12 years 10 months ago #41456 by mariusl
Replied by mariusl on topic Gmoccapy - A new screen for linuxcnc
Norbert
Look at the first error in the list
Starting LinuxCNC... io started halcmd loadusr io started task pid=4309 **** GSCREEN INFO: audio available! **** GSCREEN INFO ini: /home/marius/dev/bluearc/configs/bluearc_plasma/bluearc_plasma.ini **** GSCREEN INFO: Skin name = gmoccapy_plasma ('**** GSCREEN INFO: SKIN locale name =', '/home/marius/dev/bluearc/share/gscreen/skins/gmoccapy_plasma/locale', 'gmoccapy_plasma') **** GSCREEN INFO: Using SKIN glade file from /home/marius/dev/bluearc/share/gscreen/skins/gmoccapy_plasma/gmoccapy_plasma.glade **** USRMOT: ERROR: command timeout /home/marius/dev/bluearc/bin/gscreen:445: GtkWarning: GtkSpinButton: setting an adjustment with non-zero page size is deprecated self.xml.add_from_file(xmlname) /home/marius/dev/bluearc/bin/gscreen:445: GtkWarning: gtk_widget_grab_default: assertion `gtk_widget_get_can_default (widget)' failed self.xml.add_from_file(xmlname) **** GSCREEN INFO: using STOCK glade file from: /home/marius/dev/bluearc/share/linuxcnc/gscreen2.glade **** **** GSCREEN INFO: handler file path: ['/home/marius/dev/bluearc/share/gscreen/skins/gmoccapy_plasma/gmoccapy_plasma_handler.py'] adding import dir /home/marius/dev/bluearc/share/gscreen/skins/gmoccapy_plasma *** GMOCCAPY INFO: *** no additional python path found Error trying to import notification Shutting down and cleaning up LinuxCNC... USRMOT: ERROR: command timeout
it would seem that there is a problem loading the glade file.
here is the dir list of that file.
-rw-r--r-- 1 marius marius 123168 2013-10-16 09:21 gmoccapy_handler.pyc -rwxr-xr-x 1 marius marius 440910 2013-10-16 09:02 gmoccapy_plasma.glade -rwxr-xr-x 1 marius marius 146573 2013-10-16 11:54 gmoccapy_plasma_handler.py -rw-r--r-- 1 marius marius 126073 2013-10-16 11:55 gmoccapy_plasma_handler.pyc drwxr-xr-x 2 marius marius 4096 2013-10-21 22:08 icon drwxr-xr-x 5 marius marius 4096 2013-10-21 22:08 locale drwxr-xr-x 2 marius marius 4096 2013-10-21 22:08 python -rwxr-xr-x 1 marius marius 25988 2013-10-16 09:02 release_notes.txt marius@marius-desktop:~/dev/bluearc/share/gscreen/skins/gmoccapy_plasma$
Regards
Marius
www.bluearccnc.com
12 years 10 months ago #41457 by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
Hallo Marius,
yo are right, gscreen can not load the plasma glade file, even beeing in the correct place. Please delete the pyc files and send me the plasma files and the config folder, as I do expect the error in the config dir.
Norbert
12 years 10 months ago #41458 by mariusl
Norbert
I did delete the pyc but still the same. I attached the folder containing the plasma files under the share directory as well as my config. The config is not complete as I am trying to do the integration into the real environment still.
File Name: bluearc_plasma.tar.gz
File Size:16 KB
File Name: gmoccapy_p...a.tar.gz
File Size:310 KB
Regards
Marius
www.bluearccnc.com
12 years 10 months ago - 12 years 10 months ago #41459 by newbynobi
Hallo Marius,
you are using a handler file version 0.9.9 (see line 50 in gmoccapy_plasma_handler.py)
The actual one is 0.9.9.5, let me check if it does work also with the new version.
As we renamed the folder, the search path is not working correct, please edit
line 64 to be SKINPATH = os.path.join(BASE, "share","gscreen","skins","gmoccapy_plasma")
and report about the results.
Norbert
Last edit: 12 years 10 months ago by newbynobi.
12 years 10 months ago #41460 by mariusl
Norbert
That is alarming. I thought that I had the latest handler from you. How did I miss and update? It is not included on master as I just did a pull. I was under the impression that the plasma stuff is still what you sent me.
I just want to fix the include paths in the INI and then I will report back
Regards
Marius
www.bluearccnc.com
12 years 10 months ago #41466 by newbynobi
Marius,
no, I did not include the plasma stuff till now in master.
Please be a little bit pationed, I just made a short test on the latest master, and it seems to be easy to implement that stuff in gmoccapy standard, and then push it to master.
I will try to make some tests this evening and inform you.
Norbert
Moderators: newbynobi, HansU
Time to create page: 0.453 seconds
