- mariusl
BigJohnT wrote: How do you load a file?
JT
The machine must be homed and ready, then you will see the load symbol under the auto/run mode.
Regards
Marius
www.bluearccnc.com
- newbynobi
- Thank you received: 394
I get a couple of errors about not being able to open a file <> when I start up.
Can you change the color of the DRO? Red is a bad color for people suffering from protanopia who are unable to perceive any ‘red’ light and this affects a substantial portion of the human population.
My first thought other than red displays is it is clean and neat. I'll have to copy my configuration to it and test it out some.
Why do you have the back plot and gremlin?
The errors of not beeing able to load I file are not normal.
Have you worked before with gscreen?, May be the preference files are mixed up.
Solution: Go to the settings page and select on File to load a valid File. After that the errors should be gone.
Colors of the DRO are changable on the settings page for Abs, Rel and DTG, I will include two more color button to allow the user select also the homed and unhomed colors. If you need an imidiate solution, please open linuxcnc-dev/lib/gladevcp/Combi_DRO.py and at the beginning change the default values of self.homed_color and self.unhomed_color.
Related to back plot and gremlin, is gremlin the back plot you refer to?
It offers the possibility to show you loading a programm, that you will be able to machine the part, because you get information of the limits. Also you are able to see that entering circles and leaving circles and so on are in the right direction. I am one of many, that do theire part coding by hand, so entering G2 instead of G3 is not unusual.
You are right, that gremlin also invoke problems. I.e. trieing to load a file with 500.000 lines of code will kill everey GUI with preview, the only one that can handle it at the moment is MINI, as it works with backplot and not preview. I found that out, while testing around with ShopfloorPro the Gcode generator Rene is writing . We tried to mill 3600 circular pockets in a circle frame and got 700.000 lines of code in less than 10 seconds, but we where not able to load such a file.
What more reasons you know, to delete gremlin from the GUI?
Loading a file is only possible with machine homed. Please enter the Auto Mode and press the load button, in the IconFileSelection select a file and then press the OK button. I havn't found out, why a dobble Click does not load the file.
And yes, you have to copy that to your config and you should not do only that, you should use it! And implement your Lathe Macros as glade panel to make the GUI even better as now
Norbert
- BigJohnT
- Thank you received: 994
JT
I did not see a button to home the machine, how do you home it?
JT
- mariusl
There is a row of buttons at the bottom of the screen. When you are in the run mode the most left hand button will give you the homing options. If you dont see them then your screen is not big enough. 1024 x 1024 is best for this screen.
Regards
Marius
www.bluearccnc.com
- probamo
New
Open
souRce
Board
to me NORB would be good for industral verson as well, but any other options would be grate as well. The point s the simpler the better.
- BigJohnT
mariusl wrote: JT
My monitor is a typical 15" ELO touch screen with 1024 x 768. I see it now but the symbol was not intuitive to me to indicate homing. Like they say once you know how it is easy...
JT
