  • papagno-source
  • papagno-source
20 Apr 2026 10:58
Replied by papagno-source on topic Ethercat random jitter fix
Category: EtherCAT
I'll try your latest patch from this morning later today or tomorrow. If the axes make noise, I'll move the first current slave to last, so we'll have the 3 drives first, then the I/O.
  • grandixximo
  • grandixximo's Avatar
20 Apr 2026 10:46
Replied by grandixximo on topic Launching gladevcp panel with gmoccapy
Category: Gmoccapy
Also new 2.10 will not start with your .ini configuration having names with hyphens, use underscores
  • grandixximo
20 Apr 2026 10:45
Replied by grandixximo on topic Tuning Steperonline A6 Servos
Category: EtherCAT
Some booster parameter for micro increments?
  • Todd Zuercher
  • Todd Zuercher's Avatar
20 Apr 2026 10:41 - 21 Apr 2026 18:39
Replied by Todd Zuercher on topic Using Offsetpage Widget?
Category: GladeVCP
Never mind, I had the name of my handler file wrong in the ini file.
It works!
Thank you
File Name: offsets.py
File Size:0 KB
File Name: offsets_2026-04-20.ui
File Size:1 KB
And the INI lines to add it to a tab in Axis.
EMBED_TAB_NAME=Work Offsets
EMBED_TAB_COMMAND=gladevcp -u ./offsets.py -x {XID} ./offsets.ui
  • papagno-source
  • papagno-source
20 Apr 2026 10:41
Category: EtherCAT
Tha model EL5152 is for 24 volt encoder , we normally use 5 volt TTL encoder, because normally use emulated endoer out the drive .
Exist a model one 5 volt TTL with 1 channel encoder or 2 channel encoder , with really Z index signal ?
  • andrax
  • andrax's Avatar
20 Apr 2026 10:27
Replied by andrax on topic Tuning Steperonline A6 Servos
Category: EtherCAT
No, not that.
So, if I tap just once, for example 0.1 mm, the axis moves 0.09 mm and it takes about 1-2 seconds for it to adjust.
It's exactly the same at 0.01 mm.
At 0.001 mm, I have to tap several times before anything moves, and it takes quite a while for the axis to adjust.
I did some calculations:
17Bit encoder and 10mm spindle:
1mm = 13107,2 inc = 35,38°
0,1mm = 1310,7 inc = 3,5°
0,01mm = 131,0 inc = 0,35°
0,001mm = 13,1 inc = 0,035°
The A6 should easily manage that.I don't think autotuning alone will be enough.
You'll probably have to adjust some settings in the driver.
  • Todd Zuercher
20 Apr 2026 10:21
Category: GladeVCP
I tried coping what you have above (with the appropriate name changes) to the handler file, but I still get all zeros in the table.
  • grandixximo
20 Apr 2026 09:37 - 20 Apr 2026 09:38
Replied by grandixximo on topic Ethercat random jitter fix
Category: EtherCAT
Good morning,
If you want to keep an I/O as first device I suggest EK1100 instead, or have the servos first.
If you want encoder for rigid tapping I suggest EL5152 and a suitable encoder with A/B/Z signals.
EL5122 does not support Z signal, and you'd have to create a virtual one, more laborious, and possibly never as precise/repetitive.
Using EL5122 or EL5152 as first device on DC also not advised, they are not  conmonly used that way, so I'd avoid it.
I've been think about your debian 10 immediately OP, and I suspect that points to your debian 10 running in free mode and not DC.
  • Aciera
  • Aciera's Avatar
20 Apr 2026 08:26 - 20 Apr 2026 08:42
Replied by Aciera on topic Launching gladevcp panel with gmoccapy
Category: Gmoccapy
Just a stab, you are loading 'custom_postgui.hal' twice, which does not make a lot of sense:
EMBED_TAB_COMMAND = gladevcp -x {XID} crosshair-panel.ui -H custom_postgui.hal
POSTGUI_HALFILE = custom_postgui.hal
Generally it would be quite helpful if you told us what actually is not working.
Start your config from the terminal and share the output you get there.
  • papagno-source
  • papagno-source
20 Apr 2026 08:02
Category: EtherCAT
Good morning everyone. If I wanted to change the current first slave from Vipa to Beckoff, I was wondering if the EL5122 board for TTL encoders is supported and if connected in Hal, appropriately, can reset the encoder counter, in order to perform rigid tapping.
  • grandixximo
20 Apr 2026 07:46
Category: Gmoccapy
or
EMBED_TAB_LOCATION = ntb_user_tabs
Did you try these?
  • grandixximo
  • grandixximo
20 Apr 2026 06:47
Category: EtherCAT
Define very imprecisely +- 1mm?
