13 years 5 months ago #34828 by jlviloria
Replied by jlviloria on topic Gmoccapy - A new screen for linuxcnc
Norbert problem time error, I have a problem in my spindle scale.
when I run s100. LinuxCNC s180 shows me running.
I'll work on this have if I can fix this problem
Jorge Viloria
Barranquilla - Colombia
13 years 5 months ago #34829 by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
Hallo Marius,
it is hard codded, I can tell you how to change the value, but I do not recommend it.
If you make the screen smaller than this, the widgets will overlap each other, because they do need certain space.
Just see the settings page with 750 set, you will see that there the widgets will begin to hide each other.
Best is to use a screen size not smaller than 768, I just choose 750, because this value is the smallest I have been able to realize without investing to much time.
Norbert
13 years 5 months ago #34831 by mariusl
Replied by mariusl on topic Gmoccapy - A new screen for linuxcnc
Norbert,
It is looking very good. Can I give some feedback if I may please?
1: The DRO tab opens up to big so the DRO are cut off to the right
2: The last button on jog increments shows inches while the rest show mm
3: Under settings - the keyboard shortcuts frame is to small
4:In the settings - appearance-dro the first radio button label has a typo (Schow -> Show)
Thanks a lot for all your hard work on this. I am really happy that you are doing it for us.
Regards
Marius
www.bluearccnc.com
13 years 5 months ago #34832 by newbynobi
I do not understand very well, but I will try:
You enter in MDI the following code
S100 M3
after starting and homing the machine,
then the label in the spindle frame should say S 100
If not, please check the spindle override!
13 years 5 months ago - 13 years 5 months ago #34834 by newbynobi
Norbert,
Yes you are welcome to give feedback!
1. You are right, but this is only an example for an embedded tab. If you click in the bottom button list the button "make the preview as large as possible" You will see it fits to the screen. I will make this a little bit smaller to fit better.
2. That is on purpose! You can mix them around like you like, just change the INCREMENTS line of your INI file, see also the WIKI
3. Only if you use the GUI with smaller size than 768 height ;-) I will make the buttons "log Actions and Close" small in one of the next releases.
4. Will be fixed with the next release, but not in 0.9.3.2 witch is finished already and waiting to be pushed from Chris.
Norbert
Last edit: 13 years 5 months ago by newbynobi.
13 years 5 months ago #34840 by jlviloria
The problem is in my configuration HAL.
I had noticed that my had a problem on the scale.
My HAL.
#setp scale.spindle.gain 60 before
setp scale.spindle.gain 40 now
setp lowpass.spindle.gain 1.000000
net spindle-vel-fb => lowpass.spindle.in
net spindle-fb-filtered-rps lowpass.spindle.out => abs.spindle.in
net spindle-fb-filtered-abs-rps abs.spindle.out => scale.spindle.in
net spindle-fb-filtered-abs-rpm scale.spindle.out
postgui.hal:
net spindle-fb-filtered-abs-rpm gscreen.hal_hbar_spindle_feedback
but I have another problem, sometimes when I run s100 m3, the spindle turns me on more or less at 180-200 rpm. I do not understand why this happens, when it happens reset, and again I run s100 m3 and if you turn 100 rpm.
Moderators: newbynobi, HansU
Time to create page: 0.430 seconds
