  • my1987toyota
  • my1987toyota's Avatar
19 May 2026 19:31
Replied by my1987toyota on topic Brilliant Bambu Lab
Brilliant Bambu Lab
And there's more
  • markder13
  • markder13
19 May 2026 18:30
Replied by markder13 on topic Schaublin 125-CNC retrofit.
Category: Turning
My immediate reaction when I saw your problem was a cascade PID loop. These are two PID loops: fast and slow.
The fast loop is a normal encoder to VFD loop.
The second loop controls the CVT. That controller tries only to keep the output of the first loop at 6V (= 50Hz). I think you do not have to calculate the gear ratio, etc. Maybe it would work without any additional hardware.If the output of the fast controller (VFD) is below 5V, the CVT turns on until it hits the limit or the controller output is above 5V and below 7V. Above 7V, the CVT turns on in the other direction.
If this does not work and feedback from the CVT is needed, a Waterproof Wire Encoder (Aliexpress) can be considered. Then, the PV (actual position of the CVT) can be used to calculate / adjust the $K_p$, $K_i$, and $K_d$ of the fast VFD loop. Mark
  • robert0423
  • robert0423
19 May 2026 18:03
Replied by robert0423 on topic hm2_eth Connection refused
That solved the issue.
  1. Configured the jumpers on the MESA 7i96S (FPGA card) to Down/Up which set the IP address to 10.10.10.10. This placed it on a separate subnet isolated from my 192.168.1.x main network.
  2. Set the IP address of the RPi wired ethernet (ETH0) (Settings/Advanced networking) to the static manual address 10.10.10.1. This placed the RPi ethernet on the same subnet as the MESA.
  3. Set the IP address for the WIFI on the RPi to use DHCP. This received an IP address for the main network (192.168.1.110).
  4. In Pncconf, set the IP address for the Card (i.e. the MESA FPGA 7i96S) to match the IP address set by the jumper configuration, 10.10.10.10.
Everything now works as expected.
Bob
  • andypugh
  • andypugh's Avatar
19 May 2026 11:44 - 19 May 2026 11:45
Best way to sync collinear Spindles (running as step/gen signal)?
As these are both step-dir I think you could simply set the scales the same in the drives and send them both the same step and direction pulses (at the hardware level)
I feel that I am missing something, though, why are the two parts driven separately if they always rotate as-one?
  • PCW
  • PCW's Avatar
19 May 2026 05:01
Replied by PCW on topic hm2_eth Connection refused
It looks like you  have set the card IP address in the hal file to the host address
rather than the FPGA card address:
hm2_eth: ERROR: Could not retrieve hardware address (MAC) of 10.10.10.1: Connection refused
  • PCW
  • PCW's Avatar
19 May 2026 04:58
Replied by PCW on topic Mill Retrofit with Fanuc DC Drives
Category: HAL
The runaway suggests that possibly  one of the feedback loops is reversed.
  • fully_defined
  • fully_defined's Avatar
19 May 2026 03:23
Replied by fully_defined on topic ELO touchscreen driver and interface install.
I vibecoded it with Claude Code. Works a treat!
  • kb9ydn
  • kb9ydn
19 May 2026 02:21
Replied by kb9ydn on topic Remora for RP2040
Remora for RP2040
I had a quick look at the PortingPlan.md. Am I right to presume that this was AI assisted coding? It's insane how this thing is a game changer for non coder; I have some understanding of coding, read a lot of source code, but am not able to write more than a couple of functions to adapt an existing code (and even that part is mainly copy-pasting form existing libraries). Yet, within three days had a CANopen motor connected to a RPi spinning smoothly in CSP mode. I wouldn't say with Claude-code's help, but rather than Claude-code had it working with some of my contribution for hradware connection and debugging.
It is AI assisted, Claude in fact!  And yes, Claude did basically all of the actual coding based on existing work.  I did have to do a fair bit of flashing binaries and scoping pins for voltages and timing.  And it does need some guidance for how to fix issues that come up.  It seems very good at writing code given enough direction.  But it doesn't necessarily know which way to do things when there are multiple options available.  It can also go off on tangents when troubleshooting complex problems.  That said, it saves an unbelievable amount of time.  I do have quite a few years of hobby programming experience in a number of contexts, but I've never been a professional programmer.  I'm more into hardware hacking.  So indeed, AI assisted coding is literally game changing for less than great programmers!
C|
  • tbrasselle
  • tbrasselle
19 May 2026 01:38
Replied by tbrasselle on topic Mill Retrofit with Fanuc DC Drives
Category: HAL
I did have the motor disconnected from the ballscrew initially. I've now connected it back and the problem has not gone away. I've attached a halscope screenshot showing the current status. when i enable the drive it oscillates, starts to smooth out, then runs away.
I can adjust the velocity loop gain on the drive but i have been hesitant to do that. the drive and motor were working as is with the Fanuc controller before I disconnected them.
  • robert0423
  • robert0423
19 May 2026 00:20
hm2_eth Connection refused was created by robert0423
I get a 'Connection refused' error shown below when I try to start linuxcnc using a Raspberry Pi 4B and a new MESA 7i96S card.
