes together
net mydigitalinx lcec.0.0.mydigitalin => cia402.0.mydigitalin cia402.1.mydigitalin
I then modified the cia402.comp file to accommodate. I Use the index pulse from each axis for the final position. I am away from the machine until Friday, I will upload the files then.
I just loosen the coupler once homed to adjust the squareness. It seems to be working. (only need to adjust once)
  • yoshimitsuspeed
  • yoshimitsuspeed
11 Feb 2025 21:19
Rack Tool Changer
Category: QtPyVCP
Yes this is awesome. I hope to get around to setting it up in the next few days.
Is this on the stable repo now or should I switch to dev?
  • fziepiela
  • fziepiela
11 Feb 2025 21:19
SOLVED Cant run created stepwizard file was created by fziepiela
When following the video on setup, and using stepconfig wizard i get this error. Linuxcnc PI 5. When looking at my configurations and selecting my config there are not any details and i get the attached error.
Im a newbie, but do have Arduino experience. Please be gentle, lol..
  • Hakan
  • Hakan
11 Feb 2025 21:16
Replied by Hakan on topic Ethercat + step/dir signals
Category: EtherCAT
Judging from other builds, there will be lots of questions, so best to start your own thread and keep it there.
I'll look here daily I would say. You can also contact me by creating an issue on github. I'll get notified then, even if I happen to not be here for a while.
  • CADdy
  • CADdy's Avatar
11 Feb 2025 21:06
Replied by CADdy on topic Ethercat + step/dir signals
Category: EtherCAT
Hi Hakan,
you are right, stealing the thread was not my intension. Sorry I'm an old man...
Should I open a new thread?
I'll look through the Aliexpress links, there will be something useful there, thanks.
I hope that everything will work out. It would be a great success for me if I could get your EaserCat 3000 up and running.
I hope I can contact you if I have any further questions (which I'm sure will come).
Best greetings from Bavaria
Peter
  • Hakan
  • Hakan
11 Feb 2025 20:57
Replied by Hakan on topic Mesa with Ethercad connection
Category: Driver Boards
Two network interfaces and you can have both Mesa and EtherCAT.
  • Grotius
  • Grotius's Avatar
11 Feb 2025 20:47
Replied by Grotius on topic scurve trajectory planner
Hi Arciera,
Thanks.
I wrote a email to "Min Wan" University in China.
He or she is one of the abstract creators of the 3d clothoid.
I asked for any source code. Or any code they have used for testing their algo that can help us.
Fingers crossed.
To me it looks like " means second derivate?
And the sign above the z and x i don't know.
  • PCW
  • PCW's Avatar
11 Feb 2025 20:46 - 11 Feb 2025 20:50
Replied by PCW on topic Mesa with Ethercad connection
Whilst using hm2 over Ethercat should  improve network latency issues with Mesa cards due to the more efficient transport layer, adding the additional complexity of Ethercat just for this does not make sense to me.
The point is not so much to improve latency but to have open, extensible I/O that interworks with Ethercat servos.
Say you want a BISS absolute encoder interface, MODBUS and RCPWMgens on one low cost EtherCAT compatible card...
Displaying 19141 - 19155 out of 19429 results.
Time to create page: 0.343 seconds
