- mariusl
11 years 10 months ago #54322
by mariusl
Regards
Marius
www.bluearccnc.com
Replied by mariusl on topic Gmoccapy - A new screen for linuxcnc
We will only bite your head off if you dont give us some details of the errors.
Post some of the dmesg output and also the debug out put from the shell or terminal where you launched linuxcnc. Capture some screen shots if it gets that far.
Not getting it to run does not give much
Regards
Marius
www.bluearccnc.com
The following user(s) said Thank You: 2e0poz
- 2e0poz
11 years 10 months ago #54323
by 2e0poz
Replied by 2e0poz on topic Gmoccapy - A new screen for linuxcnc
Ok will explain first what the issue is. I was expecting gmoccapy files to be in my config folder and none exist, in the error report that pops up after trying to run it refers to the files that are not there.
I need my head so please be gentle
- 2e0poz
11 years 10 months ago - 11 years 10 months ago #54324
by 2e0poz
Forgot to say the install went fine and Axis runs allowing me to run a test code run (no machine connected yet)
Last edit: 11 years 10 months ago by 2e0poz.
- newbynobi
- Thank you received: 394
11 years 10 months ago #54326
by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
Just read the error and you will find:
Custom_postgui.hal:7 pin pyvcp.spindle-speed does not exist
Please clear you hal files and you are done, all other errors we will clear later.
Norbert
Norbert
- 2e0poz
11 years 10 months ago #54327
by 2e0poz
Coooolie, i removed the spindle setup via stepconf and then changed th ini and sure enough gmcoccapy fires up. Thank you very much for the help guys, will configure the spindle later.
- tuxcnc
- Thank you received: 56
11 years 10 months ago #54343
by tuxcnc
I'm afraid, there is no polish translation in repos ...
I do not have time to do anything too, but somehow I made a diff of the two sliders.
The differences are relative to the latest version was downloaded yesterday.
It works, but I think you can do it better.
dl.dropboxusercontent.com/u/16218687/gmo...-two-jog-sliders.tar
Replied by tuxcnc on topic Gmoccapy - A new screen for linuxcnc
newbynobi wrote: I will include polish traanslation in the official repo.
I will have to think about the doble slider
Moderators: newbynobi, HansU
Time to create page: 0.353 seconds