I can successfully ping the MESA card from the RPi
  • I can get card information using mesaflash --readhmid
  • iptables is configured to accept all packets and not drop any.
  • The yellow and green LEDs are on for both the RPi and the MESA.
I've tried multiple RPis, MESA cards (both are new), power supplies, network cables, Linuxcnc versions, RPi imagers, ip configurations, disabling WIFI and setting the IP address on the MESA to both 10.10.10.10 and 192.168.1.121.
The results are the same; Connection refused.
Any thoughts or information on how to resolve this issue is greatly appreciated.
Found file(REL): ./cncmill.hal
Running HAL shutdown script
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2: unloading
Debug file information:
Note: Using POSIX realtime
hm2_eth: rtapi_app_main: Connection refused (-111)
./cncmill.hal:9: waitpid failed /usr/bin/rtapi_app hm2_eth
./cncmill.hal:9: /usr/bin/rtapi_app exited without becoming ready
./cncmill.hal:9: insmod for hm2_eth failed, returned -1
1509
Stopping realtime threads
Unloading hal components
  • COFHAL
  • COFHAL
18 May 2026 22:29
Replied by COFHAL on topic Qtvcp GUI and hal pins
Category: Qtvcp
Yes, I already tested it and those new HAL pins work.Thanks.
  • Dudelbert
  • Dudelbert
18 May 2026 19:17
Replied by Dudelbert on topic Schaublin 125-CNC retrofit.
Category: Turning
I have a few points.
First: you refer to the fan multiple times. If your machine is like mine, and I have no reason to believe otherwise, the motor has no fan where you think the fan is, the thing there is the brake.
Second: regarding your solution 2, I can make a simple op-amp for you. Scaling to 24 V is easy, as you already have 24 V, and it would have 2.5 times the resolution of the system that gives satisfactory results for me. Yes, it has way less resolution than an encoder, but you do not need it. This would be the fastest and least invasive route.
Marti
  • spumco
  • spumco
18 May 2026 19:15
Replied by spumco on topic Schaublin 125-CNC retrofit.
Category: Turning
1/ pull the motor fan, and use the shaft stud to drive an encoder, and then mount an electric cooling fan on the shround for the motor.
I vote encoder.
An encoder separate fan will allow:
  • lower continuous motor speed without overheating
  • higher continuous motor speed without the chance of a 45-year old fan leaving the chat
  • you and LCNC not to guess what the motor speed is, adding confidence you aren't going to send the motor in to orbit
All giving you a wider safe frequency/speed range for your VFD/motor - and thus making each 'step' in the CVT more useful (wider range).
Actually, I vote for getting rid of the CVT.  Do what CNC mfgrs have been doing since the 80's & 90's and stick a big a$$ spindle-servo in there with an 8kRPM top end and appropriate-ratio single-speed belt drive.  Just horse the thing.  Simplify your control loop and save your sanity.
But I digress...
  • PCW
  • PCW's Avatar
18 May 2026 16:22
Category: HAL
Are the motors connected to the linear axis?
This will affect the loop stability
Can you change the velocity loop gain on the drives?
  • PedPEx
  • PedPEx
18 May 2026 15:38
Retrofitting an old industrial CNC mill with EtherCAT components - MAHO MH400E
Category: EtherCAT
Hello guys,
a friend and i have planned a retrofit of an old industrial CNC Mill - a MAHO MH400E - since many years, after scoring it back in 2020 and driving it through Bavaria while the very first Corona wave hit the whole world.
The first intention was to retrofit the machine with Mesa hardware and LinuxCNC. After destroying two Mesa boards in another machine build, we decided to use propper industrial components. Therefore the desire to use EtherCAT with reliable Beckhoff hardware arose. After gathering all the necessary components over the years, it was finally time to implement drivers and everything in order to install the accumalted hardware into the Maho CNC mill. The whole process can also be found in my bachelors thesis and is publicly available on GitHub .
The thesis is intentionally written in a way, that beginners have all necessary EtherCAT commands, instructions on how to build the repos from source and CiA402 related information centralized in one place.
The retrofit is not finished at the moment and the process of implementing every component into the CNC mill will be shared here. We aim to execute this retrofit to the highest possible standard, drawing on our professional backgrounds in electronics and mechanics.
Starting from 05/2026, the hardware is mounted inside the control cabinet - which is subject to change, all spindle motor speed controll with contactors will be removed and all the 400V components will be replaced with newer Siemens safety hardware and contactors. The machine is able to read the axes position with an accuracy of 2µm (1µm was planned). The root cause of this problem is subject of the future posts. I'll keep you posted.
All machine files can be found in this GitHub Repo (Maho400E-LinuxCNC) , the custom interpolator PCB is also avaliable on GitHub (SinCosEnc-Conv_EP5101) , the custom EtherCAT drivers can be found in the seperate "linuxcnc-ethercat" repo and in the long shot, the Siemens Machine Keyboard ( Siemens-LinuxCNC-Interface ) is also planned for implementation as a seperate EtherCAT device.
If you have any questions, just join the conversation
Best Regards
Patrick
Displaying 3016 - 3030 out of 13407 results.
Time to create page: 0.509 seconds
