  • Finngineering
  • Finngineering
19 Jul 2024 19:32
Replied by Finngineering on topic Un-lobotomizing a Maho MH600T
Category: CNC Machines
Here is a photo of the back plate. For some reason I was not able to attach it to the previous message.
 Offtopic, but is there also a resolution (actually more like width*height) limitation in addition to the 1.6 Mb size limit informed when posting a message to the forums? When I cut the widht*height to half, I could post. But previously it would not allow me to post it even with an image size < 500 kB.
  • Finngineering
  • Finngineering
19 Jul 2024 19:23
First of all, I would like to apologize for the long time without reply from my side.
Work and life has kept me busy...It would appear the design of the crowbar circuit is not good enough. The zener voltage "knee" is not sharp enough and component substitutions and tolerances almost means it has to be tuned to work as intended. I am considering updating the design based on the (last) TL431 design from  axotron.se/index_en.php?page=26
I would anyway prefer to have the ethernet jacks rotated 180° so I could use cables with 90° connectors to make it a bit more tidy.
I have worked a bit on the machine as well and started putting it back together. I am not in a situation where I almost need the electrical cabinet before proceeding. For that one I took some inspiration from RotarySMP and cut a section ~25 cm deep out of the cabinet. I will put the mill in a corner, and this will end up saving me a decent amount of space. At the same time, I patched up all of the old holes in it. And with some filler and beautiful Maho green, it starts looking decent again.
The electrical back plate also starts to be complete, at least for now. The planned wiring is done, but I still need two more SinCos interpolators, and sawing and cable channel covers to length. But regardless of that, the back plate can be installed to the electrical cabinet once that is fastened to the mill. Then external wiring and testing can start for real. I used orange terminal blocks to indicate that they have protection inside. This was a convenient possibility with the two level terminal blocks. For the solenoids, I soldered in diodes (1N4004) and for that gearbox motors I used varistors.
  • Aciera
  • Aciera's Avatar
19 Jul 2024 17:42
  • Aciera
  • Aciera's Avatar
19 Jul 2024 17:41
Brauche bitte Hilfe bei der Steuerung des Werkzeugrevolvers
Category: Deutsch
G0 W[#<_selected_tool> * #4001-#4001]
Grundsätzlich wird natürlich deine Routine nicht funktionieren wenn
#<_selected_tool> = 0
Das gäbe dann 0*45-45 = -45
Das führt dann zur Fehlermeldung:
USRMOT: ERROR: invalid command
Bewegung Linear in Zeile 10 würde von Achse/Gelenk W den Anschlag Negativ überschreiten
Bewegung Linear in Zeile 10 würde neg. Anschlag von Achse/Gelenk 3 überschreiten
  • WKS-3D
  • WKS-3D's Avatar
19 Jul 2024 17:34
Category: Deutsch
Found file(REL): ./custom.hal
note: MAXV     max: 166.000 units/sec 9960.000 units/min
note: LJOG     max: 166.000 units/sec 9960.000 units/min
note: LJOG default: 6.000 units/sec 360.000 units/min
note: AJOG     max: 180.000 units/sec 10800.000 units/min
note: AJOG default: 12.000 units/sec 720.000 units/min
note: jog_order='ZXUW'
note: jog_invert={'X'}
 4999: 1.000000
 current_ tool: 0.000000
 selected_ tool before M61: 0.000000
 selected_ tool after M61: 0.000000
 4999: 1.000000
 4999: 1.000000
 current_ tool: 1.000000
emc/task/emctask.cc 68: interp_error: Werkzeug muss vorbereitet sein -Txx- für Werkzeugwechsel
  • Aciera
  • Aciera's Avatar
19 Jul 2024 17:23
Category: Deutsch
Das Gleiche bitte nochmals mit dieser Subroutine:
o<toolchange> sub
#4001=45
(print, 4999: #4999)
(print, current_ tool: #<_current_tool>)
(print, selected_ tool before M61: #<_selected_tool>)
M61 Q#4999
(print, selected_ tool after M61: #<_selected_tool>)
o500 if[#<_current_tool> EQ #<_selected_tool>]
    (DEBUG,Tool bereits in Spindel)
o500 else
    M6 G43
    #4999=#5400
o500 endif
o<toolchange> endsub
m2
  • my1987toyota
  • my1987toyota's Avatar
19 Jul 2024 16:51
Replied by my1987toyota on topic Interesting Youtube Video
this video should help explain.
  • shasse
  • shasse
19 Jul 2024 16:32
"error finishing read" with Mesa 7i92T on fresh install
Category: Driver Boards
I updated the RTK 8168 driver following the procedure in Rod's document, and that seems to have resolved the issue. I did do that previously, but after setting the "r8168.aspm=0 r8168.eee_enable=0 pcie_aspm=off loglevel=3" kernel parameters in /etc/default/grub I previously had neglected to run "sudo update-grub". So the kernel parameters were not actually applied previously. When I worked through it this time I did that and that seems to have made a significant difference.
