12 years 10 months ago #41572 by mariusl
Replied by mariusl on topic Gmoccapy - A new screen for linuxcnc
Hi Norbert
I discovered in my sleep last night that I cannot change a hal label.
What I am trying to do is to replace the spin buttons as they do not work well on a touch screen. Some of these settings has to be changed quickly while the machine is running and the spin button is too small to get to by hand.
So I am trying to replace all the spin button settings to use a up/down button set to change the value. All the settings can be done this way except the "Switch Travel", that can go to the INI file as it is a static setting only used at the calibration of the machine. It can come off the screen.
I am busy with an example of what I think it should be like. I will send it when I am done. I do agree with doing all the calculations and settings in a component. That way it will be easier to manage the storage of the variables. Well at least for me as I know C++ better.
Regards
Marius
www.bluearccnc.com
12 years 10 months ago #41575 by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
Hallo Marius,
OK I do understand your point of view!
So please just make the layout, without any functins or code,
I will then fix all thinks together, including the save stuff.
Is it OK to have the increments in the INI file?
Push button + once will increase value by increment from INI file.
Norbert
12 years 10 months ago #41577 by mariusl
Hi Norbert
Yes the INI file is a good way to go for all the stuff.
I will send the glade file a bit later.
Regards
Marius
www.bluearccnc.com
12 years 10 months ago #41579 by mariusl
Norbert
I dont know if I got all the button and label type correct, but here goes.
Tell me what more I can do please.
File Name: plasma_new.glade
File Size:31 KB
Regards
Marius
www.bluearccnc.com
12 years 10 months ago #41582 by andypugh
Replied by andypugh on topic Gmoccapy - A new screen for linuxcnc
mariusl wrote: What I am trying to do is to replace the spin buttons as they do not work well on a touch screen.
The "Touchy" LinuxCNC interface requires a jog-wheel, and to change any parameter you select the parameter on the touch screen, then operate the wheel to select the value.
Also, Touchy doesn't begin any motion until you press a physical "run" button.
I very much support both these design decisions.
12 years 10 months ago #41584 by mariusl
I agree with you. My machines always has a run / pause / stop button on. A MPG for plasma is not really suitable as jogging to a rough position is mostly used.
Lot of people dont even fit homing switches to plasma machines. I personally dont build a machine without homing and limit switches.
The main reason for using the button approach on a plasma machine is because one is required to make adjustments while the machine is working. This means that you dont have the luxury of mistakes. The setting that is mostly used is the Set Voltage for the THC and the THC speed.
There are two approaches when it comes to THC. One is the Gcode contains the code to probe the material height and do corrections using G92 and the rest. The other is using a component to do the THC setup and corrections.
The pro and cons are:
Gcode option:
Pro: The config is very simple as all is done in gcode.
Cons: Due to the G92 and offsets used, one cannot recover or use "cut from here" when the arc fails.
Component option:
Pro: Very simple gcode with just M3 is used and the rest is done by component.
Con: Not so easy to setup from scratch. ( Until we have a new component to fix this)
I will support the external start button option if you wish to go that way.
Regards
Marius
www.bluearccnc.com
Moderators: newbynobi, HansU
Time to create page: 0.172 seconds
