10 Mar 2026 14:50
Crazy characters in code after import from another document (Word or eq.)
Category: G&M Codes
Do not use windows editors or office suits for editing machine files.
Use simple text editors such as notepad on windows or mousepad, gedit, nano, geany, etc on Linux.
  • Xnke
  • Xnke
10 Mar 2026 14:38
current latest download of LinuxCNC V2.9.8 will not install GRUB on several PC's
Category: Installing LinuxCNC
I am also trying to use the latest ISO with the Preempt-RT kernel, and the installer fails at the "installing system" step. It also can't format the boot partition as vfat, because apparently the module to read and write FAT32 or FAT16 isn't included? I also have issues with the Realtek firmware for the NIC not being included either.
In order of appearance:
Need non-free firmware, rtl8106g-2.fw not included. I insert removable media (USB thumbdrive) with the realtek firmware .deb and the actual .fw file and it apparently can't access this, even when prompted. Leads to no network access during install.
During partitioning, I prefer seperate /, /tmp, /bin, and /home partitions, but I can work in anything that works. Unfortuntately, no matter what partitioning system I use, even the suggested systems, I get the same error during the installation step: Installing system failed. If I drop to a terminal and do a "cd / && ls" , I can see all the normal things I would expect, but if I try to mount sda0,1 at /, then cd to it and ls, I get what looks normal, but I have not done a comparison yet to see how much is missing.
Finally, if I just push it forward to install grub and try to boot a possibly crippled system, it fails to install grub and complains that it cannot access /boot due to not having the vfat module.
I've downloaded and verified the .iso and burned it with Rufus using both the .iso and dd methods, and I get consistently the same results.
System is a J3445 Celeron 1.5ghz with 4gb of ram and a 140gb Sandisk SSD.
  • sivaraj
  • sivaraj
10 Mar 2026 12:30
400V Servo (51 Nm) mit EtherCAT / CiA402 in LinuxCNC – bezahlbarer Drive gesucht
Category: Deutsch
Based on the manual (download.sew-eurodrive.com/download/pdf/29194652.pdf), your motor appears to be an 8-pole motor.
For an 8-pole motor to operate at 4500 RPM, it requires a frequency supply of approximately 300 Hz, which is supported by most modern drives.
Please note that the 400 V value refers to the inverter-rated voltage, not the motor's rated voltage. You can find additional details in the following document (see page 44):
download.sew-eurodrive.com/download/pdf/29133866.pdf
I found a similar motor with name plate details in this ebay listing:
www.ebay.de/itm/168190225800
This motor rated Power is 5.29 kW
Usys 400 V is the inverter-rated voltage
Motor rated voltage: 328 V
It is not strictly necessary for the drive’s current rating to match the motor’s maximum current, especially if you have a large gear ratio. In such cases, a lower power drive can be used. For example:
11 kW drive should work well . Estimate the torque required
Even a 7.5 kW drive may also be sufficient depending on the application
However, if you plan to use the motor at its maximum rating (48 A with 51 Nm at 4500 RPM), this would require approximately a 22 kW drive.
Another important consideration is the type of encoder installed on the motor. You may need to ensure the encoder is compatible with the selected drive, or possibly replace it to match the drive requirements.
I have seen CTB China drives were used by Linuxcnc user,You can check CTB universal drive with Ethercat interface
  • Badger1875
  • Badger1875
10 Mar 2026 12:11
Category: G&M Codes
Hi folks,
did this appear  to anyone of you in former times?
I'm  fairly new to CNC and brandnew to LinuxCNC (MiniMill 2.9) and I needed a 'warmup_routine' for my machine, so I used the help of AI and generated a file to my purpose.
I imported the code to my Windows editor and saved the file as <name>.ngc.
I wrote shorter files on my own in g-code in advance, saved them, transfered them to the machine and opened them: they worked from the first second.
As I tried to open the g-code with the AI generated parts, I recieved absolute trashed characters in the code, the complete code was unreadable!
When I opened this file with the 'gedit' from Linux, everything looked fine...
Anyone of has some ideas, tipps or solutions?
Greetz
Freddie
  • kb0thn
  • kb0thn
10 Mar 2026 11:31
Laser power scaling based on speed and direction
Category: HAL Examples
Much thanks to iforce2d for this implementation and write-up. I just deployed a slightly tweaked version of it to my 4x10' router that has a 40 watt laser as second spindle.
