12 years 10 months ago #41498 by mariusl
Replied by mariusl on topic Gmoccapy - A new screen for linuxcnc
Norbert
I got the screen to load and do most things but I have a problem with the jogging.
I can jog X and Y axis no problem but as soon as I jog the Z axis I get the errors in the screen shot. I reset the estop and machine and then I cannot jog any axis. The error is as shown. The error is for Z axis although I jog the X axis.
I have the NO_FORCE_HOMING switch ON at the moment so the machine is not homed.
Regards
Marius
www.bluearccnc.com
12 years 10 months ago #41501 by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
Hallo Marius,
most of the warnings you mentioned, are normal, I will spend some time to check how to avoid them, but not all come out of my computer;-)
The actual error of your config is the following error in Z axis, the following error do unhome the axis, what is not allowed and so on.
Please find the reason for the following error.
Norbert
12 years 10 months ago #41502 by mariusl
Norbert
I am using the axis settings that you supplied in the example config. Have a look at the attached file.
Why will the Z axis give an error when I jog the X axis?
File Name: bluearc_plasma.ini
File Size:6 KB
Regards
Marius
www.bluearccnc.com
12 years 10 months ago #41504 by newbynobi
Marius,
are you on your real machien, or on sim?
I understood, that sim is working fine, as it does here.
If you are on a live machine, you do have to set your hal files and make the axis settings according to your machine!
At least I can see, that you did include a new hal file and you did not adapted the paths of subroutines and macros.
Norbert
12 years 10 months ago #41509 by mariusl
Norbert
It is running on live machine now. The problem with Z was the THC comp was not connected so there was no feedback :(
It looks great. I will let you know how it goes.
Thanks again for your support.
Regards
Marius
www.bluearccnc.com
12 years 10 months ago - 12 years 10 months ago #41513 by newbynobi
Hallo Marius,
fine that it is running.
Related to the labels, you may just edit the glade files to modify them, and send the changed ones so I can push them to master.
Or just inform about the changes you like.
Norbert
Last edit: 12 years 10 months ago by newbynobi.
Moderators: newbynobi, HansU
Time to create page: 0.262 seconds
