- Thank you received: 394
- newbynobi
12 years 10 months ago #41561
by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
Marius,
to upload a python file, just rename it from py to txt, it is not allowed to upload for security reasons.
Norbert
Norbert
- newbynobi
12 years 10 months ago #41562
by newbynobi
Hallo Marius,
I just saw, you did the signal connections in the glade file. That is normally no problem, and would work in most circumstances, but this is a very special case, as the GUI will be re parented as embedded window, so the connections will not go through. OK, that is not the exact trues, they do not come through, because the are in the plasma class, and we do need that class, to get the widgets to python code. And that is needed to save later on the states on exit.
Like Michael told me long time ago, you get this way a longer rope to hang up yourself
And please, take names for the widgets that do tell the meaning of the widget, button2 will not be as easy as btn_THC_speed_minus.
Norbert
Norbert
- newbynobi
12 years 10 months ago - 12 years 10 months ago #41563
by newbynobi
Hallo Marius,
here is the modified plasma glade file.
I did not change the button to hal button and I do not know why you are using hal boxes.
Norbert
Please rename the file to plasma.glade
Norbert
Last edit: 12 years 10 months ago by newbynobi.
- mariusl
12 years 10 months ago #41564
by mariusl
Regards
Marius
www.bluearccnc.com
Replied by mariusl on topic Gmoccapy - A new screen for linuxcnc
Hi Norbert
I have not named anything correctly just yet. I am just trying to get the hang of things. I will name the stuff according to your standard.
The buttons must just increase and decrease the value of the hal label
It still fits as I will remove the first frame once I have renamed the objects correctly.
This looks like a lot of trouble for someone like me who know zip about python. But I will try.
Thanks for helping, I do appreciate it very much.
Regards
Marius
www.bluearccnc.com
- mariusl
12 years 10 months ago #41565
by mariusl
Regards
Marius
www.bluearccnc.com
OK I can see the button event. HeHe.
Regards
Marius
www.bluearccnc.com
- newbynobi
12 years 10 months ago #41567
by newbynobi
Hallo Marius,
You want to increase a hal label?
That is not possible!
A hal label is an in pin, so it can only indicate a given hal pin value.
If I try to follow you, you want the buttons to change a hal value. It is easier to connect hal buttons to a hal component that increase a hal value and just display that value in the hal label.
Doing this in python is posible, but for a beginner not easy.
If you explain what functions the buttons should control, I will try to implement them.
Norbert, getting slowly crasy, because remap code for tool measurement seems to destroy my work.
Moderators: newbynobi, HansU
Time to create page: 0.178 seconds
