  • DenysCNC
  • DenysCNC
27 Jan 2025 20:00
Replied by DenysCNC on topic Raspberry Pi Mesa 7C81
Category: Installing LinuxCNC
How did you enable SPI? I didn't find it in "sudo menu-confg" and "sudo raspi-config" command not found.
  • bellda101
  • bellda101
27 Jan 2025 19:26
Replied by bellda101 on topic Post Processor for Linux CNC
Category: Post Processors
It is a Print NC 3 axis router.
  • PCW
  • PCW's Avatar
27 Jan 2025 18:33
Replied by PCW on topic Mesa Board availability
Yes all in stock (7I84,7I84U, 7I74)
  • beauxnez
  • beauxnez
27 Jan 2025 17:51
ESP32/S2/S3 LinuxCNC Controller (6 axis hardware step gen), USB plug-and-play
Hello
 I am trying to compile the code with an esp32 but I have an error message?
  • Muecke
  • Muecke's Avatar
27 Jan 2025 17:08
Replied by Muecke on topic Age of the website and forum
Category: Forum Questions
I actually forgot that logging in as root didn't put me in the actual root directory.
So I can find the joomla and kunena  directories
That sounds like a good basis to get an overview and check what is feasible, offers of support have come: forum.linuxcnc.org/36-using-this-forum-q...ourse?start=0#263279
@JT: You wrote in another post that you don't want to destroy the forum itself, which I think is a good idea ;-).
Would it perhaps be possible to run a second forum in parallel (for a short time) and then try to copy the current forum into it (posts, images, ...) and then, if it works, switch over?
Unfortunately I'm not familiar with this either :-( But personally I would welcome it if the state of the art would work again.
VG Mücke
Translated with DeepL.com (free version)
  • bevins
  • bevins's Avatar
27 Jan 2025 16:57
Replied by bevins on topic Mesa Board availability
Thanks Peter,
You have these in stock?
  • PCW
  • PCW's Avatar
27 Jan 2025 16:45
A 7I74 and 7I84U would be a bit more flexible.
The 7I84U has these advantages over the 7I84:
Each output can be sinking, sourcing, or push-pull
No flyback diodes needed on outputs up to full (500 mA) current
  • bevins
  • bevins's Avatar
27 Jan 2025 16:19
Mesa Board availability was created by bevins
Are 7i74 and 7i84 boards available now? I have to add a topolchanger to a big system I did years back and I need to add a I/O board to a 5i25 on the second port.
Was thinking a 7i74 and a 7i84. Any thoughts or a better idea?
Thanks,
Bob
  • PCW
  • PCW's Avatar
27 Jan 2025 14:58
7i96S card arrived what setup is recomended
Category: Driver Boards
7I96S    CL57
+5V     PUL+
STEP-   PUL-
+5V     DIR+
DIR-     DIR-
SW3 Set for 5V mode
The ENA, ALM and BRK can be left unconnected
  • PCW
  • PCW's Avatar
27 Jan 2025 14:52 - 27 Jan 2025 14:53
Replied by PCW on topic Connecting mesa 7i96s to DM542T
NC means no connection, so don't connect the ENA pins.
Also make sure that the CL57 is set for 5V inputs
  • behai
  • behai
27 Jan 2025 14:34
Replied by behai on topic Connecting mesa 7i96s to DM542T
For a DM542, I would wire:
DRIVE      7I96S
STEP+      +5V
DIR+        +5V
STEP-        STEP-
DIR-          DIR-
ENA+       NC
ENA-        NC
Hi PWC,
What is NC, please? I have looked through the layout, there is a NC mark in TB2 ANALOG:
This is for my own understanding, I am not using this driver. My driver is CL57T which also has Enable pin.
Thank you.
  • horcsab
  • horcsab
27 Jan 2025 14:23
Replied by horcsab on topic 2-speed spindle configuration - help
Dear All,
I have an old milling machine with a hydraulic spindle speed range switch. The hydraulic valve has 2 coils (low and high speed). There are 2 feedback inductive sensors (for low and high speed).
How can I solve this so that when a program needs to change the speed range, it does so automatically under the following conditions.
- the spindle can only rotate (in the between min-max range (50-3200rpm) if the inductive feedback corresponding to the speed
- the range can be changed by reducing the speed to 1-2 rpm
- low range (50-1500rpm)
- high range (1501-3200rpm)
I am looking for advice on how I can solve this properly. (I have never done this with Linuxcnc before)
  • spumco
  • spumco
27 Jan 2025 13:56
Replied by spumco on topic Lathe spindle question turning and milling.
