  • tykhon
  • tykhon
05 Mar 2026 02:43
Replied by tykhon on topic chineese mesa 7i92 custom bit file
Category: Driver Boards
99%. Allready flashed it with original 7i92 bit file downloaded from mesa store support zip files. File attached was modified from that zip also.
  • COFHAL
  • COFHAL
05 Mar 2026 00:24
Replied by COFHAL on topic Extract a specific bit from hex value
Thanks, with this component I was able to extract the bits I needed.
  • Marcos DC
  • Marcos DC's Avatar
04 Mar 2026 23:48
Separating CiA402 Logic from EtherCAT (lcec): Modular Adapter + Drive Stub Valid
Category: EtherCAT
Small clarification regarding the README
After reading the feedback I realized that one part of the README may have been ambiguous, especially the section mentioning “Gantry Support” and gantry_manager.comp.
To clarify the intent of the project:
The goal of this repository is not to introduce a new motion or gantry control layer in HAL. Final gantry squaring, coordinated homing and axis relationships are expected to remain in the motion / kinematics layer (e.g. trivkins) as usual.
The purpose of the HAL components in this project is limited to:
separating CiA402 semantics from the transport layer (LCEC / EtherCAT)
providing a deterministic controlword composition path
adding safety gating
optionally handling decouple/recouple situations when a drive performs internal motion (for example CiA402 homing), to avoid command/feedback discontinuities
So any future “coupler” component would only handle safe transition and coupling of drive states, not replace motion-level gantry logic.
I will update the README to make this clearer.
  • Marcos DC
04 Mar 2026 23:18 - 04 Mar 2026 23:39
Category: EtherCAT
Thanks for the feedback. Just to clarify an important point that I may not have emphasized clearly:
All components in the current tests run in the same servo-thread at 1 kHz, with a fixed execution order using addf. For example:
safety → pds_manager → procedure (UT) → controlword composer → driver interface
Because of this, execution is deterministic. In HAL this effectively becomes a sequential call chain within the same realtime cycle.
Also, there is only one writer for the final 6040 controlword, produced by the controlword composer, which avoids the typical “multiple writers” problem that often causes ambiguous state transitions.
In HAL, race conditions are caused by multiple threads or multiple writers, not by the number of components.
Regarding gantry and coupling: I agree that final squaring and coordinated homing logic belongs in the motion/kinematics layer. If a coupler is introduced on the HAL side it would only serve a limited purpose — handling safe decouple/recouple situations when the drive performs internal motion (for example CiA402 homing) to avoid command/feedback jumps. It would not replace motion’s gantry or homing logic.
Interestingly, the recent HOME_ABSOLUTE_ENCODER fix in motion (PR #3774) also highlights a similar concern about maintaining internal consistency when offsets are applied during homing. In that patch the motion code re-normalizes pos_cmd, pos_fb, free_tp.curr_pos, and motor_offset to avoid accumulated offsets during re-homing. Conceptually this looks similar to a recoupling step inside the motion layer to keep controller and physical states aligned.
The goal here is not to duplicate motion functionality, but simply to keep CiA402 semantics independent from the transport layer (LCEC/EtherCAT) while maintaining a deterministic controlword path.
  • PCW
  • PCW's Avatar
04 Mar 2026 22:43
Replied by PCW on topic chineese mesa 7i92 custom bit file
I can make a (7I92) bitfile but are you sure 7I92 bitfiles will work on that card?
04 Mar 2026 22:32 - 04 Mar 2026 22:33
Replied by tommylight on topic Forum Fehler, ... :-(
Category: Deutsch
OK das ist forum fehller, aber es gibt kein info was hat shief geganen.
Had die thema im ein anderen sub forum geschickt, versuch noh mal bitte.
forum.linuxcnc.org/additive-manufacturin...drive-gesucht#343661
04 Mar 2026 22:14
Replied by tommylight on topic 7i92T and mx3660 request for help
Category: PnCConf Wizard
Funny, the homing was INVERTED in Stepconf, but now is not in Pnnconf. Also the latest Pnnconf instructions do not match the Pnnconf I see on my machine. ????? documentation must be lagging I guess, realize everybody is busy and this is a free program......
Parallel port requires pulling inputs down to trigger,
Mesa can have inputs set for pull down or pull up, in hal
Mesa can use all pins as inputs or as outputs, in any combination, and they are much, much faster than parallel port, so it is impossible to have all possible combinations in a wizard.
  • ClarkSavage
  • ClarkSavage
04 Mar 2026 21:27
Replied by ClarkSavage on topic 7i92T and mx3660 request for help
Ok, changed all in_out to in and the axes and everything stays enabled - I can jog them. They go in the right direction.
Since I have changed all the limit settings will revisit that later. Many thanks. Your in the run.
