  • minimac
  • minimac
30 Oct 2025 09:12
Hilfe bei Pinbelegung ERL PCSE200 an Mesa 7i96S (Step/Dir
Category: Deutsch
Hallo miteinander,ich konnte keine vernünftigen Datenblätter für diesen Antrieb irgendwo finden.Schade denn ich hätte diesen Antrieb gut gebrauchen können. Jetzt habe ich Plan B umgesetzt.Wenigstens konnte ich das Getriebe retten, ich habe ein Adapter gebaut und wie ihr seht ein JMC Servo verbaut.Im Anhang findet ihr ein Bild.Vielen Dank an alle die das gelesen haben.Viele Grüße.
  • Hakan
  • Hakan
30 Oct 2025 09:03 - 30 Oct 2025 09:28
Long initialization of Ethercat on servo drive SV660N
Category: EtherCAT
Nothings makes me more curious than someone being secretive haha.
This is what Ethercat master documentation says
Two places to modify
Read out the sii info with "ethercat -p 0 sii_read"
1. Supported mailbox protocols.
Like it says in the figure, word 0x1C byte 0x38, bit 0x02 specifies EoE support.
Clear that bit for no support.
To orient yourself, you should find bit 3, 0x04, set for CoE support.
2. Enabled EoE mailboxes.
To find the byte that specifies drive EoE mailbox enabled:
In the read sii file, use some kind of hex editor.
Skip 0x80 bytes forward over the hardware config info
Byte 0x80-0x81 is 0x1a00 meaning strings section
Byte 0x82-0x83 is a word specifying the length of the string section.
  Example : 0xd100 = 209(dec) words.
  Add 1 to make it even: 210 words.
  Multiply by 2 to make number of bytes: 420.
  Add two for the size of the 0x1a00 identifier word: 422
  Sum up 128 + 422 = 550. Hex 0x226
At bytes 0x226-0x227 one finds 0x1e00 meaning general information section
0x228-0x229 is a word specifying the length of the general section
EoE mailbox specifier is now byte 9 in this section: 0x231
To orient yourself, byte 8 (0x230) is FoE mailbox specifier, CoE details are in byte 7, (0x22f)
To disable EoE, first verify that the specified byte is 1. Then, write a zero in that position.
Upload the modified sii file to the drive again with "ethercat -p n sii_write mod_eeprom"
Personally, I wouldn't do this. I would use a Ethercat master with EoE disabled.
The above is only theoretical and may be wrong. Don't use it.
  • unknown
  • unknown
30 Oct 2025 08:53
I haven't had a chance to really give it a good go lately, other things have got in the way.
But I've found your project to be solid and though it doesn't really relate to your project, but when I came across it I was in a bit of a dark place and it gave me the will and drive to get active again.
  • Hakan
  • Hakan
30 Oct 2025 08:29
New ethercat / probe basic control for minimonster
Category: CNC Machines
Here are the general signals that was generated for me by pncconf some years ago.
net spindle-vel-cmd-rps        <=  spindle.0.speed-out-rps
net spindle-vel-cmd-rps-abs    <=  spindle.0.speed-out-rps-abs
net spindle-vel-cmd-rpm        <=  spindle.0.speed-out
net spindle-vel-cmd-rpm-abs    <=  spindle.0.speed-out-abs
net spindle-enable             <=  spindle.0.on
net spindle-cw                 <=  spindle.0.forward
net spindle-ccw                <=  spindle.0.reverse
net spindle-brake              <=  spindle.0.brake
net spindle-revs               =>  spindle.0.revs
 net spindle-at-speed           =>  spindle.0.at-speed
setp spindle.0.at-speed 1
net spindle-vel-fb-rps         =>  spindle.0.speed-in
net spindle-index-enable      <=>  spindle.0.index-enable
net spindle-revs              <=   hm2_7i76e.0.encoder.04.position
net spindle-vel-fb-rps        <=   hm2_7i76e.0.encoder.04.velocity
net spindle-index-enable      <=>  hm2_7i76e.0.encoder.04.index-enable
net spindle-manual-cw     halui.spindle.0.forward
net spindle-manual-ccw    halui.spindle.0.reverse
net spindle-manual-stop   halui.spindle.0.stop
You would need at least the enable and one of the vel-cmds.
Maybe forward/reverse and so on.
They all connect to the spindle pins (created by the motmod component).
Speed feedback is optional but nice to have, at-speed if your spindle can do that.
Displaying 12151 - 12154 out of 12154 results.
Time to create page: 0.498 seconds