  • Hakan
  • Hakan
20 Apr 2026 06:43
Replied by Hakan on topic Proper value for FERROR ? (EtherCAT Servo)
Category: EtherCAT
Most likely your servo drive doesn't report 0 position at the start.
Look at the pin joint.N.motor-pos-fb to verify that.
I am not aware of any good way to fix this more than to manually set the encoder
value to zero, via some device specific sdos. I'm doing that.
It should be described in the manual in that case.
  • grandixximo
20 Apr 2026 05:26 - 20 Apr 2026 06:01
Category: EtherCAT
Hi Hakan,
Thanks for the trace, it pointed straight at the bug. I reproduced your observation on my hardware and the root cause is exactly the "bad initial reference time" you flagged, but only in M2R mode. R2M is unaffected because it only writes the ref clock (sync_reference_clock_to) and never reads it back.
I added a small debug capture inside the dcsync callbacks (same columns as yours: cycle, pll-err, ref_time_lo, app_time) and logged the first 10 cycles. Before the fix on M2R:
# cycle pll_err ref_time_lo app_time_ns      app_time_lo
0 0        1875535147 829958931561087328 1037861216
1 0        1037346343 829958931562087328 1038861216
2 -385754  1038312400 829958935857087328 1038893920
3 -382546  1039366179 829958935858087328 1039893920
Between cycles 1 and 2, app_time_ns jumps by 4,295,000,000 ns (4.3sec). Same shape as your lcec.write-all trace.
Mechanism, walked through the code:
1. Cycle 0 pre_send reads ref_time_lo = 1,875,535,147. At this point our first frame carrying ecrt_master_application_time() has NOT yet been sent (cycle_start queues it, the actual send happens later in pre_send). So the read is the slave's own free-running DC SystemTime from before it received our epoch, exactly your speculation about the 0x92C offset register. lcec's unwrap code then seeds master->ref_time_ns = (app_time & 0xFFFFFFFF00000000) | 1,875,535,147.
2. Cycle 1 pre_send reads ref_time_lo = 1,037,346,343 (now valid, slave has received our app_time and rebased). The 32-to-64-bit wrap detector sees 1,037,346,343 < 1,875,535,147 and adds (1LL << 32) to master->ref_time_ns. False wrap.
3. With ref_time_ns now 4.3 billion ns ahead of dc_time_ns, the resnap logic in pre_send divides the diff by the period and snaps app_time backwards by 4295 periods. That's your +4.295e9 jump.
4. PI then only has to absorb the sub-period residual, which is why your cycle 3+ looks normal.
Fix is in v1.41.0-pre2. A ref_seeded flag discards the first nonzero read; the second nonzero read seeds the unwrap state without wrap detection; steady-state wrap detect takes over from cycle 2 onward.
After the fix on the same hardware:
0 0        3928128362 829970359148090426 4011856954
1 0        4043140737 829970359149090426 4012856954
2 -192285  4044085554 829970359181090426 4044856954
3 -187787  4045074812 829970359182090426 4045856954
No phantom 4.3sec. The cycle 1 to 2 delta is now 32 ms (32 periods), which is the real initial phase error between the slave's rebased SystemTime and our app_time at startup, snapped to whole periods by resnap. PI absorbs the ~190 us sub-period residual over the settle time. pll_reset_count stays at 0 because the first resnap fires with dc_diff_ns == 0 and skips the counter increment.
So your speculation about the slave maintaining its own time and adding an offset after rebase is consistent with what we observe. The lcec bug was specifically the wrap detector treating the pre-rebase read as the baseline for the post-rebase read.
R2M in the current master was already correct in this respect (no read, no bad baseline), so no change there.
Thanks again for the clear debug output, it was the whole reason this was easy to pin down.
Could you test my 1.41~pre2 release on GitHub, to confirm you get the same result?
github.com/grandixximo/linuxcnc-ethercat...ses/tag/v1.41.0-pre2
But be warned even with this fix the OP time in my case remain about the same, the hardware has to do OP to run in DC, and it does take time, I agree with Rob's assessment, having the first device on the network be a good DC device is a must if you want good DC, I could try to debug what is the problem with papagno's first device, and I am also trying to get Ethercat to fix the function where we will be allowed to move the DC reference to arbitrary devices in the network, at the moment this function is present in the API but does NOT work.
This is simply restart after few minutes LinuxCNC was closed (servos had time to drift apart)
12s OP
Then quickly close and open again (servos had NO time to drift apart)
3s OP
if you want to get similar logs
File Name: debug.zip
File Size:426 KB
As far as AssignActivate 0x300 to 0x730 I don't use this type of sync as i run in pos-cmd I don't think is necessary in my use case, but it should work, I think 0x300 should work fine for pos-cmd, if you use vel or torque command with internal PID you might want to look at 0x700 or 0x730
Displaying 3361 - 3375 out of 13628 results.
Time to create page: 0.994 seconds