Now I need to play with getting my homing back to normal and get the axes unlimited and start uncommenting other stuff too.
Thanks again.
Thanks again, will report back once I can settle down and get this part straightened out.
  • Lcvette
  • Lcvette's Avatar
04 Mar 2026 21:24
Replied by Lcvette on topic Probe Basic DRO display appears blank
Category: QtPyVCP
kcjengr.github.io/probe_basic/update_notes_stable.html
follow the docs for sa new installation and machine configuration setup. the instructions are there to setup as is needed.
  • hitchhiker
  • hitchhiker
04 Mar 2026 21:23
EMCO Compact 5 cnc Turret with dc motor and no feedback
I start with a pyvcp panel...
Drive fwd 1 station button calls in section in my comp
Set tool 1 button calls m61q1
Then i add buttons tool1 tool2.... tool6 to call m6 t1....t6
If i hit drive fwd 1 station it rotates exact 1 station fwd. goes then backward and reduce pwm to get it locked against the pawl.
Now i check temperature ever 15 minutes of driver and dc motor.
Next step is calculating the distance from actual tool position to taeget tool position.. like from tool 1 to tool 6... or from tool 6 to tool 3... handling the rollover would be interesting... we will see in the next days.
If this done is the last step the movement... with the calculated distance on position to go forward i can multiplie with the forwardtime from position to position.. the locking part is not so sensitive.
So we will see... toolchanger without feedback... very oldschool... complete openloop.
  • my1987toyota
  • my1987toyota's Avatar
  • PCW
  • PCW's Avatar
04 Mar 2026 20:56
Replied by PCW on topic Trying to set up position control mode
Category: HAL
Ok those work properly (step generator action is correct)
I suspect the problem is with your jogging setup.
( Which I cannot check unless you include the missing custom.hal
and custom_postgui.hal files )
  • PCW
  • PCW's Avatar
04 Mar 2026 20:17
Replied by PCW on topic 7i92T and mx3660 request for help
Well the first thing is that all home switches are inverted...
The need to be false (dim red) when not activated and Yellow when activated.
(whoever chose those colors should be punished somehow...)
  • ClarkSavage
  • ClarkSavage
04 Mar 2026 19:27
Yes, I am just confusing myself now.
Yes, looked at Halshow - never done that before so I read a little and then picked what I thought would give the best info.
So, I re-enabled the Y & Z both home limits. All home switches active. I made sure for each test I over road the limits and enable/active Axis display before moving any switch and I got the following. Screenshot is ENABLED base Halshow.
Then I methodically tripped switches + and recorded what happened.
For the limit switches at both ends of each axis:
  • joint.0.home-sw-in [my 7i92 X] yellow turns red when either switch tripped, then back to yellow on release
  • joint.1.home-sw-in [my 7i92 Y] yellow turns red when either switch tripped, then back to yellow on release
  • joint.2.home-sw-in [my 7i92 Z] yellow turns red when either switch tripped, then back to yellow on release
Charge Pump:
  • charge-pump.enable yellow
  • charge-pump.out                   blinking yellow / red
  • hm2_7i92.9.gpio.005.in         blinking yellow / red
  • hm2_7i92.9.gpio.005.in_not  blinking yellow / red opposite charge-pump.out
  • hm2_7i92.9.gpio.005.out       blinking yellow / red opposite charge-pump.out
probe:
  • hm2_7i92.9.gpio.016.in             red turns yellow when probe tripped
  • hm2_7i92.9.gpio.016.in_not      yellow turns red when probe tripped
  • motion.probe-input                    yellow turns red when probe tripped
  • probe-in                                     yellow turns red when probe tripped
ESTOP
  • hm2.7i92.0.gpio.003.in            red not change when my ESTOP button active, but changes color when axis display button pushed
  • hm2.7i92.0.gpio.003.out          yellow not change when my ESTOP button active, but changes color when axis display button pushed
  • hm2.7i92.0.gpio.003.in_not     yellow not change when my ESTOP button active, but changes color when axis display button pushed
If you can provide a few hints, I will check and report on other pins. Appears that ALL axis are enabling as long as I over ride limits, and all limit switches are fine if the color should be yellow when the machine is active.
Again, 7i92 connected with short parallel cord directly to mx3660. All limits and ESTOP run through the mx3660 and then would report back to the 7i92.
Appreciate the input. I now have a few things to learn and can see how Halshow sort of works so will check what I have which isn't much - enable, limit switches, Z probe only, external ESTOP.
Finally, I looked everything over for type mistakes but I am kinda deer in the headlights at this time so ask if you think something does not look right.
  • jblanscett
  • jblanscett
04 Mar 2026 19:11
Replied by jblanscett on topic Trying to set up position control mode
Category: HAL
Here they are
Displaying 5326 - 5340 out of 13551 results.
Time to create page: 2.233 seconds
