13 Jan 2026 15:55
older 5i25 with 7i76 not working with Linuxcnc 2.9.8
Category: Driver Boards
Can you post whet the exact error is?
  • Lockomat
  • Lockomat
13 Jan 2026 15:23
Hi Guys,
tried to update a system with Mesa 5i25/7i76 kit, running well on wheezy 2.7 to 2.9.8.
The hostmot driver seems to have problems to see the cards. Maybe they are too old? (10-12 Years)
lspci shows a device called "DPIO 2718:5125", mesaflash does not find the 5i25
pncconf seems to see the cards and uses the correct config and mesa tabs.
But Linuxcnc doesn't start because of unknown pins(?) in the hal file
I have attached hal and ini... (See comments in hal where the wrong entries are)
Do you experienced guys see whats wrong here?
Thanks in Advance and best Regards
Stefan
  • DemonClaW
  • DemonClaW
13 Jan 2026 15:06
Replied by DemonClaW on topic Generating a own Popup
Category: Qtvcp
This would be the handler.py for the popup, the ui is currently a blank QDialog Window from QTDesigner nothing on it, i would add that after i got the window working like i want it to work. The problem is that it is something self created and nothing really proofed. I ocouldnt find a post here in the forum and the LinuxWiki side about Qtvcp and QtDragon isnt helping much ,too. Ive really no idea if im even on the right way.
  • lorenzing
  • lorenzing
13 Jan 2026 13:48
Replied by lorenzing on topic Automatic Gantry Squaring
Category: HAL
Hello everyone, I’m asking for your help to understand how I can automatically square my gantry, which is equipped with two motors for the Y and Z axes. The motors have multi-turn absolute encoders, so I don’t have sensors for homing. For me, it would be enough if both motors had the same value. Currently, I perform this operation manually in jog mode when starting LinuxCNC. I’m attaching both the .ini and .hal files. Thanks for your help.
  • cmorley
  • cmorley
13 Jan 2026 13:32
Replied by cmorley on topic Generating a own Popup
Category: Qtvcp
can you post the ui file that defines your popup dialog?
  • Todd Zuercher
  • Todd Zuercher's Avatar
13 Jan 2026 10:58
Replied by Todd Zuercher on topic SolidCAM 2021 remove remaining material
Category: CAD CAM
The best way may depend a lot on what your machine is, what tooling you have available, and even how many of these parts you need to make.
If the part is a low volume part, positioning the part at the correct angle to the head in a fixture and mill the angle with an end mill on a manual machine. Or if you have a multi axis machine (4th or 5th axis) that can mill at the required angle. Another option would be to use a profile mill with the proper angle built into the tool. And of course using a ball end mill to approximate the profile with many passes is always an option.
  • Aciera
  • Aciera's Avatar
13 Jan 2026 07:02 - 14 Jan 2026 07:25
Replied by Aciera on topic code G71
code G71
Category: O Codes (subroutines) and NGCGUI
you already have a thread asking about the exact same topic:
forum.linuxcnc.org/38-general-linuxcnc-q...7775-code-g71#338257
Please continue there.
You have been given a working example gcode. Have you tested that?
Also, you are not providing much information to go on.
Usually a good idea to provide a minimal example of gcode with an explanation of what exactly is not working how you expect it to.
  • SOLD
  • SOLD
13 Jan 2026 05:36
Replied by SOLD on topic 7i92M + 7i76 add PWM+PktUART
Thank you very much for the quick turnaround and for providing the custom bitfile.
I have successfully flashed it and will begin testing shortly.
I really appreciate your help and support.
  • DemonClaW
  • DemonClaW
13 Jan 2026 05:31
Generating a own Popup was created by DemonClaW
Category: Qtvcp
Hey there,
im trying to get a popup done by myself, if i press a GUI Button i would like to get a Popup where i could have some checkboxes and monitoring some pressure inputs. I tryed to find something about the topic here but i didnt really found anything, is there a topic that already deals with this topic? Or is there someone who tryed something like that? Ive created my own .ui File, and tryed to implement it once by the main handler what just leaded a lot of crashes, then i tryed a own handler for the ui what in my opinion is the cleaner way, but sadly same result. i didnt touch any old code in the handler but it still crashes on a buttons i never touched or created myself.
Thx for any help
  • geostu34
  • geostu34's Avatar
13 Jan 2026 04:51
Need help setting up Mesa 7I76EU and Linux CNC, I will pay $100 if someone help
Category: Installing LinuxCNC
I need help setting up my Mesa Card. I believe I have an issue with setting up the IP Address in the computer. I can load Linuxcnc but can get the card to connect. I will pay $100 to someone to walk me through it on the phone or connect directly to my computer. I know nothing about Linux. I want to get this setup asap
george
  • djdelorie
  • djdelorie
13 Jan 2026 04:38
Replied by djdelorie on topic Tool Lengths Offsets and Touch off
Category: AXIS
I don't know if this is needed or not (my M6 macro does it for me) but are you calling G43 after each tool change where you don't touch off, to load that tool's offsets?
  • jakelong61098
  • jakelong61098
13 Jan 2026 02:42 - 13 Jan 2026 02:51
Replied by jakelong61098 on topic ETHERCAR ON INOVANCE SERVO SV635N
Category: EtherCAT
Thank you. After two days i know how to make to motor run. But now the following error of two motor are the same, but still too big sometime with rapid move can up to 1.6mm I think have to tune the motor, but i still dont know how to do it.
So in next step i will try how to input servo load  and digital input to add home switch.
After finish the these step i will update more
www.tiktok.com/@jakelong61098/video/7593...=7532006091312498184
  • skipper
  • skipper
13 Jan 2026 02:22
code G71 was created by skipper
code G71
Need help using G71,
 lenux cnc will not recognize U or W commands.
Thank you
  • nhof
  • nhof
13 Jan 2026 01:57
Replied by nhof on topic Network Interface Card Recommendation
Category: EtherCAT
I just put an intel i226-V PCIe card in on igc driver.  It seems silly to get a 2.5G card to run at 100M but it is cheap and works so far with no problems.  You can check the driver list here:  IgH EtherCAT Master: Device Drivers  for supported drivers.
I am also curious if TSN has any effect, I have not seen how this integrates into ethercat or linuxcnc.
Displaying 7846 - 7860 out of 13508 results.
Time to create page: 0.794 seconds