I had to modify the component to force zero power output when there was no motion. It looks like the original first line of code can result in a NaN and then my machine was ending up with a 50% PWM output in that state. So I force NaN to zero. That worked okay in my testing at a fixed z height. But when running an actual program I retract Z between parts and I was finding that Z only motion was leaving the laser stuck on. So now I also force zero power output when X and Y motion are essentially zero.
component aprs_laserreg "";
pin in   float inpower    "Desired laser power at constant speed";
pin in   float reqspd    "Requested speed, connect to motion.requested-vel";
pin in   float curspd    "Current speed, connect to motion.current-vel";
pin in   float velx    "Current speed x component, connect to joint.0.vel-cmd";
pin in   float vely    "Current speed y component, connect to joint.1.vel-cmd";
pin in   float velz    "Current speed y component, connect to joint.1.vel-cmd";
pin in   float share    "Fraction of power given to pure Y movement, eg. 0.6";
pin out  float outpower "Scaled output laser power";
function _ fp "Update the laser power";
license "GPL";
#include <math.h>
FUNCTION(_) {
	outpower = inpower * (curspd / reqspd);
	float angle = atan2(fabs(velx), fabs(vely));  // angle away from y in radians
	float horz = angle / (0.5*M_PI);          // 1 when moving perfectly along x axis
	outpower *= share + (1-share) * horz;
	if ( outpower > inpower )
		outpower = inpower;
	if ( outpower > 100 )
		outpower = 100;
	if ( ( fabs(velx)<1e-6 && fabs(vely)<1e-6 ) || isnan(outpower) || outpower < 0 )
		outpower = 0;
I use a bunch of MESA cards including a 7I77 and a 7I76. And then some additional IO boards linked via serial. I never figured out how to get a hardware PWM output. So I am using software PWM for driving the laser. Here are the relevant sections of my custom.hal file showing how it all goes together:
# laser engraver
# software PWM
loadrt pwmgen output_type=0
addf pwmgen.update      servo-thread
addf pwmgen.make-pulses servo-thread # should be base-thread
setp pwmgen.0.enable TRUE
setp pwmgen.0.scale 65535
# based on https://forum.linuxcnc.org/47-hal-examples/54073-laser-power-scaling-based-on-speed-and-direction
loadrt lincurve personality=2
loadrt aprs_laserreg # for some reason the component gets renamed to aprs-laserreg (ie changes _ to -)
addf lincurve.0         servo-thread
addf aprs-laserreg.0    servo-thread # I don't seem to have a base-thread. I think because it is MESA
# Laser power mapping (0-100 -> 0-65535)
setp lincurve.0.x-val-00 0
setp lincurve.0.y-val-00 0
setp lincurve.0.x-val-01 100
setp lincurve.0.y-val-01 65535
net laser-requested-speed      motion.requested-vel    => aprs-laserreg.0.reqspd
net laser-current-speed        motion.current-vel      => aprs-laserreg.0.curspd
net laser-velx                 joint.0.vel-cmd         => aprs-laserreg.0.velx
net laser-vely                 joint.1.vel-cmd         => aprs-laserreg.0.vely
net laser-velz                 joint.2.vel-cmd         => aprs-laserreg.0.velz
setp aprs-laserreg.0.share     1.0
net laser-percent              spindle.1.speed-out      => aprs-laserreg.0.inpower
net laser-regulated-percent    aprs-laserreg.0.outpower => lincurve.0.in
net laser-65535                lincurve.0.out           => pwmgen.0.value
net laser-pwm                  pwmgen.0.pwm             => optimat_o_laser_engraver_pwm
# second spindle we will always consider to be at speed
net laser-at-speed => spindle.1.at-speed
sets laser-at-speed true
  • Hakan
  • Hakan
10 Mar 2026 10:59
Replied by Hakan on topic CiA 402 Folder Missing
Category: EtherCAT
It is encoder pulses per mm, maybe your value isn't far off then.
It is suspicious if it start moving very fast. Use halshow to look at the
variables between cia402 and lcec and see if they look ok in size,
moves when they should etc.
  • Finngineering
  • Finngineering
10 Mar 2026 09:45
Replied by Finngineering on topic Strange preview for circular arc (G2/G3)
Category: G&M Codes
Thank you Hannes. I made a bug report as you suggested:
github.com/LinuxCNC/linuxcnc/issues/3855
This was a real use case and a toolpath I intended to use immediately. I was trying for an hour or so, wondering how I can mess up or misunderstand such a simple command. I then gave up and made this thread some time later. I would think I had the command right from the start, just that incorrect preview threw me off. And I did have a fair bit of confidence in the preview, because I had previously used several somewhat complicated CAM generated programs, and the preview always looked fine. Well, at least I know the reason now.
  • Konstantin
  • Konstantin
10 Mar 2026 07:57
Replied by Konstantin on topic CiA 402 Folder Missing
Category: EtherCAT
About the cia402.0.pos-scale, I wrote 100 000 to just start with some value. My encoders are 23bit, therefore 8 388 608 pulses per motor revolution. On my current plasma machine I have a 1:10 planetary gearbox that I plan to use when I upgrade the machine motors to servo motors and LinuxCNC. The rack gear pitch diameter is 50 mm, therefore the circumference is 157.07963267949 mm. This the linear distance that the axis will travel for 1 revolution of the rack gear or 10 revolutions of the motor.
Therefore the cia402.0.pos-scale = ((encoder res * gear ratio)/distance per rev). I am not sure what value I should use for distance per rev - is it the linear distance per the rack gear revolution or the linear distance per motor revolution(that is linear distance per rack gear revolution / gear ratio)?