Category: Turning
How  does the servo driver know I want to switch from turning to position for milling?
As @Aciera pointed out, there are (at least) two methods for combining a velocity-mode spindle with a position-mode C-axis.
In Aciera's first example (caxis.comp) the servo driver doesn't 'know' anything about turning vs positioning.  The drive is put in position mode, and LCNC (via caxis.comp and PID tuning) handles positioning vs velocity commands.
In the second example, the drive itself is switched between velocity and position modes using an input on the drive.  LCNC handles the mode switch command, as well as appropriate outputs to the drive depending on which mode is desired.
Neither one of the methods is 'official' Linuxcnc.  That means you won't find official simulations & examples, nor will you find caxis.comp in the official repository.
If you only need to index the C-axis, it will be significantly easier to use orient.comp to position the spindle.  Simplified, orient.comp works by creating two PID loops (one for velocity, one for position), and switching between the two using an M-code.  With orient.comp, there is no 'C' axis available to command - just the spindle through M3/M4/M5 and M19 to position it.
When stopped, the spindle can be positioned at any location using an M19 command - just fine for drilling or X/Y axis milling.  And with a servo-driven spindle the position should be pretty stable.  Heavy milling or drilling which imposes a significant rotational force on the spindle would likely require a brake of some sort.
However, if you need continuous spindle movement coordinated with one or more other axes (X/Y/Z) during milling you will have to use one of the above 'unofficial' methods (or create a new scheme).
  • spumco
  • spumco
27 Jan 2025 13:27
Replied by spumco on topic caxis.comp - How to freewheel axis/spindle?
Category: HAL
@Aciera -
I had hoped to duplicate your C-axis process back when you were working on it, but my drive doesn't permit on-the-fly mode switching via external input.
Since I don't think I can use orient.comp and caxis.comp on the same joint, I'm thinking about ways to un-home and re-home the joint/axis.  Caxis.comp doesn't re-home or move to C0 whenever the spindle stops - it returns to the same position it was in when the spindle command was issued.
Since I don't need to freewheel in the middle of a program, what do you think about using halui to unhome/rehome the C-axis?
  • Freewheel button ON (M-code)
    • set halui.joint.C.unhome
    • Latch encoder reset pin HIGH (to keep it at 0)
    • Amp enable OFF
  • (manual spindle rotation activity)
  • Freewheel button OFF
    • Amp enable ON
    • Unlatch encoder reset pin
    • set halui.joint.C.home
See any major issues with the above before I try testing it this evening?
  • behai
  • behai
27 Jan 2025 12:31 - 27 Jan 2025 14:37
Please help me with the wiring of a single CL57T-V4.1 closed loop driver to Mesa 7i96S
( I am able to get PnCconf to see the Mesa 7i96S board. )
This is the manual of the CL57T driver: www.omc-stepperonline.com/download/CL57T_V4.0.pdf
The printed manual comes with the driver is version CL57T-V4.1, but I can't see any difference.
Based on the manuals for the driver and 7i96S, I understand that:
● Mesa 7i96S STEP pin is the Driver PUL pin. E.g., for a 1.8° step motor, 200 PULSES is a full STEP.
● Mesa 7i96S DIR pin is the Driver DIR pin. I.e., Clockwise or Counter Clockwise.
● The CL57T_V4.x driver requires input voltage 18-50VDC (recommended 24-48VDC). Peak Current: Minimum 2.4 (RMS 2A), typical 5.6 (RMS 4A), max 7.0 (RMS 5A). So it is not a "higher than normal input current requirements" as per Mesa 7i96S manual page 12.
● The CL57T_V4.x driver supports both differential inputs and single-ended inputs. ( I'll wire it to use differential inputs, since it offers better performance. )
And so I am going to attempt this:
1. Is the wiring correct please?
2. The driver manual, page 7, states:
The 1-bit selector is located on the top (S3 in figure 2), used to configure the voltage of control signals. For the safety of optically coupled, the factory setting is 24V, which no need to connect 2K resistors, making it easier to use. When the voltage of the control signal is 5V, the S3 must be set to 5V, otherwise, the motor won't work.
To use the driver using Rasberry Pi 4 as a controller, I have to set the driver S3 to 5V ( I have documented in this video:
Using it with 7i96S, should I set it to 5V or 24V, please?
3. Do we just leave the driver ENA, ALM and BRK un-used, please?
Thank you.
Displaying 19426 - 19440 out of 19845 results.
Time to create page: 0.734 seconds
