  • COFHAL
  • COFHAL
29 Jan 2026 00:50
Replied by COFHAL on topic Debian Trixie upgrade/install to 2.9.4
Category: Installing LinuxCNC
Excuse my ignorance, but how do I create an image of the contents of one hard drive to install it on another? This is to avoid having to reinstall the additional applications I use with LCN.
  • COFHAL
  • COFHAL
29 Jan 2026 00:38 - 29 Jan 2026 00:40
Solving the USB Latency Dogma for HMI/MPG: Technical Feedback Request
Category: Driver Boards
I use Arduino Connector, I really like your project, it's very professional. I don't know if you plan to create matrix-type keyboards to simulate keys or to be used as HAL pins like in Arduino Connector, which gives great flexibility.
  • COFHAL
  • COFHAL
29 Jan 2026 00:32
Thanks, I had an error in the rules file, that's why that error appeared.
  • micklethenickel
  • micklethenickel
  • PCW
  • PCW's Avatar
29 Jan 2026 00:20
  • micklethenickel
  • micklethenickel
29 Jan 2026 00:16
Replied by micklethenickel on topic Using Mesa 7i95T for laser + galvo (xy2-100) control
Thanks! Yeah getting the firmware for this would be much appreciated :)
  • PCW
  • PCW's Avatar
28 Jan 2026 23:44
Yes, you can steal 2 Step/Dir channels to support the 4 differential output signals
that XY2-100 needs. If you don't need the status data back from the galvanometer,
that's all that would be required. If you need the galvanometer status, you could
steal 1 of the 7I95T's RS-422 serial port RX pairs
I can make this firmware if needed
28 Jan 2026 22:36
  • Ismacr63
  • Ismacr63
28 Jan 2026 22:12
keyboard shortcut was created by Ismacr63
keyboard shortcut
Category: QtPyVCP
I’ve been using Probe Basic for a while, and I was wondering if it’s possible to assign keyboard shortcuts to turn the spindle on and off.
  • Nkbhvid
  • Nkbhvid
28 Jan 2026 22:07
Replied by Nkbhvid on topic Linuxcnc 2.9.4 and Mesa 7i97T
Quadrature A,B and Z should be the standard of the ecodrives position signal.
Could you direct me to some knowledge resources or forum threads related to the setup?
  • micklethenickel
  • micklethenickel
28 Jan 2026 22:07
If I were to try doing this with just the galvo hooked up to the 7I95T (no other peripheral steppers), would I still need the daughtercards? Also, where would I be able to find the xy2mod firmware needed for the 7I95T? I saw you had one for the 7I96 board, but it seems this cannot act as a drop-in replacement
  • PCW
  • PCW's Avatar
28 Jan 2026 21:55 - 28 Jan 2026 21:57
Replied by PCW on topic Linuxcnc 2.9.4 and Mesa 7i97T
Yes, if the the drive can output quadrature (A,B,Z) that can connect directly to the 7I97T's encoder inputs
SSI is also possible but would require an additional daughtercard, so quadrature is easier.
  • juliankoenig87
  • juliankoenig87
28 Jan 2026 21:53 - 28 Jan 2026 22:10
Replied by juliankoenig87 on topic LinuxCNC S-Curve Accelerations
I had the same things happining a while ago when I tested Michels s curve. In the end theese (exactly like your situations) were just "calculation errors" and he solved it by adding allowed dwviations. Pos_out got a allowed deviation of 1e-4 I think.
Like you see in my pictures he had imperfections too. Michels s curve code tested outside linuxcnc when I implemend s curve backlash compensation as a proof of concept.
  • Nkbhvid
  • Nkbhvid
28 Jan 2026 21:49
The ECOdrive DKC11.3 can actually output both Incremental Encoder Output (A/B/Z Emulation) as well as SSI absolute encoder emulation. Will any of these fit the encoder input of mesa7i97?
  • PCW
  • PCW's Avatar
28 Jan 2026 21:36
Its not a 7I97T limitation, it's a system limitation.
Analog servo drives for CNC do not use the analog voltage for position control
but rather torque or velocity control. This means the control system (LinuxCNC in this case)
MUST get position feedback from the  axis or it cannot control the axis position.
Displaying 7081 - 7095 out of 13542 results.
Time to create page: 0.366 seconds