  • grandixximo
  • grandixximo's Avatar
10 Mar 2026 06:52 - 11 Mar 2026 07:44
Replied by grandixximo on topic Ethercat random jitter fix
Category: EtherCAT
It sounds like you get gravel in the servo motors from time to time.
Or you get click sounds from the motors. It repeats itself with a few or many minutes apart.
The first thing to do is to enable syncToRefClock and enable DC mode for the servos,
this will keep the servo loop in sync with the DC.
What grandixximo is doing here is fixing an effect that despite DC and servo loop are synchronized,
the two loops have been started with an undetermined/unfortunate phase between them.
The gravel sound is there all the time and it doesn't go away until linuxcnc is restarted.
Surprisingly, yesterday Sasha Ittner popped up in the PR log and mentioned he had been working
on a complete redesign of the DC system, eliminating all these problems (don't know details)
grandixximo seems to have reviewed that work and decided to adopt Sasha's work.
grandixximo will have to say himself. And if you don't know, Sasha Ittner is the author of linuxcnc-ethercat
from many (>10) years ago.
After reviewing on real hardware today, I found my original PR works better than what Sascha Ittner did in his repo, I reverted back to the original state before I started reviewing Sasha's work.
If anyone wants to help me test, I'd love feedback on the code in my repo, because for me this is what works.
github.com/grandixximo/linuxcnc-ethercat
But I need more data from other testers.
To prove the system works, you should get grinding noise, if you set sync0shift of your drive to be half your max servo latency, open halscope and scope your servo-thread and open a couple of glxgears to induce latency in the servo thread, this should induce the grinding noise, and the noise will not be anywhere else.
  • Hakan
  • Hakan
10 Mar 2026 06:22
Category: EtherCAT
Initcmds can be used to set a configuration at startup github.com/linuxcnc-ethercat/linuxcnc-et...er/examples/initcmds
your cia402.0.pos-scale is very large. Double-check that one.
Set a negative value for refClockSyncCycles="–1", that switches on the PLL to synchronize
servo loop with DC clock. You also have "did not sync in 5000 cycles" in dmesg. I have no
good way of fixing that, eventually the drives will sync their time though.
  • rodw
  • rodw's Avatar
10 Mar 2026 05:46
that looks like its looking on the cd/DVD. If this is not on installation, edit your sources file to remove the CD/DVD settings
  • Konstantin
  • Konstantin
10 Mar 2026 05:23
Category: EtherCAT
I talked to the manufacturer of the drives and they told me that the PDO mapping should be set in the control device on each start of the machine.
With the above mentioned configuration I tested the homing and it seems the motor find the index pulse but then it starts rotating very fast and following error is reported.
But the synchronization error is still present.
  • Marcos DC
  • Marcos DC's Avatar
10 Mar 2026 04:30
Separating CiA402 Logic from EtherCAT (lcec): Modular Adapter + Drive Stub Valid
Category: EtherCAT
Hi @NWE,
No worries — things have been a bit busy on my side too
Over the last days I focused on validating the CiA402 logic layer in simulation using a HAL drive stub. The main pieces are behaving as expected now (PDS state machine, controlword composition, homing supervision, etc.).
I also added a small gantry supervisor component on top of the CiA402 layer to experiment with safe decouple/recouple behaviour when drives perform internal motion like CiA402 homing.
At the moment everything is running inside HAL with two simulated drives.
Next step is reconnecting this to the EtherCAT side through an adapter layer.
I'm also planning to write a small Python CLI diagnostic tool to read the HAL signals and print a quick snapshot of the CiA402 state to help with testing.
Your Lichuan drive with 4 axes in one unit is quite interesting — that could be a very good test case once the EtherCAT adapter is wired.
I might also open a separate thread later describing the small framework this is turning into and include your two drives as example adapters.
No rush at all
  • hmnijp
  • hmnijp
10 Mar 2026 04:23 - 10 Mar 2026 04:42
Replied by hmnijp on topic motion channels for robotic atc library
I saw this in a recent PR sent by Sascha Ittner:
github.com/sittner/linuxcnc/pull/70
github.com/LinuxCNC/linuxcnc/pull/3845/c...7ac47d8c5d436a843202
Description: joint_ctrl_main.c
* Standalone HAL realtime component for single-joint control.
* Provides: homing, keyboard jogging, jogwheel jogging, trapezoidal
* trajectory planning, following-error monitoring, limit-switch
* handling, and backlash compensation — all as a self-contained
* HAL component independent of the full LinuxCNC motion controller.
  • fts
  • fts
10 Mar 2026 03:09 - 10 Mar 2026 03:16
If the installation fails and you want to see what is going on, go back to "Configure the package manager."
Hit Ctrl Alt F4.
You will likely see something like the attached output scrolling down the screen. What is odd in my situation is that even with the network cable plugged in, I am able to ping the host that it claims to be unable to reach.
Hit Ctrl Alt F5, and that will take you back to the GUI where it has gone on to the GRUB installation portion and likely failed at this point.
This is an odd issue to have!
Displaying 5116 - 5130 out of 13551 results.
Time to create page: 0.292 seconds
