- DaOne
- Thank you received: 6
21 Nov 2013 15:30 - 21 Nov 2013 15:34 #41077
by DaOne
Replied by DaOne on topic Gmoccapy - A new screen for linuxcnc
Norbert,
Great stuff!! I say release it as is for this version. Might as well since its already done and it gives people who know how to play with the screen the ability to leave the buttons if they want them. I love options. This is becoming a great screen! Keep up the good work! Can't wait till you put up the new release. Any time frame on the industrial version? Sounds more like the version I am after.
A quick question on editing. Is there any documented list of commands implemented in gscreen? I would like to add a couple of buttons myself but I cant find much on documentation.
Thanks,
Wes
Thanks,
Wes
Last edit: 21 Nov 2013 15:34 by DaOne.
- newbynobi
- Thank you received: 394
21 Nov 2013 20:28 #41080
by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
Halo Wes,
I will release the next with the buttons, so users have more time to play with that feature and decide some time later about keeping them or not.
I do like options too, that's why there are so many settings available to the user on the settings page, and I have some more in mind, but unfortunately all the options make more and more control structures in the code necessary, leading to very complicated code some times.
Unfortunately the internals off gscreen and also gmoccapy are not very well documented. I will not do this ether, because that would cost so much time, that all other stuff would suffer, but in my code there are a lot of comments and in most cases this do explain, why I do that in one or the other way. Feel free to check out the code.
If you would like to add own button, the best way is to do that with gladevcp panels. There is an excellent documentation for that:
GladeVCP
What buttons you need?
What functions you want to control?
Norbert
GladeVCP
Norbert
- newbynobi
21 Nov 2013 20:32 - 21 Nov 2013 20:32 #41081
by newbynobi
gmoccapy_0_9_9 - new DRO with new feature has been pushed
ver. 0.9.9
- introduced a new DRO, showing all three positions (Abs, Rel, DTG) at ones
user can toggle the DRO by clicking on them
- The new DRO also indicates the actual coordinate system
- The new DRO will change its units according to the active gcode (G20 / G21)
- There are still the three buttons, but they are hidden by default,
this can be changed on the settings page, but when the buttons are visible,
the user looses the auto units feature of the DRO
Hope too get the permission from the users to delete that button as soon as possible
- made the documentation for IconViewFileSelection
- made the documentation for Combi_DRO
- This change saved some lines of code in gmoccapy.py and made the code
a lot easier to understand
- updated German translation
- updated Spanish translation
Norbert
ver. 0.9.9
Norbert
Last edit: 21 Nov 2013 20:32 by newbynobi.
- Mike_Eitel
- Thank you received: 183
22 Nov 2013 01:08 #41083
by Mike_Eitel
Replied by Mike_Eitel on topic Gmoccapy - A new screen for linuxcnc
Norbert
That look is proffesional
Have not yet tried, but will sooner or later invest time into it.
Call it something like NgMMI gext generation Man Maschine Interface
MMI is very well known expression in industries.
Your work earns strong wording
Mike
Mike
- newbynobi
22 Nov 2013 03:53 #41088
by newbynobi
LUMI?
Linux
User
Machine
Interface
Or
LUMICNC
Norbert
Linux
User
Machine
Interface
Or
LUMICNC
Norbert
- BigJohnT
- Thank you received: 994
22 Nov 2013 04:27 #41089
by BigJohnT
Replied by BigJohnT on topic Gmoccapy - A new screen for linuxcnc
I get the error no module combi_dro when I try and run gmoccapy from the latest master pull.
JT
JT
- sliptonic
- Thank you received: 22
22 Nov 2013 04:49 #41090
by sliptonic
Or even "Luminous" with some variation of capitol letters.
lu·mi·nous (lm-ns)
adj.
1. Emitting light, especially emitting self-generated light.
2. Full of light; illuminated. See Synonyms at bright.
3.
a. Easily comprehended; clear: luminous prose.
b. Enlightened and intelligent; inspiring: luminous ideas.
Replied by sliptonic on topic Gmoccapy - A new screen for linuxcnc
LUMI?
Linux
User
Machine
Interface
Or
LUMICNC
Norbert
lu·mi·nous (lm-ns)
adj.
3.
- newbynobi
22 Nov 2013 06:05 #41093
by newbynobi
JT,
That should be solved, there was an error with the first push.
Please make a new pull, then it should work.
Norbert
Norbert
- BigJohnT
22 Nov 2013 06:57 #41098
by BigJohnT
Thanks Norbert, it comes up now.
I get a couple of errors about not being able to open a file <> when I start up.
Can you change the color of the DRO? Red is a bad color for people suffering from protanopia who are unable to perceive any ‘red’ light and this affects a substantial portion of the human population.
My first thought other than red displays is it is clean and neat. I'll have to copy my configuration to it and test it out some.
Why do you have the back plot and gremlin?
Thanks for all the work.
JT
JT
- BigJohnT
22 Nov 2013 07:06 #41100
by BigJohnT
How do you load a file?
JT
JT
Moderators: newbynobi, HansU
Time to create page: 0.602 seconds
