  • Thllll
  • Thllll
28 Dec 2025 00:54 - 28 Dec 2025 01:51
QT Dragon Unable to Set Tool Height was created by Thllll
Category: Qtvcp
The buttons on the probing page for setting the tool height, I am unable to click on those. Ever other button works. Bottom two buttons
  • unknown
  • unknown
28 Dec 2025 00:05
Replied by unknown on topic CNC camshaft grinder DIY project
Category: CNC Machines
Change the couplers between the lead screw and stepper motor. They can wind under load and tear themselves apart.
Looks good so far.
  • unknown
  • unknown
27 Dec 2025 23:03
How to install simplescreenrecorder on old version of Debian?
What exact version of Debian are you using ?
When you do an apt update it will list the repos and the version, wheezy or bullseye or whatever.
If it's bullseye or up it's available in the repos, if not you may have to install from source, which brings along a whole manner of other issues. And to make whatters worse there does appear to be some issues with wheezy.
From my understanding Sid is the "unstable"branch, so I doubt that anything from Sid would help.
27 Dec 2025 22:24
Choose a mirror near you, download, double click.
packages.debian.org/sid/amd64/simplescreenrecorder/download
If it complains:
sudo apt install gdebi
P.S.
did you do a
sudo apt update
before trying to install? Sorry for asking, but way to often this gets left out.
  • FPVUALAB
  • FPVUALAB
27 Dec 2025 22:20
Replied by FPVUALAB on topic Bricked Mesa 7i92T
Bricked Mesa 7i92T
Category: Driver Boards
Greetings!
First of all, thank you for your advice!!!
It took me a while to realise as a newbie! ))))
Secondly, I want to ask what are the correct steps to take to get help? Do I have to create a separate forum thread or can I ask a question in another one? I'm a complete beginner and don't understand many terms and algorithms, but I'm much better than a month ago!!!))).
I recently bought a ready-made control panel with two Chinese interface boards.
I have a task to connect and configure a 4 axis milling machine.
I have some equipment (a lot of equipment was purchased incorrectly and I can no longer afford unreasonable expenses)
I need help with step-by-step instructions:
1- listing and checking for the relevance of the equipment in relation to my goals
2- firmware for the board in relation to the goals and equipment.
3- help with explaining the connection (I mean connecting the picture of the contacts I made with a marker)
4- setting the machine parameters
It is very difficult for me to connect! It's hard for the first time!
Thank you very much for your support!!!
  • RotarySMP
  • RotarySMP's Avatar
27 Dec 2025 22:06
Thanks Rod, I have an Atem mini Pro Iso, which I use for my live streams, but having it set up for a simple task like screen recording is overkill. For the times I need the screen recorded on the Schaublin I
just use simplescreenrecorder and drop the files onto a thumb drive.
Why it is so hard to install a simple program on Linux, which I have installed easily on two other flavours of linux.?
  • rodw
  • rodw's Avatar
27 Dec 2025 21:48
A bit left field but if this is for your YouTube channel, I use a video switcher and send the Linuxcnc monitor to one input on the switcher ( I had to buy a VGA to HDMI adapter for one machine). The video and audio (from a seperate microphone) gets recorded to SD card on the switcher and I can do picture in picture etc when recording.
I use a MovMagic switcher but a similar one is a Black magic ATEM mni
  • Juxus
  • Juxus
27 Dec 2025 21:22
CNC camshaft grinder DIY project was created by Juxus
Hi all,
I am Juxus from Germany and building my first LinuxCNC project: a camshaft grinder. The mechanics are almost done - now it is time to setup the Mesa 7i96s and LinuxCNC. Laptop (Lenovo T450s) is setup and exclusively for operating the machine.
The idea is to run the A axis with an encoder for turning the camshaft and Y axis for positioning the cam against the grinding wheel. X Axis is to positioning the second cam after the first one is done.
I am a total beginner with LinuxCNC and I am thankful for all hints!
Thanks!