Rod: Your detailed document was extremely helpful. It might be worth adding a small blurb about editing /etc/default/grub and running sudo update-grub to get them to stick, or point folks to an existing location where that procedure is documented. I struggled to find a canonical "clean" location of documentation for how to do that. askubuntu.com/questions/19486/how-do-i-a...ernel-boot-parameter was the closest I could find.
But this issue is resolved for me now. Thanks so much Rod and Peter!
  • WKS-3D
  • WKS-3D's Avatar
19 Jul 2024 15:43
Category: Deutsch
 4999: 1.000000
 selected_ tool: 0.000000
task: main loop took 0.127948 seconds
 4999: 1.000000
 4999: 1.000000
ungültige Parameter in linearem Kommando
Das verstehe ich aber nicht, denn in der INI-Datei steht für die W-Achse:
[AXIS_W]
MAX_VELOCITY = 66
MAX_ACCELERATION = 1000
MIN_LIMIT = -0
MAX_LIMIT = 360
[JOINT_3]
TYPE = ANGULAR
WRAPPED_ROTARY = 1
HOME = 0.0
FERROR = 10.0
MIN_FERROR = 1.0
MAX_VELOCITY = 66
STEPGEN_MAXVEL = 100
STEPGEN_MAXACCEL = 2000
# these are in nanoseconds
DIRSETUP   = 5000
DIRHOLD    = 5000
STEPLEN    = 5000
STEPSPACE  = 5000
# 12800 Microsteps : 360 = 35,555556, Uebersetzungsverhaeltnis 2:1 = 71,111111111
STEP_SCALE = 71.111111
MIN_LIMIT = -0
MAX_LIMIT = 360
HOME_OFFSET = 0.0
HOME_SEQUENCE = 1
Und unter MDI kann ich die W-Achse sauber ansteuern
  • Aciera
  • Aciera's Avatar
19 Jul 2024 15:29
Category: Deutsch
Also I würde folgendes vorschlagen:
1. ändere mal deine 'toochange.ngc':
o<toolchange> sub
#4001=45
(print, selected_ tool: #<_selected_tool>)
M61 Q#4999
o500 else
    M6 G43
    #4999=#5400
o500 endif
m2
2. Starte deine Konfiguration von einem Terminal:
linuxcnc
3. Ruf die Routine über MDI auf:
[code]o<toolchange> call
4. Schau mal im Terminaloutput was da für Werte von der 'toolchange.ngc' ausgegeben werden.
Vielleicht ergeben sich so neue Hinweise.
  • Toribio1898
  • Toribio1898
19 Jul 2024 15:17 - 19 Jul 2024 15:29
Reconfigurar mi LinuxCNC was created by Toribio1898
Hola y disculpas, por mi falta de inglés. Diría que sólo he actualizado LinuCnc, instalado otros software, como kdenlive, que se que tal vez no sea la distro adecuada para editar videos, pero quería probarla más, es más hago música, me gustaría probar Ardour, Lmms, entre otros, con su kernel, obviamente, pero de golpe, veo que mi gestor de tareas, no se agranda, ni veo la opción de maximizar, queda chiquito. Si hago un clik, no puedo bajar con el mouse, para elegir alguna opción, debo hacerlo con las flechas, y apretar el enter, no hay otra manera y considero que debo reestablecer mi LinuxCNC, no tengo ninguna máquina conectado a mi LnuxCnc, que está instalado en una netbook táctil, que me encanta, con su i3, 4 gigas de ram y ssd, tiene salida vga anulada, pero abriéndola se ven las conexiones internas de su circuito interno, voy a medir sus voltajes y hdmi.
El torno GSK 980TDb, tiene un cable con conexión semejante a un vga, pero de 2 lineas, con solo 3 cablecitos muy finos, que lo conforman. osea, con forma de vga, pero más chuito, veo si puedo anexar una foto de él mismo, me gustaría poder armar una hermbra, para ese cable y ahi si poder conectar el cnc a mi maquina, me encantaría, ojala conozcan el torno y halla algo de guía, o trabajo realizado, que me puedan compartir. Nunca lo hice.
_ Otro cosa que pienso en utilizar el Freecad último o estable, para realizar los gcode, es muy completo y complejo, me gusta mucho, que opinan?. Se de Inskape, que otras opciones?.
_ Cuando consulte por el LinuxCNC 32 bits, que amablemente me compartieron, se lo instale a 8 cpus muy viejos, disco ide y 512 megas de ram ddr, quedaron hermosas, que ya compartí con ustedes, pero no encuentro el Freecad de 32 bits, por ahí ustedes lo tienen para compartirlo?. Si es válida mi mirada de utilizar Freecad, claro está.
_ Perdonen mi extensión, soy novato en LinuxCNC, obviamente se darán cuenta, pero me gusta mucho ésta hermosa opción, lo esecial es recuperarlo y no tener que instalar todo de nuevo.
