- Thank you received: 394
- newbynobi
13 years 3 months ago #36795
by newbynobi
Sorry Marius,
I missed your question. What you want is possible, if you place all you want in a gtk.notebook page, you may then switch between the different pages to get one or the other settings.
As IMHO it is a very singulair wish, I will not include that in the original code (at this development state).
Norbert
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
Hi Norbert
I have done just that and placed a tab but I am thinking to block out the spindle and cooling functions and place the Plasma functions there. Do you think that could be done so that I can turn the one or the other on with a setting?
Sorry Marius,
Norbert
- newbynobi
13 years 3 months ago #36796
by newbynobi
gmoccapy ver. 0.9.5 has been pushed!
Here are the changes:
- Keyboard shortcuts, now ESCAPE only aborts and F1 emit estop
- spindle can be switched on and off while program is paused, without getting an error
- sourceview now with search and do / redo, while in edit mode
- added an offset page in ntb_preview with the possibility
* to select directly an coordinate system
* edit the coordinates of every system
* give the systems human names, like naming G56 as center of rotary table
- fixed a bug in tooledit, trying to touch of a tool not in spindle, I must check if this should be allowed
or if it better only allowing touch off with the tool in spindle
- changed gmoccapy keyboard to "onboard",
if the layout is not correct, or the keys emitted are wrong, the following command will correct it
setxkbmap -layout <your contry letters>
gb for Great Britain, de for Germany, etc.
- start from line dialog changed, it will remain open until you press cycle start
- changed the entry dialog, so in some cases it is only possible to enter integer values
- added a button to select a tool by its number, it is easier, if you have a lot of tools
- settings page, it is possible to select if you want to use the onbord keyboard also in tooledit page
and in offset page editing
And now the work to include a 4-th axis has began!
So development will go on.
I am also working on a touch screen friendly file selection dialog!
I will update the WIKI as soon as possible.
Norbert
Norbert
- mariusl
13 years 3 months ago #36798
by mariusl
Regards
Marius
www.bluearccnc.com
Replied by mariusl on topic Gmoccapy - A new screen for linuxcnc
Hi Norbert
Thanks for that, it really looks great. I am really excited about the 4th axis. It will be the cherry on the cake for your work, I think
Regards
Marius
www.bluearccnc.com
- mariusl
13 years 3 months ago #36799
by mariusl
I fully realize that Norbert. I did not really expect that you should do it. I am very new to this environment but I am learning fast. I will eventually have a configurable screen that will switch between plasma, mill and custom if I need to. I am not working on it just yet as I am waiting for your work to get closer to the end. Like the 4th axis. My bit will just be a small change after that for me.
Thanks again for really great work. I have been asked, by our local CNC Club to do a presentation on all the new stuff that has surfaced on Linuxcnc. I will be introducing the members to your work and I am sure they will all be very impressed.
Keep it up man:)
Regards
Marius
www.bluearccnc.com
Keep it up man:)
Regards
Marius
www.bluearccnc.com
- f1oat
- Thank you received: 10
13 years 3 months ago #36872
by f1oat
Replied by f1oat on topic Gmoccapy - A new screen for linuxcnc
I would like to add a small feature to Gmoccapy: altering automatically the tool table by reading tags in G-Code file.
I have already modified Cambam config too generate tool table as below:
I have now to launch some Python code when the .ngc file is loaded.
I would like to integrate this modification without modifiying Gmoccapy files. Looks like it is possible with gladevcp handlers, but I will need some help to show me where to start.
Can I add a custom handler somewhere in the "DISPLAY = gscreen -c gmoccapy -d" config line ?
Thanks.
( Made using CamBam - http://www.cambam.co.uk )
( Support HD5000 cover V11 7/15/2013 11:08:44 PM )
( LINUXCNC/TOOLTABLE, 2, "2.00mm 1 flute Fraise cylindrique", 2.0, 0.0, 20.0 )
( LINUXCNC/TOOLTABLE, 4, "6.00mm 4 flute Fraise cylindrique", 6.0, 0.0, 20.0 )
( LINUXCNC/TOOLTABLE, 5, "3.17mm 2 flute Fraise à bout rond", 3.17, 1.585, 30.0 )
(STOCK/BLOCK,80.0,80.0,10.0,10.0,10.0,10.0 )
G21 G90 G64 P0.01 G40
G0 Z3.0
Thanks.
- Thank you received: 2181
13 years 3 months ago #36875
Replied by cmorley on topic Gmoccapy - A new screen for linuxcnc
Gmoccapy and Gscreen are married to gladeVCP, but with little differences.
They invoke the gladeVCP libraries, but initialize differently.
As such you cannot add a second handler file (Gmoccapy uses the handler file principal to modify Gscreen)
So really I think you need to just add to Gmoccapy's handler file.
I'm not sure how successful this will work - but we won't know till you try
hal_status sends a signal to Gscreen when a file is loaded - it calls on_hal_status_file_loaded
You could override this in Gmoccapy by adding the same method name to Gmoccapy's handler file.
From there you could call Gscreen's method or just duplicate it's code (it's a short method)
Then add whatever code you need to parse the file and save it to the tooltable.
The next trick is to get linuxcnc to reread the tool table so as to update it.
There are only certain times you can get linuxcnc to read it. machine on and interpreter idle IIRC
There are python bindings to linuxcnc and a command to reread the tool table.
look at tooledit_widget.py for ideas there.
Interesting idea !
Chris M
Interesting idea !
Chris M
Moderators: newbynobi, HansU
Time to create page: 3.952 seconds
