  • PCW
  • PCW's Avatar
11 Jan 2026 22:58
Mesa 7i96s problem, only one stepgen works
Category: Driver Boards
That sound's more like a wiring or hal file issue than hardware issue with the 7I96S
You might check than the DIR signals for all axis change when jogging each axis in different directions
  • B-Dizzle01
  • B-Dizzle01
11 Jan 2026 22:36 - 12 Jan 2026 00:04
Replied by B-Dizzle01 on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
I am hoping to find some help on my project.EC300 3.1.3 firmware from scott. NVMPG-StockHal files attachedIt seems to "see" the NVMPG, some of the buttons register but it doesnt seem like they are talking properly.  It'll see some of the button presses but the axis selector on the mpg doesn't change even though it registers the changed on linux cnc.  The pulse wheel doesn't move and the DROs don't update.  Some of the buttons register, some dont.  I installed NVMPG.C from scott as well. Kind of lost on where to go next. hopefully its something stupid and simple.Video:https://youtu.be/3qt5uAIqTMM
This browser does not support PDFs. Please download the PDF to view it: Download PDF
  • deckname
  • deckname
11 Jan 2026 22:13
Hi, I can´t get my mesa card to work right. (It did before.)
The Problem is that only one axis works at a time.
I,m using LinuxCNC 2.9.6 with QtPlasmaC.
Mesa is connected to DM542T drivers.
I swapped the plugs on the mesa to make sure the hardware works correctly.
Tried different stepgen configurations which made different outputs work, but only one at a time.
Looked at the hal pins, which seem good.
I´m out of ideas and hoping for yours.
11 Jan 2026 21:31
Replied by tommylight on topic QtPlasmaC + CoreXY Kinematics
You are welcomed, always, and thank you for reporting back, i am building a small 10W laser with spare parts from a Creality CR-30 (the whole gantry as it is very sturdy and uses 10mm wide belts tightened to breaking point! :) ) so i will need corexy to work, again.
11 Jan 2026 21:28
Replied by tommylight on topic New and Working RTAI debs for 2.9
Category: Installing LinuxCNC
The Kernel Headers are not available for download. Is it necessary, or can I use the one I have here?
Your last link has the headers
drive.google.com/file/d/1fwGb5Qo9pw8lGLp.../view?usp=drive_link
  • HansU
  • HansU's Avatar
11 Jan 2026 20:50
Replied by HansU on topic Touch resizing of gcode preview
Category: Gmoccapy
Please update to the most recent version. There was an issue the the handle where you can adjust the ratio of the left and right window part.
  • Mbrand1901
  • Mbrand1901
11 Jan 2026 20:44
Replied by Mbrand1901 on topic Retrofitting Deckel FP4ATC
Category: Milling Machines
Hello everyone!
after a lot of thoughts, i came to the conclusion, that a 3 axis Heidenhain converter from ebay would be the best. The alternive with these small adapters is to expensive (220€ without tax).
For the toolcanger i need an extra 70Ins and 20Outs.
My idea is, that i am going to use 4 7i84 that I will connect to the 7i97T.
One 7i84 on the RS 422 connection und a 7i85 on the 25 pin connection with 3 7i84 connected to it via the Rs 422.
Is this posible or am I going to make a mistake?
  • cnbbom
  • cnbbom
11 Jan 2026 20:39
Replied by cnbbom on topic New and Working RTAI debs for 2.9
I saved some installation files; I meant to delete them, but because they contained important information, they remained.
Thanks for keeping those, I have now uploaded them to the LinuxCNC repository and I have re-issued the 2.9.8 LinuxCNC RTAI package bases on that kernel.
Please try installing linux-image-5.4.279-rtai, booting from that kernel, them removing linux-image-5.4.290-rtai and rtai-modules-5.4.290
Then install rtai-modules-5.4.279 and reinstall linuxcnc (should still be v2.9.8).
  • TAKUYA
  • TAKUYA
11 Jan 2026 20:08
Replied by TAKUYA on topic StepperOnline A6 Servo
Category: EtherCAT
im not sure what the issue is to be honest. the drive not trying to home is the major issue right now.
  • andypugh
  • andypugh's Avatar
11 Jan 2026 19:50
Replied by andypugh on topic New and Working RTAI debs for 2.9
  • andrax
  • andrax's Avatar
11 Jan 2026 19:40
Replied by andrax on topic StepperOnline A6 Servo
Category: EtherCAT
Unfortunately, I don't know either.Since I switched off the handwheel during homing, I haven't had any more jumps.Please upload your .ini and .hal files.
  • amanker
  • amanker
11 Jan 2026 19:10 - 12 Jan 2026 06:33
I am using this branch
github.com/scottalford75/Remora/tree/main
This is repository I am using since last 2 years. Used on stm32f429 and stm32f446 both version of octopus pro boards
And also tested this one.
github.com/ben-jacobson/Remora-STM32F4xx-PIO
On octopus pro stm32f446 board
Also tested this repo
github.com/scottalford75/Remora-STM32H7xx-PIO
On BTT skr3 board
All were working. But now every repo gives same problem
Yes payload remains same.
"Bad SPI payload = 32393a38"
Occasionally it's 32393a30
  • TAKUYA
  • TAKUYA
11 Jan 2026 18:27
Category: EtherCAT
there is none connected. I wonder why the handwheel would do this though. did you do any specific servo drive settings?
  • andrax
  • andrax's Avatar
11 Jan 2026 18:25
Category: EtherCAT
No, that wasn't the problem.
For me, it was the handwheel.
Do you have a similar device or something like that?
Then deactivate it.
  • deckname
  • deckname
11 Jan 2026 18:22
Replied by deckname on topic QtPlasmaC + CoreXY Kinematics
I´m sorry, i think i mixed something up.
KINEMATICS = corexykins actually works.
might have been the home switches...
Thanks again
Displaying 7891 - 7905 out of 13507 results.
Time to create page: 0.368 seconds
