13 years 5 months ago #35062 by mariusl
Replied by mariusl on topic Gmoccapy - A new screen for linuxcnc
Thanks a lot Norbert. Will Chris notify us here when the patched has been pushed?
Regards
Marius
www.bluearccnc.com
13 years 5 months ago #35063 by mariusl
Thanks a lot Norbert. Will Chris notify us here when the patch has been pushed?
Regards
Marius
www.bluearccnc.com
13 years 4 months ago #35086 by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
@ Marius,
I will do so!
Norbert
13 years 4 months ago #35560 by newbynobi
gmoccapy ver. 0.9.4 is on master!
The most important change is, that gmoccapy will use its own locale folder, so it may be translated to every language linuxcnc supports.
I added German by my own and I am waiting for the Spanish translation from Jorge.
If someone like an other language, just give me a info, so I will include the language.
The second change to be taken care off is that I renamed some hal Pin, so if you use your own config, you might be forced to edit it.
All changes are:
- corrected a lot of typo, thanks to David for his help
- renamed some widgets from "cero" to "zero"
- deleted one increment in every INI file, so the GUI fits better to smallest screen size
- translation to German included and prepared for more languages
- there was still an error in key handling with incremental jogging, hope I solved it now for final
- changed the dialog "run_from_line" to use gscreens default, resulting in the need to rename
"hal_sourceview" to "gcode_view"
- renamed all pins and definitions from "overide" to "override" because of typo
- avoid getting to the touch off button, while the machine is not homed
- hide Y touch off buttons in lathe mode
- solved a bug executing a command constantly related with feed and periodic
- Tool change from tool editor now works like it should even with T1 M6 as with M61 Q1
- the tool in spindle will be marked active if you enter the tool editor.
Norbert
13 years 4 months ago #35667 by mariusl
Hi Norbert,
I just pulled the latest version of linuxcnc-dev and ran Gmoccapy on my brand new touch panel. It really looks great and I cant wait to put it to work on my mill,
The million dollar question is now - when are you going to add the fourth axis so we can cut gears? :)
Thanks a lot man your work is great.
Regards
Marius
www.bluearccnc.com
13 years 4 months ago #35691 by newbynobi
Hallo Marius,
I would answer "very, very soon", but I must answer:
"I am working on it, but with limited time at the moment"
So it will take some time, but is the next step to do for sure, just together or after the cero table!
Norbert
Moderators: newbynobi, HansU
Time to create page: 0.367 seconds