Juxus
  • Pipik
  • Pipik
27 Dec 2025 20:42
Replied by Pipik on topic Need firmware for Chinese BoB on Mesa 7i92
Looks it will fit. Thank you so much!
  • Surmetall
  • Surmetall's Avatar
27 Dec 2025 19:52
maybe a silly idea. but you could install Teamviewer and record the screen on your Cutter-PC.
i use Teamviewer all the time on my machines and i cant note any lag.
Greetings
Tom
  • MaHa
  • MaHa
27 Dec 2025 19:33
calling subroutine from G54, G55, G56, but it acts weird
Category: O Codes (subroutines) and NGCGUI
Today i tested with axis, made an entry in ini:
[HALUI]
MDI_COMMAND = O<work_zero> call
and had this button in glade in postgui.hal
net tb  gladevcp.tb.tog halui.mdi-command-00
The subroutine as before, and the result as before. MDI G0G55X0Y0, when press the button it moves to G0G54X0Y0
  • PCW
  • PCW's Avatar
27 Dec 2025 19:29
Configurations for both the 7I92 and 7I92T plus pinout source:
File Name: 7i92_shu.zip
File Size:245 KB
  • Pipik
  • Pipik
27 Dec 2025 18:24 - 27 Dec 2025 18:30
I'll try to get to this sometime this week
So, did you create firmware for this setup? I am using this BoB´s in several machines, I would like to switch to driving them by 7i92, but cant find proper pinout in 7i92 firmwares file downloaded from your pages. Or whats the name of file with this pin setup?
______________________________
ParPortPin Function
1 Enable
2 xstep
3 ydir
4 (-I dont need-) SpindlePWMout (creating a 0-5V signal for the VFD with a buffer and low pass filter from this pin)
5 adir
6 astep
7 zstep
8 zdir
9 (-I dont need-)
10 max-home-z
11 min-home-x-and-y
12 (-I dont need-) SpindleSensorIn (RPM sensor, 4 pulse per revolution)
13 probe-in
14 xdir
16 ystep
17 CoolantEnable
  • NWE
  • NWE's Avatar
27 Dec 2025 18:10
Replied by NWE on topic System date/time within HAL
Category: HAL
Did you take a look at userspace python hal components? Using that you can create hal pins within a python program. As far as I know, you can easily import time and use it. It will just not be running in the realtime kernel. For a central lubrication system I doubt that would be a problem.
  • NWE
  • NWE's Avatar
27 Dec 2025 17:43
中文论坛话题 Chinese forum topics
Category: Other Languages
希望没有任何误会。我确信这个论坛欢迎中文话题,就像欢迎其他语言一样。
你们从我们这里得到的回复比较少,原因是我们不懂中文,而使用翻译工具需要额外的时间。
我认为按照这个论坛的运作方式,“其他语言(Other Languages)”是开始发布新的中文话题的最佳地方,就像我现在所做的一样。
如果由一些懂中文的人来负责中文话题会更好,因为我们如果不借助翻译是无法阅读的,那样会占用我们太多时间。
如果有人行为不当,最主要的做法是先警告对方。如果在多次警告后仍然继续不当行为,请使用“Report This(举报)”按钮,通知版主介入并协助处理。
“Report This(举报)”按钮也用于举报有害的垃圾信息,这样版主就可以将其删除。
Chinese translation provided by ChatGPT 5.2
I hope there is no misunderstanding, I am sure Chinese topics on this forum are welcome, just like the other languages.
The reason you get very little response from us is we do not understand Chinese and translators take extra time.
I think the way this forum works, the "Other Languages" is the best place to start your new Chinese topics. Just like I did now.
It will be best if some of you who know Chinese are in charge of the Chinese topics, because we can not read it without translation, it would take too much of our time.
The main thing to do if someone is misbehaving, you warn the person. If they continue misbehaving after several warnings, use the "Report This" button to notify the moderators to step in and help you with the misbehaving person.
The "Report This" button is also for reporting harmful spam so the moderators can delete it.
Displaying 8566 - 8580 out of 13507 results.
Time to create page: 1.923 seconds
