  • karlhe
  • karlhe
28 Aug 2024 07:03
Replied by karlhe on topic durchmesser stimmt nicht
Category: Other User Interfaces
Hallo,
ich habe das geändert und es funktioniert jetzt.
Danke
karlhe
  • Aciera
  • Aciera's Avatar
28 Aug 2024 06:36 - 28 Aug 2024 06:49
Replied by Aciera on topic Computer Shutdown
Computer Shutdown
Are you asking me how it works or are you asking the OP if it works for him?
[edit]
'&&' means that the second command (ie 'systemctl poweroff') is only executed once the first command (ie 'linuxcnc '/home/yourusername/linuxcnc/configs/yourconfig/yourconfig.ini') has been successfully executed, which is only the case once linuxcnc has been shutdown again.
Useful if you want a one line command.
[edit2]
in comparison '&' will run both commands independently
  • Aciera
  • Aciera's Avatar
28 Aug 2024 06:33 - 28 Aug 2024 06:34
Replied by Aciera on topic İnstall glade
İnstall glade
Category: Gmoccapy
I don't know what you use to edit your python code. 'Geany' is a simple editor that does a good job and can be easily installed with
 sudo apt install geany
In the menu go to 'View' and activate 'Show White Space' to see spaces and tabs:
  • SamCoffee
  • SamCoffee's Avatar
28 Aug 2024 06:25 - 11 Sep 2024 06:18
Replied by SamCoffee on topic Computer Shutdown
Computer Shutdown
how is it going?
  • Aciera
  • Aciera's Avatar
28 Aug 2024 06:23
İnstall glade
Category: Gmoccapy
here is the relevant function as posted above:
    def on_value_changed(self,obj,data=None):
        changed_value = obj.get_value()
        hal.set_p("near_speed.difference",str(changed_value))
  • Moutomation
  • Moutomation
28 Aug 2024 06:19 - 28 Aug 2024 06:21
Replied by Moutomation on topic İnstall glade
İnstall glade
Category: Gmoccapy
Right now I'm stuck on two issues: 1. Interfering with the hal parameters, 2. Changing the value of a variable in the hal from the g code file and displaying it in the gui. I think I should rest a little and try again when I'm fitter.
  • Moutomation
  • Moutomation
28 Aug 2024 06:16
İnstall glade
Category: Gmoccapy
I start working at 6 in the morning. I work on this project for an average of 15 hours every day. Thank you very much for everything. I'm a little overwhelmed and confused, maybe that's why I can't do it. I'll take a break, get my mind together and try again.
  • royka
  • royka
28 Aug 2024 06:04
How to compile the RT kernel of a ARM board?
That has nothing to do with ARM, perhaps something with the distro that you were using. If it did install but not boot, then it didn't update the bootloader or symlinks in /boot. That could've been easily solved.
  • Aciera
  • Aciera's Avatar
28 Aug 2024 05:49
İnstall glade
Category: Gmoccapy
You can just use the command without the optional '-l'. This should bring up the config picker window:
linuxcnc
or you can directly provide it with the .ini you want to open:
linuxcnc <your_path_here>/<your_ini>.ini
  • Aciera
  • Aciera's Avatar
28 Aug 2024 05:45
İnstall glade
Category: Gmoccapy
File "/home/a/linuxcnc/configs/bluecad/python/testpanel-handler6.py", line 13
TabError: inconsistent use of tabs and spaces in indentation
Python does not like if you mix tabs and spaces for indentation. I only use spaces no tabs so I presume you used tabs to indent the additional lines of code. delete the tabs and replace with spaces.
  • Moutomation
  • Moutomation
28 Aug 2024 05:26 - 28 Aug 2024 05:32
İnstall glade
Category: Gmoccapy
I have added the terminal output.the panel name is tespanel6,testpanel-handler6.py File "/home/a/linuxcnc/configs/bluecad/python/testpanel-handler6.py", line 13
File Name: YeniMetinBelgesi.ngc
File Size:48 KB
  • Moutomation
  • Moutomation
28 Aug 2024 05:03 - 28 Aug 2024 05:04
İnstall glade
Category: Gmoccapy
  • Moutomation
  • Moutomation
28 Aug 2024 04:51 - 28 Aug 2024 04:55
İnstall glade
Category: Gmoccapy
Since I deleted the configuration I do not use, it cannot find that configuration. How can I run the configuration I actually use with linuxcnc -l?
It's looking for sim.gmoccapy, my configuration name is bluecad
  • Moutomation
  • Moutomation
28 Aug 2024 04:48
İnstall glade
Category: Gmoccapy
I created the above configuration just to see the embedded pages, but now I have deleted it and when I run the linuxcnc -l command, it says that it cannot find my actual configuration.
  • Moutomation
  • Moutomation
28 Aug 2024 04:40 - 28 Aug 2024 04:43
İnstall glade
Category: Gmoccapy
Hello,
sorry this is not this there are 2 configurations
Displaying 21751 - 21765 out of 25344 results.
Time to create page: 0.426 seconds
