  • angelnu
  • angelnu
06 Nov 2024 05:57
hm2/hm2_7i92.0: Error finishing read! was created by angelnu
Category: Driver Boards
Usually it is Joint 2, sometimes joint 1 or joint 0. I have to shut down the 7i72 card and restart linuxcnc.
The error is running a program, but sometimes I have gotten the error Error finishing read on 7i92 with no movement of the motors. What could this be due to?
I have a Mesa 7i72 board with a 7i76 connected to an orange PI5, The network cable is Cat6, the motors are Chinese servomotors connected as a direction step, I have executed several times the command:
sudo chrt 99 ping -i .001 -q 192.168.1.1 -c 50000
To see if packets are lost and the result is always 0% packets lost.
I have lowered the maximum speed of the engines in the ini file, I don't know what can happen. Any idea?
Angel
  • jadid
  • jadid
06 Nov 2024 05:37
Replied by jadid on topic Homing lichuan
Homing lichuan
Category: EtherCAT
Aciera,
I see this only happen with lichuan-stepper (CL3-E57H). The same setup can do drive-homing for lichuan-servo (LC20E).
  • Levi
  • Levi
06 Nov 2024 04:56
/usr/share/linuxcnc/hallib/lathe.hal error
I created 1 config with pfconfig. no issues with this one. then i used pfconfig to create a second one and copy the same ini and hal files into the second config and im getting a /usr/share/linuxcnc/hallib/lathe.hal error addf failed / servo-thread not found. they should both be identical so im not sure why one would work but not the second one? im trying to create 2 different configs for the same machine. one with axis and one with probe basic.
anyone have any thoughts?
wopass:invoked with <> options
twopass:found /usr/share/linuxcnc/hallib/lathe.hal
twopass:found ./custom.hal
twopass: Error in file /usr/share/linuxcnc/hallib/lathe.hal:
    addf failed
Running HAL shutdown script
Debug file information:
Note: Using POSIX realtime
HAL: ERROR: thread 'servo-thread' not found
2323
Stopping realtime threads
Unloading hal components
  • Micro2000
  • Micro2000
06 Nov 2024 04:38
Replied by Micro2000 on topic LinuxCNC Error
LinuxCNC Error
Maybe it will work but I am going to try the file from the downloads page at the LinuxCNC Packages "LinuxCNC package for RTAI Kernal 5.4.258" the file is labeled as "linuxcnc_2.9.3_amd64.deb"
  • mBender
  • mBender
06 Nov 2024 03:21
Heureka!! The new level shifter came in today and it works! I used the 3.3V to 12V and supplied 5V to the high voltage line. Even that works. On the Oscilloscope the Input side looks like a perfect square wave, the output side has a raising edge which is not super vertical. It looks like to doesn't make an issue. Will test the 3.3V to 5V lever shifter and see if that makes a difference.
What is the expected behavior of the direction signal. I was expecting that it's either permanently high or permanently low depending on the direction. It looks like that it's either permanent low and high only when a step impulse is created. Meaning it is kind of a square signal too. Is that correct?
Another question: I am running the tang 9k with ethernet. What happens if the ethernet connections drops during a move. Will the motors just stop?
  • Micro2000
  • Micro2000
06 Nov 2024 02:59
Replied by Micro2000 on topic Cannot stat/ no such file or directory
I never tried that mainly because I did not know "linuxcnc" had the RTAI kernal and the "linuxcnc-uspace" was the PREEMPT rt.
  • Micro2000
  • Micro2000
06 Nov 2024 02:05
LinuxCNC Error
when I run "sudo apt install linuxcnc" it returns
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Package linuxcnc is not available, but is referred to by another package.
This may mean that the package is missing, has ben obsoleted, or is
only available from another source
E: Package 'linuxcnc' has no installation candidate
  • tcbmetalworks
  • tcbmetalworks
06 Nov 2024 01:09
Replied by tcbmetalworks on topic 10.5 x 25 cnc plasma table retrofit
Thanks yea I posted on a few Facebook groups asking people about it and they thought I was nuts but to me it makes perfect sense. A large gantry is the exact same as a plasma table. Cartesian coridinates XYZ what gets complicated is when you start to introduce a 6 axis robot with kinematics. What do you think of controlling it using the same controller as the plasma table? Is linux cnc capable of that many axis? It's gonna be interesting making a post processor to run this whole deal. I figure even just driving the crane around with the teach pendant would be handy but what would be even cooler is to have a auto part puller set up. It's a ways away I still haven't even set the table up I need to basicly reorganize the whole shop move the saw lines and lots of other heavy equipment but have been staying up late every night with a tape measure a can of spray paint chain smoking planning different set ups to optimize material flow threw the building. Seems yah can't win 100% every set up has its strengths and weaknesses. I got off the phone with hypertherm earlier they said that the ht2000 has a raw arc voltage output on the io board. Would the thc 5 work well for raw arc voltage?
  • phillc54
  • phillc54's Avatar
06 Nov 2024 00:31 - 13 Nov 2024 01:00
Replied by phillc54 on topic Controlling a compressor with Linuxcnc.
Category: Plasmac
EDIT: files changed to suit a pressure sensor on a analog input.
The following should work but has only been tested in a sim. Use a pressure sensor connected to an analog input and change the postgui file hal pin to suit the analog input. Change HIGH_PRESSURE_VALUE and LOW_PRESSURE_VALUE in user_periodic.py to the values you wish to use. All three files need to be in your plasma machine config directory. Due to response times you will need to move the torch to a suitable start point using the cut recovery panel after the job has paused.
custom_postgui.hal
Warning: Spoiler!
qtplasmac_custom.py
Warning: Spoiler!
user_periodic.py
Warning: Spoiler!
05 Nov 2024 23:59
Replied by tommylight on topic To forum member Aciera
Aciera wearing the new color proudly! :)
Sorry, i was busy earlier so i just made a smiley.
05 Nov 2024 23:52
Replied by tommylight on topic Compensating For Angled Cut
Category: Plasma & Laser
Oh we have to do this marking thing
And this is what can be done, Kjellberg is the Plasma master
05 Nov 2024 23:44
Replied by tommylight on topic 10.5 x 25 cnc plasma table retrofit
Yeah, that with the CNC crane is very good, i asked a client of mine a few years back about that, he stared at me as his crane is 40X15 meters and 8 meters high. Had to ask him twice and still he was not convinced i can do that.
DO IT! :)
05 Nov 2024 23:36
Replied by tommylight on topic Pi-5, NVMe and Mesa
Pi-5, NVMe and Mesa
Category: Installing LinuxCNC
I am pretty sure i am a bit younger than both of you (54), but i absolutely admire your persistence and will to push through, always.
  • Joco
  • Joco's Avatar
05 Nov 2024 23:14
Error getting packages on fresh install on Raspberry Pi 5
Category: QtPyVCP
I will do some snooping after work on my pi5.  Thats about 5 hrs away as of the time of this post.
  • Aldenflorio
  • Aldenflorio's Avatar
05 Nov 2024 22:30
Replied by Aldenflorio on topic Compensating For Angled Cut
I see what you’re saying. That is a predicament, though I can figure that out later alike you mentioned. It may be solvable with the same me mechanism as the dial and some more thought as well. Though for now I’ll disable the THC.
how about the offset issue? Rotating the torch will offset the predicted cut point from the actual cut point. Can I program that out?
Displaying 22381 - 22395 out of 22546 results.
Time to create page: 1.306 seconds
