  • Ismacr63
  • Ismacr63
04 Feb 2026 15:12
T3D-L20A-RABF configuration help was created by Ismacr63
Category: Turning
I've been trying for several days to configure the T3D-L20A-RABF servo motor as a spindle in speed mode, but I can't get it to work.
I've set the parameters p004=1, p047 to auto-zero, p050=1 for 0-10V unipolar, and p103=9 to reverse the spindle. I've set p025=0 (default) to use the analog input AS+.
I'm using pin 17 to control the relay and connecting S0 or 0V/GND to the relay.
I'm using pin 16 to reverse the spindle direction.
And pin 1 is for PWM. I've connected AGND and AS+ to the bobbin's 0-10V pin.
The board is powered by 24V, and the servo driver is also powered by 24V.
When I input the command M3 S100, for example, the spindle energizes and has torque, but it doesn't rotate or respond to RPMs.
With my limited knowledge, I don't know what else to try. T_T
  • NWE
  • NWE's Avatar
04 Feb 2026 14:52
Replied by NWE on topic Lichuan 4 axis stepper need help-
Category: EtherCAT
but did you try to go to op-enabled without the cia402 component?
That echos my thoughts, I considered throwing that idea out there but decided I'm too much of a newby in this ethercat business to be making too much noise here without trying stuff out on hardware first.
My drive and motors are expected to show up today. Not that that makes it a rush to get this figured out. I still need to decide what I'll build with it once it's working.
  • Nkbhvid
  • Nkbhvid
04 Feb 2026 14:33
Replied by Nkbhvid on topic Linuxcnc 2.9.4 and Mesa 7i97T
Category: Installing LinuxCNC
I've finally managed to configure my 7i97t with the mesaCT.
In order to test my card I tried to put a small voltage on the output pin of the analog 0.
I would have expected to be able to use something like
setp hm2_7i97.0.analogout0 1.0
but it seems that the parameter for the analog drives doesnt exist at all?
My firmware is 7i97_d.bin
Where did i get lost this time?
  • andrax
  • andrax's Avatar
04 Feb 2026 13:26
Replied by andrax on topic Lichuan 4 axis stepper need help-
Category: EtherCAT
I am reading all the topics on EtherCAT and CIA402 carefully. Unfortunately, I am not a programmer and cannot contribute much.
But I found this page, maybe it will help?
EtherCAT Slave: CiA 402 example
Note: would it be possible to incorporate certain safety routines? For example, a watchdog if the servo receives the command for homing but does not start moving.
  • Muecke
  • Muecke's Avatar
04 Feb 2026 13:22
Proposal to improve forum stability and structure
Category: Forum Questions
Hello dear administrators,
I would like to raise a concern about the stability and structure of the forum, as it is becoming increasingly difficult to be active here. Often, the forum is unavailable or you can no longer reply to your own posts. Unfortunately, this is very frustrating and a shame, as the forum is an important point of contact for many of us.
Question for our administrator, BigJohnT:
You recently made some adjustments to the server structure. A question about this:
Would it be possible to share a new database, i.e., create a new table in the database?
Is it possible to create a new folder in the root directory where a new Joomla 6.x can be installed?
I would like to implement this suggestion in collaboration with other interested members of the forum.
Specific suggestion for improvement:
A) Installation of a new Joomla 6.x
B) Installation of the Kanuna forum for Joomla
C) Preparation so that other areas can also be migrated or integrated if desired, such as:
* Downloads
* Search
* Documents
* Archives
* Community
* Forum (this could then be given a new location)
* Wiki
* Source
This is, of course, only a suggestion and not a mandatory requirement! I am not very familiar with Joomla (I only have a small static page with it), but I am convinced that a fresh installation of Joomla and a new forum would improve stability and user-friendliness.
Important:
I am not aiming to migrate the existing forum! Users would have to re-register in the new forum. However, a transition process could be created in which existing members receive an email with a password that they can change when they log in for the first time.
Additional help:
If anyone in the forum is more familiar with Joomla or server structures and is willing to help, please respond with the words: “I offer my help!” Perhaps we can work together to come up with a stable solution.
I hope this suggestion is met with understanding and look forward to your feedback!
