- mariusl
12 years 10 months ago #41470
by mariusl
Regards
Marius
www.bluearccnc.com
Replied by mariusl on topic Gmoccapy - A new screen for linuxcnc
Thanks Norbert
Are you confirming then that I am missing some latest stuff? If so then I will wait until you are done. If not I will try to get it working by myself in the meantime.
Regards
Marius
www.bluearccnc.com
- newbynobi
- Thank you received: 394
12 years 10 months ago - 12 years 10 months ago #41480
by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
gmoccapy 0.9.9.6 - introduced plasma screen layout
ver. 0.9.9.6
- made a new config folder to show gmoccapy as plasma screen
- included some minor changes to be able to place user glade panels
over the coolant and spindle frame, hiding the original widgets
so plasma screen can easy be realized
This will hide also the spindle speed label in gcode info frame.
- the tool info frame can also be hidden by a user glade file, because tool
info is not needed for plasma.
- corrected an error in handling python calls in / for user glade screens,
as example introduced plasma.glade plasma.hal and plasma.py demonstrating
all possible communications
ver. 0.9.9.6
Last edit: 12 years 10 months ago by newbynobi.
The following user(s) said Thank You: Quadro
- mariusl
12 years 10 months ago #41482
by mariusl
Regards
Marius
www.bluearccnc.com
Wow looks great Norbert. I might want to talk to you about some of the labels or terms used. Not all of them are the usual plasma terms. It could be a last thing though once we get all the other stuff working.
Regards
Marius
www.bluearccnc.com
- mariusl
12 years 10 months ago #41484
by mariusl
Regards
Marius
www.bluearccnc.com
Norbert
It works great in sim. I will attempt to take it into a live config and let you know.
Please have a look at the Paramsaver component that we use in Axis to save the plasma / thc spinbox settings. Is there a way that we can save the settings we use in gmoccapy?
Regards
Marius
www.bluearccnc.com
12 years 10 months ago #41485
Pretty easy in GladeVCP, even I can do it.
linuxcnc.org/docs/html/gui/gladevcp.html...ariables_in_gladevcp
I notice that the g-code syntax highlighting is wrong, there is a better .lang file at www.cnc-club.ru
Replied by andypugh on topic Gmoccapy - A new screen for linuxcnc
mariusl wrote: Is there a way that we can save the settings we use in gmoccapy?
- mariusl
12 years 10 months ago #41486
by mariusl
Regards
Marius
www.bluearccnc.com
Norbert
I am not having much luck in the live config. I did a pull and compiled fresh. At this stage I am trying to load the screen without any hal files.
**** GSCREEN INFO: Preference file path: ~/.gmoccapy_preferences
USRMOT: ERROR: command timeout
/home/marius/dev/bluearc/bin/gscreen:1062: GtkWarning: Invalid icon size 48
self.widgets.window1.show()
toolfile: /home/marius/dev/bluearc/configs/bluearc_plasma/torches.tbl
WARNING:Config:Can't load Default loading default layout instead
Xlib.protocol.request.QueryExtension
/home/marius/dev/bluearc/bin/gladevcp:185: GtkWarning: GtkSpinButton: setting an adjustment with non-zero page size is deprecated
builder.add_from_file(xmlname)
gladevcp: trouble looking for handlers in 'plasma': PlasmaClass instance has no attribute 'connect_signals'
File "/home/marius/dev/bluearc/bin/gladevcp", line 122, in load_handlers
objlist = h(halcomp,builder,useropts)
File "./plasma.py", line 67, in get_handlers
return(PlasmaClass(halcomp,builder,useropts))
File "./plasma.py", line 55, in __init__
self.connect_signals()
AttributeError: PlasmaClass instance has no attribute 'connect_signals'
/home/marius/dev/bluearc/share/gscreen/skins/gmoccapy/gmoccapy_handler.py:689: Warning: value "0" of type `gint' is invalid or out of range for property `max-messages' of type `gint'
self.notification.set_property('max_messages', self.widgets.adj_max_messages.get_value())
timeout 100
**** GSCREEN INFO: postgui filename: gmoccapy_postgui.hal
HAL: ERROR: pin 'hal_manualtoolchange.change' not found
gmoccapy_postgui.hal:7: unlink failed
/home/marius/dev/bluearc/scripts/linuxcnc: line 396: 32566 Killed $EMCTASK -ini "$INIFILE"
Cleanup done
Regards
Marius
www.bluearccnc.com
Moderators: newbynobi, HansU
Time to create page: 0.322 seconds
