13 years 5 months ago #34844 by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
but I have another problem, sometimes when I run s100 m3, the spindle turns me on more or less at 180-200 rpm. I do not understand why this happens, when it happens reset, and again I run s100 m3 and if you turn 100 rpm.
Do you have set 180 rpm in your settings page as start rpm?
I am able to reproduce this, when giving the command S 100 M3 just after homing.
If I do S100 in one line and M3 in an other, this will not happen.
I will investigate how to avoid this.
Norbert
13 years 5 months ago #34845 by mariusl
Replied by mariusl on topic Gmoccapy - A new screen for linuxcnc
Thanks Norbert. I am busy with a mill and a lathe for my own shop so I am very excited about using the screen.
Regards
Marius
www.bluearccnc.com
13 years 5 months ago #34847 by jlviloria
Replied by jlviloria on topic Gmoccapy - A new screen for linuxcnc
Norbert.
if that is what is happening. I have my machine set to s180.
well at least we found something.
Remember I am here willing to try or test anything.
Thanks,
Jorge Viloria
13 years 5 months ago #34848 by newbynobi
I think I found a solution, I mailed a patch to Chris, I will inform as soon he pushed it.
Norbert
13 years 5 months ago #35029 by newbynobi
gmoccapy 0.9.3.2 released!
ver. 0.9.3.2
- alligned the jog_button and jog_rates frame on the top (just cosmetic)
- The Page-up and Page_Down keyboard keys moved the Z axis in oposide directions
- Feed values will only be shown with digit if G95 is active
- added classicladder button to the list of buttons to be able to handle it with hardware button
- changed hardware button handling to fit also to lathe mode
- included a test to avoid speeding the spindle over its limit using the spindle speed overide
i.e. max = 6000 but S = 5500 and overide = 120 % would result in 6600, but only 6000 is possible
- also check spindle speed if the commands are given trough MDI and overide is to high will reduce
the overide value to max allowed
Norbert
13 years 5 months ago - 13 years 5 months ago #35030 by newbynobi
@Jorge,
0.9.3.2 fixes the spindle bug you found, but unfortunately not jet the G95 bug.
@Marius
3. Only if you use the GUI with smaller size than 768 height ;-) I will make the buttons "log Actions and Close" small in one of the next releases.
4. Will be fixed with the next release, but not in 0.9.3.2 witch is finished already and waiting to be pushed from Chris.
I fixed it, but needed to remove the patch afterwards, for incompatibility reasons, will be fixed in the nest release, witch will be a mayor one with new Features!
Norbert
Last edit: 13 years 5 months ago by newbynobi.
Moderators: newbynobi, HansU
Time to create page: 2.383 seconds