Best regards,
Mücke
Translated with DeepL.com (free version)
  • Dudelbert
  • Dudelbert
04 Feb 2026 12:47
Considering a Full Rewire on a Working Schaublin 125 CNC
Category: Turning
so in the last weeks it is really hard to convince myself to even go to the shop — “badly isolated to small of a heater,” you know how it is. Anyway, I still have a bit of an update.
I worked mainly on the control cabinet and its mounting. In the attachments you can see the box made from laser-cut and pre-bent steel plate, and the arm to mount the cabinet.
I decided to take it in the front of the machine. I reused the foot of the holder that mounted the original one in the back. Because the cabinet now is in the way of the tailstock, it had to be articulated twice. Simple rotation would not have worked.
It’s not quite together yet, but you may still see how it is supposed to go together.
It will be some weeks until I will be able to paint it (again, it is too cold).
I think that’s it for now.
  • Hakan
  • Hakan
04 Feb 2026 12:43
Replied by Hakan on topic Lichuan 4 axis stepper need help-
Category: EtherCAT
Can't you just forget about cia for the moment and only work with lcec, like I did.
And transition manually 6,7 15.
  • rodw
  • rodw's Avatar
04 Feb 2026 12:39
Replied by rodw on topic Lichuan 4 axis stepper need help-
Category: EtherCAT
I've attached my unfinished comp and hal for good luck. also had a look at Dominic's results and its the same
  • rodw
  • rodw's Avatar
04 Feb 2026 12:33
Category: EtherCAT
Well, that's disappointing! Thats exactly what I have done.
And all of my statuswords 1-3 are zero. :(
If you can see any obvious errors in the XML, let me know
  • rodw
  • rodw's Avatar
04 Feb 2026 12:26
Category: EtherCAT
Funny, I was just looking too. There is only one lcec slave showing
So if I go back and rework all the cia402 joints to point to the correct variable/pdo for that one slave, it might work!
File Name: pdos_2026-02-04.txt
File Size:2 KB
File Name: ethercat-c...2-04.xml
File Size:4 KB
XML and dump of PDO's is attached
  • Isleape
  • Isleape
04 Feb 2026 11:45 - 04 Feb 2026 11:48
Mesa 7i90HD no comunication/ update erprobte on 2nd mesa (Solved)
Category: Driver Boards
Hi, I am measuring on all pins (11 13 15 17) with no LPTR connected ~ 1.6V - When grounding CS (Pin 17) nothing changes....
LED CR3 is constantly on.
What can i che k in the FPGA configuration that may not be set to have SPI enabled?
Not sure if i used a spi cfg for my custom Bit file...
I created some for ethernet 7i80 and Epp sucessfull 7i90hd previously.... but then things went wrong....
  • Hakan
  • Hakan
04 Feb 2026 10:50
Category: EtherCAT
I asked Rony for it, let's see what he says.
Here is a litttle exercise.
Comment out all connections to lcec for the say fourth drive. No cia involved, only lcec.
Start linuxcnc and then start halshow.
First set lcec.0.x.4-opmode to 8.
Then step by step enter 6, 7 and 15 as 4-controlword (or 4-cia-controlword).
Watch how 4-statusword changes for every number entered.
Use a dec-to-bin converted to decode statusword.
Some of the statusword combinations are belwow
Probably especially valuable to compare the drive that works with one that doesn't.
  • rodw
  • rodw's Avatar
04 Feb 2026 10:15
Replied by rodw on topic Was the forum down 2-3-2026
yeh it was down here during the day (your night) quite a lot
  • my1987toyota
  • my1987toyota's Avatar
04 Feb 2026 10:02
Was the forum down 2-3-2026 was created by my1987toyota
  So all day yesterday I could not bring up the LinuxCNC forum. I could go to the main site but not the forum.
Does anybody know if the forum was actually down or is the USA starting to limit how it's citizens can interact
with others in the world? I tried multiple locations and devices yesterday and none of them would successfully
bring it up.
Obviously I can connect to it now. but the question remains.
  • rodw
  • rodw's Avatar
04 Feb 2026 10:02
Category: EtherCAT
The manual is google translated from Chinese and there is a windows configuration program that connects via USB. Too big to upload sorry but it is all there even if presentation is a bit lacking. It identifies all of the PDOs so it does not make sense if one axis works and others don't
Displaying 6811 - 6825 out of 13543 results.
Time to create page: 0.433 seconds
