12 years 11 months ago #41133 by DaOne
Replied by DaOne on topic Gmoccapy - A new screen for linuxcnc
Maybe a good solution would be the icon with text underneath. The only issue I see with that is language localization. I have yet to look to see if its possible but maybe you could put a dynamic text string over the button that is set from the language strings? Just a suggestion to avoid confusion for people who are not familiar with the icons and their meanings.
12 years 11 months ago #41134 by BigJohnT
Replied by BigJohnT on topic Gmoccapy - A new screen for linuxcnc
You can translate the button label with gettext and extract all translatable strings with intltool.
JT
12 years 11 months ago #41135 by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
Hallo,
a good idea, but very difficult to realize. I got the tool tips, witch will apera if you stay with the mouse ofer a widget. I am just updating that feature, to apply to all widgets. This text are translatable and I will offer the translations for German ans Spanish, hoping to get the Serbian files translated. B)
There is also a possibility to display buttons with Icon and Text, but that will need more space. I might introduce with the industrial version an option to change between Text and Icon Display. It's a quite a lot of work, but if the user can convince me that it is necessary, I will do that.
Or we introduce ICON calles
etc.
I check for the locale and load the ICONS by its country code, so you can add an text to any ICON.
Norbert
12 years 11 months ago #41137 by DaOne
etc.
That makes it easy to code just requires an image set for every language. Probably the best way to handle it however.
12 years 11 months ago #41147 by probamo
Replied by probamo on topic Gmoccapy - A new screen for linuxcnc
Norbert,
last time I sent you updated translation for Serbian. I checked *.po file and found 404 lines, among which all translated requested by gmoccapy at the time. Can you please advise which translation is missing so I can update it.
Thanks,
12 years 11 months ago #41148 by probamo
This is what I got
Any advice. It happened after I did 'git pull'.
Thanks,
Moderators: newbynobi, HansU
Time to create page: 0.187 seconds
