  • rodw
  • rodw's Avatar
12 Sep 2026 12:19
Replied by rodw on topic 4WD 4WS gps guided lawnmower.
Category: HAL
rodw, oh I saw you on youtube! The new motion.interp.heading pin looks to give you the tangent angle of the current point on a path? That seems helpful.
oh well, tried to attach gifs of the two motion strategies, but didn't work.
Yes the heading gives you an arc tangent to a G2/G3 move which is the direction the wheels should be pointing to drive it. When you revert to a G0 or G1 move, the heading is simply the direction of travel which should also be where both wheels are pointing
Now in the case of  the inside wheel needing to travel  a shorter arc radius than the outer wheels, you should be able to calculate that from the outer arc.
  • muddiver
  • muddiver
12 Sep 2026 11:09
Replied by muddiver on topic Jumping motion with XHC-WHB04B pendant
Category: Basic Configuration
Hi Sascha,
i wanted to thank you, you made my day with your hint, that's what it needed to get the smooth Handwheelfeeling i wanted!
Greets, Tom
  • Nathan40
  • Nathan40
12 Sep 2026 08:36
Replied by Nathan40 on topic Configure scara robot
Category: HAL
Hi All.
I am using SCARAKINS for my scara robot with (2 angular axis + 1 linear axis). The joint mode is working fine but when in cartesian mode the X axis does not move. Please help!
File Name: scara_robo...9-12.zip
File Size:9 KB
Attached is the config. I am using MESA 7c81 with a regular BOB.
  • Catweazel
  • Catweazel
12 Sep 2026 07:36
Replied by Catweazel on topic Headless
Headless
Hi Keith,
I had the same or similar problem yesterday, when I tested my new 7i96s. The estop remained activatet. The cause was: I had configured one input as estop, but left it unconnected during the test.
  • PCW
  • PCW's Avatar
12 Sep 2026 02:49
Home switches stopping machine but not latching fully
Category: Plasmac
Sounds like either an electrical noise issue or maybe contact bounce.
What type of switches are used and what are they connected to?
  • spumco
  • spumco
12 Sep 2026 02:11
(Solved) Probe Basic - HAL pins not being created
Category: QtPyVCP
I couldnt figure out what was interfering with the non-flash 'checked' state, but I figured out a workaround:  set the flashState="false" to the same color as "true" and the indicator appears solid when on.
Time to merge in to my live machine HAL and see if the hang problem I reported on GH have been resolved.
  • RMJ fabrication
  • RMJ fabrication
11 Sep 2026 23:45
Category: Plasmac
Greetings everyone, I call for help on a new issue with my plasma table. So basically when I go to press home all the homing sequence begins. The z axis homes successfully 90% of the time, the x axis homes successfully half the time, and the y axis gantry does not successfully home. I get these errors with the x and y axis.
  • andrax
  • andrax's Avatar
11 Sep 2026 19:45
Replied by andrax on topic EtherCAT Master Beckhoff slave not found
Vertraue keiner KI bevor du nicht das Handbuch gelesen hast.
  • Schaublin12
  • Schaublin12
11 Sep 2026 19:19
Replied by Schaublin12 on topic EtherCAT Master Beckhoff slave not found
Das Teil hört auf den Namen EC1-872 siehe 2. Foto im obigen Beitrag. Laut KI sind die Treiber CIA402 kompatibel.
  • spumco
  • spumco
11 Sep 2026 18:52 - 11 Sep 2026 18:56
Category: QtPyVCP
Updated and startup sidebar selector works great, thanks very much.
Problem... something odd with the indicators.  The non-flashing indicators are no longer changing color when checked, either in Qt or the sim when I toggle the halpin.  But the flashing indicators still work perfectly.
Same thing in the user_button ui - flashing works, static color change does not.
I didn't change anything in the sidebar ui file before/after the update.
  • Lcvette
  • Lcvette's Avatar
11 Sep 2026 17:15
Category: QtPyVCP
Ok i added a combo box to select sidebar tab default for startup, i just pushed so give it about 20 minutes to build and upload and be available in apt update should be ready about 1:40pm EST
  • andrax
  • andrax's Avatar
11 Sep 2026 17:03
Das ESI File nützt dir erst mal nichts. Das ist eine Gerätebeschreibungsdatei typischerweise für Beckhoff.
Zu deinen Steppern. Hier müsstest du sagen, was das für Geräte sind und ob sie CIA402 kompakibel sind.
Wenn sie das sind, ist das implementieren relativ unproblematisch. sic.^^
Verkabeln, anstöpseln, eine Vorlage hier im Forum raussuchen und entsprechend deiner Konfiguration anpassen.
  • Lcvette
  • Lcvette's Avatar
11 Sep 2026 16:42
Category: QtPyVCP
there is not but i can add one, thats a good idea since there is already one for the main tabs
  • Lcvette
  • Lcvette's Avatar
11 Sep 2026 16:39
  • spumco
  • spumco
11 Sep 2026 16:38
Category: QtPyVCP
One down...
Is there a setting to startup with the user sidebar displayed like there is for the user tab?
Displaying 811 - 825 out of 12269 results.
Time to create page: 0.403 seconds
