  • tjtr33
  • tjtr33's Avatar
20 Apr 2026 13:32
Sinker EDM machine based on diy pulse generator
Hello,
I still work on the 'sedm' project on GitHub.
But there were questions about the technology';s origin.
So i took a week (so far) to resurrect the tools I used to generate tech.
The premise is that a discharge of N amperes at Vdischarge voltage,
for T uSecs can be calculated.
It's been a challenge, as the code is Excel 4 XLM ( the pre VBA language).
It's a work in progress. I was pleased to see the inputs were Idischarge Vdischarge Tduration,
making the relationship OverBurn is proportinal to joules.
I was also pleased it listed RMS,RA,Rz and VDI surface finish values for
each discharge energy.
Is this project wanted as a Github repo?
I'll need to translate it from Excel4 with XLM
to LibreOffice(current) with Python as the macro language.
lemmeknow
Tomp tjtr33
  • cmorley
  • cmorley
20 Apr 2026 13:24
Replied by cmorley on topic Using Offsetpage Widget?
Category: GladeVCP
excellent.
  • grandixximo
  • grandixximo's Avatar
20 Apr 2026 11:48
Replied by grandixximo on topic Ethercat random jitter fix
Category: EtherCAT
You might have to do some testing, EK1100 works fine as the first DC with Beckhoff servos, but I don't know how your servos will like it, to be tested, possibly fine, but I wouldn't finalize anything before testing is done.
  • papagno-source
  • papagno-source
20 Apr 2026 11:37
Replied by papagno-source on topic Ethercat random jitter fix
Category: EtherCAT
So, even if you switch to the EK1100 as a coupler and related I/O on the EK1100 backplane, it is not recommended to use them as the first slave. Is it better to install the drives first and then the EK1100?
  • grandixximo
20 Apr 2026 11:28
Replied by grandixximo on topic Tuning Steperonline A6 Servos
Category: EtherCAT
Verify Pr0.04 with inertia identification.
Zero Pr2.22 and Pr2.23.
Raise Pr1.10 to ~500, see if small moves land correctly.
Bring Pr1.12 up in 10-point steps with Pr1.13 ≈ 50.
Measure breakaway torque per direction (d04 monitor) and set Pr6.08/Pr6.09.
Only then, if still imperfect, enable Pr2.50 (ZTC).
  • grandixximo
20 Apr 2026 11:18 - 20 Apr 2026 11:19
Category: EtherCAT
Exist a model one 5 volt TTL with 1 channel encoder or 2 channel encoder , with really Z index signal ?
EL5101 is 5V with the Z index
  • andrax
  • andrax's Avatar
20 Apr 2026 11:10
Replied by andrax on topic Tuning Steperonline A6 Servos
Category: EtherCAT
That's exactly what I'm looking for. Perhaps someone has already made such adjustments to the driver and can say which parameters need to be adjusted.
  • papagno-source
  • papagno-source
20 Apr 2026 10:58
Category: EtherCAT
I'll try your latest patch from this morning later today or tomorrow. If the axes make noise, I'll move the first current slave to last, so we'll have the 3 drives first, then the I/O.
  • grandixximo
20 Apr 2026 10:46
Replied by grandixximo on topic Launching gladevcp panel with gmoccapy
Category: Gmoccapy
Also new 2.10 will not start with your .ini configuration having names with hyphens, use underscores
  • grandixximo
20 Apr 2026 10:45
Category: EtherCAT
Some booster parameter for micro increments?
  • Todd Zuercher
  • Todd Zuercher's Avatar
20 Apr 2026 10:41 - 21 Apr 2026 18:39
Replied by Todd Zuercher on topic Using Offsetpage Widget?
Category: GladeVCP
Never mind, I had the name of my handler file wrong in the ini file.
It works!
Thank you
File Name: offsets.py
File Size:0 KB
File Name: offsets_2026-04-20.ui
File Size:1 KB
And the INI lines to add it to a tab in Axis.
EMBED_TAB_NAME=Work Offsets
EMBED_TAB_COMMAND=gladevcp -u ./offsets.py -x {XID} ./offsets.ui
  • papagno-source
  • papagno-source
20 Apr 2026 10:41
Category: EtherCAT
Tha model EL5152 is for 24 volt encoder , we normally use 5 volt TTL encoder, because normally use emulated endoer out the drive .
  • andrax
  • andrax's Avatar
20 Apr 2026 10:27
Category: EtherCAT
No, not that.
So, if I tap just once, for example 0.1 mm, the axis moves 0.09 mm and it takes about 1-2 seconds for it to adjust.
It's exactly the same at 0.01 mm.
At 0.001 mm, I have to tap several times before anything moves, and it takes quite a while for the axis to adjust.
I did some calculations:
17Bit encoder and 10mm spindle:
1mm = 13107,2 inc = 35,38°
0,1mm = 1310,7 inc = 3,5°
0,01mm = 131,0 inc = 0,35°
0,001mm = 13,1 inc = 0,035°
The A6 should easily manage that.I don't think autotuning alone will be enough.
You'll probably have to adjust some settings in the driver.
  • Todd Zuercher
20 Apr 2026 10:21
Category: GladeVCP
I tried coping what you have above (with the appropriate name changes) to the handler file, but I still get all zeros in the table.
  • grandixximo
20 Apr 2026 09:37 - 20 Apr 2026 09:38
Category: EtherCAT
Good morning,
If you want to keep an I/O as first device I suggest EK1100 instead, or have the servos first.
If you want encoder for rigid tapping I suggest EL5152 and a suitable encoder with A/B/Z signals.
EL5122 does not support Z signal, and you'd have to create a virtual one, more laborious, and possibly never as precise/repetitive.
Using EL5122 or EL5152 as first device on DC also not advised, they are not  conmonly used that way, so I'd avoid it.
I've been think about your debian 10 immediately OP, and I suspect that points to your debian 10 running in free mode and not DC.
Displaying 2506 - 2520 out of 14223 results.
Time to create page: 0.640 seconds
