- Thank you received: 394
- newbynobi
12 years 10 months ago #41341
by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
Hallo,
I just updated the WIKI page.
There are now new and actual images and the complete part of the settings page has been reworked, and adapted to the new style.
And I do not stop, asking for help:
- Add Usage information to the WIKI, the button X does Y etc.
- Translation of the WIKI page
- Add own information to the WIKI page
- And the most needed, write a AsciiDoc for gmoccapy, to be included in master as a manual, AsciiDoc is not complicated, yust take a look at AsciiDoc
All this is work, that has to be done and will retain my from introducing new features and going on with the gcode generator.
Norbert
Norbert
- newbynobi
12 years 10 months ago - 12 years 10 months ago #41419
by newbynobi
gmoccapy 0.9.9.5
ver. 0.9.9.5
- added color chooser for homed and unhomed colors, as recommended
by BigJohnT to help people suffering from protanopia (red/green weakness)
- corrected an error updating the DRO colors in lathe mode
Norbert
ver. 0.9.9.5
Norbert
Last edit: 12 years 10 months ago by newbynobi. Reason: typos
- svenakela
12 years 10 months ago #41431
by svenakela
I was going to write to you about the colors and now it's already fixed. Good work!
Replied by svenakela on topic Gmoccapy - A new screen for linuxcnc
newbynobi wrote: gmoccapy 0.9.9.5
ver. 0.9.9.5
Norbert
- mariusl
12 years 10 months ago #41438
by mariusl
Regards
Marius
www.bluearccnc.com
Replied by mariusl on topic Gmoccapy - A new screen for linuxcnc
Hi Norbert
I am trying to move plasma to master but I am having problems running it. This is the error. Can you see what I am doing wrong or missing here?
LINUXCNC - 2.6.0~pre
Machine configuration directory is '/home/marius/dev/bluearc/configs/bluearc_plasma'
Machine configuration file is 'bluearc_plasma.ini'
Starting LinuxCNC...
io started
halcmd loadusr io started
task pid=32472
**** GSCREEN INFO: audio available!
**** GSCREEN INFO ini: /home/marius/dev/bluearc/configs/bluearc_plasma/bluearc_plasma.ini
**** GSCREEN INFO: Skin name = gmoccapy_plasma
('**** GSCREEN INFO: SKIN locale name =', '/home/marius/dev/bluearc/share/gscreen/skins/gmoccapy_plasma/locale', 'gmoccapy_plasma')
**** GSCREEN INFO: Using SKIN glade file from /home/marius/dev/bluearc/share/gscreen/skins/gmoccapy_plasma/gmoccapy_plasma.glade ****
/home/marius/dev/bluearc/bin/gscreen:445: GtkWarning: GtkSpinButton: setting an adjustment with non-zero page size is deprecated
self.xml.add_from_file(xmlname)
/home/marius/dev/bluearc/bin/gscreen:445: GtkWarning: gtk_widget_grab_default: assertion `gtk_widget_get_can_default (widget)' failed
**** GSCREEN INFO: using STOCK glade file from: /home/marius/dev/bluearc/share/linuxcnc/gscreen2.glade ****
**** GSCREEN INFO: handler file path: ['/home/marius/dev/bluearc/share/gscreen/skins/gmoccapy_plasma/gmoccapy_plasma_handler.py']
adding import dir /home/marius/dev/bluearc/share/gscreen/skins/gmoccapy_plasma
*** GMOCCAPY INFO: *** no additional python path found
Error trying to import notification
emcTaskInit: using builtin interpreter
Cleanup done
Regards
Marius
www.bluearccnc.com
- newbynobi
12 years 10 months ago - 12 years 10 months ago #41448
by newbynobi
Hallo Marius,
gmoccapy does not find notification.py.
It should be in linuxcnc-devel/share/gscreen/skins/gmoccapy/python
In your case it should be gmoccapy_plasma/python?!
Does it exist?
Norbert
@Sven,
Sorry for fixing the bug, before you asked
Does it exist?
Norbert
@Sven,
- mariusl
12 years 10 months ago - 12 years 10 months ago #41455
by mariusl
Regards
Marius
www.bluearccnc.com
Hi Norbert
It is there. I copied all the plasma related files and directories to the same places in the master repo that I am using. So it sits at ~/dev/bluearc/share/gscreen/skins/gmoccapy_plasma/python/
EDIT: Did I mention I am trying to run outside of sim?
Regards
Marius
www.bluearccnc.com
Last edit: 12 years 10 months ago by mariusl.
Moderators: newbynobi, HansU
Time to create page: 0.443 seconds