Al escribirles veo mi Firefox, maximizado a un 3/4 de mi pantalla totao, si aprieto maximizar, ya está a fondo, no da opción, tampoco minimizar,  si cierra con su X.
Desde ya Muchísimas Gracias, los saluda un gran admirador de ustedes, al Equiepo de LinuxCNC, es más, tengo unas netbook de la Escuela, que les voy a instalar un W11 activado, para los dormidos, y dual boot para instalar LinuxCNC, 64 bits para mi, y quienes bajan entendiendo que en la Educación, si queremos la libertad real de nuestros estudiantes, debemos utilizar software libre, como LinuxCNC. Muy amables!...
Finalmente no me reconoce mi celular, que conecté por usb, como siempre a mi LinuxCnc 64 bits. Lástima. Envió mi consulta y si es posible que me respondan, desde ya les agradezco, descargaré mis fotos en otra distro, para poder tenerla en mi netbook. Muchísimas Gracias nuevamente.
  • Caffink
  • Caffink
19 Jul 2024 15:05
MesaCT config - Help was created by Caffink
Hey,
I am trying to do a Mesa Config for Mesa board 7i95T. I have a Nema 34 stepper motor, and a CL86T-V41 stepper driver from Stepperonline. This is for X-axis on benchtop mill. I will use Mesa Hardware Stepgen. I also attached the manual for stepper driver.
Here are my specs:
  • 2:1 gear reduction
  • Ball screw pitch 4mm
  • Fullstep = 200steps/rev
  • 20 microstep, 4000steps/rev
  • Driver has max 500KHz input frequency
  • Recommended specs from driver manual:
    • Step space should not be less than 1us
    • Step length should not be less than 1us
  • Duty cycle of PUL signal is recommended 50%
Question 1) Is step length + step space = step pulse?
Question 2) What does they mean with Duty cycle of PUL signal is recommended 50%? Do they mean that Step space should be 50% of Step length?
Question 3) Regarding Step scale (Which I believe is steps(step pulses) required per 1mm). Are my calculations correct?:
  • (200steps/1rev)*(20microsteps/step)*(2revs/1ballscrew rev)*(1ballscrew rev/4mm)= 2000step pulse/1mm
Question 4) What is maximum linear velocity? Is this the max speed at the gear/pulley after reduction? Or is it the max speed at the stepper motor shaft? I assume it is after reduction, aka at the gear/pulley?
Question 5) What is the lowest step length and step width I can have? I know you shouldn't use max settings specified by the manual, but this is just for my understanding/learning. Stated by the driver: 500KHz max input frequency
  • Maximum input Pulse Rate of stepper driver 500KHz = 1pulse/0.000002nano sec = 1pulse/2000nano sec
  • Since (I assume) Step pulse = Step length + Step space. I can Divide Step Pulse by 2 and get:
  • Step length settings in Mesa CT: 1000nano sec
  • Step space settings in Mesa CT: 1000nano sec
Question 6) Is the maximum linear velocity calculated by this formula?:
  • Maximum input pulse rate of stepper / driver step scale
  • (500000step pulse) / (2000step pulse/mm) = 250mm/s Maximum linear velocity?
Question 7) What should my maximum acceleration be(For trapezoid linear motion)? And how do I calculate it? A formula with explanation would be appreciated.
Best regards
Caf
19 Jul 2024 14:50
Replied by Cant do this anymore bye all on topic Reconnect to Mesa ethernet card
I have separate power controls for PC, MESA, Steppers & Spindle, if I'm going to be a away for a bit I just turn the Stepper & Spindle power off. And the way I have the relays that control the contactors if the mains goes & comes back on nothing energizes. To an outsider it may seem I have too many separate power supplies.
  • PCW
  • PCW's Avatar
19 Jul 2024 14:30
rtt min/avg/max/mdev = 0.057/0.101/10.259/0.057 ms, pipe 2
> 10 ms suggests either network power management is enabled
(in the BIOS) or a problem with the RTK driver. I would try
using the DKMS RTK 8168 driver:
docs.google.com/document/d/1jeV_4VKzVmOI...ading=h.7ydcp08f6tyu
  • WKS-3D
  • WKS-3D's Avatar
19 Jul 2024 14:25
Category: Deutsch
Lösche mal diese Zeile in deiner HAL
setp hm2_7i92.0.7i76.0.0.output-00 true
dann versuch mal im MDI die subroutinen aufzurufen:
o<Ventil_an> call
o<Ventil_aus> call
Klasse, das funktioniert
Jetzt bleibt nur noch das 1. Problem, warum dreht der Stepper nicht beim Toolchange bzw. es passiert ja garnichts.
Wenn ich im MDI die W-Achse aufrufe zB. mit G0 W180, dann dreht sich der Stepper zu dieser Position.
Displaying 24556 - 24570 out of 25551 results.
Time to create page: 0.726 seconds
