- mariusl
12 years 10 months ago #41488
by mariusl
@Andy, don't be so modest old chap. I did remember looking at that at some stage. If Norbert don't include it I will attempt to do it but I think it should be part of the screen when you use variables that change with machine behaviour.
Regards
Marius
www.bluearccnc.com
Replied by mariusl on topic Gmoccapy - A new screen for linuxcnc
Pretty easy in GladeVCP, even I can do it.
linuxcnc.org/docs/html/gui/gladevcp.html...ariables_in_gladevcp
Regards
Marius
www.bluearccnc.com
- newbynobi
- Thank you received: 394
12 years 10 months ago #41489
by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
Oh !
My fault!
Please delete line 55 frommer plasma.py
self.connect_signals()
I forgot to delete that one, I will correct that tomorow.
Bet your parfon.
Norbert
My fault!
Bet your parfon.
Norbert
- newbynobi
12 years 10 months ago #41490
by newbynobi
@andipugh
I do not speak rushan, can you please search the lang file and post it here?
Thanks Norbert
Thanks Norbert
12 years 10 months ago #41491
Replied by andypugh on topic Gmoccapy - A new screen for linuxcnc
[quote="newbynobi" post=41490I do not speak rushan, can you please search the lang file and post it here?[/quote]
cnc-club.ru/forum/viewtopic.php?f=33&t=80&p=27169
- mariusl
12 years 10 months ago #41496
by mariusl
Regards
Marius
www.bluearccnc.com
Hi Norbert
It is getting better. Still these errors.
USRMOT: ERROR: command timeout
/home/marius/dev/bluearc/bin/gscreen:1062: GtkWarning: Invalid icon size 48
self.widgets.window1.show()
///////// I deleted some lines here
toolfile: /home/marius/dev/bluearc/configs/bluearc_plasma/torches.tbl
/home/marius/dev/bluearc/bin/gladevcp:185: GtkWarning: GtkSpinButton: setting an adjustment with non-zero page size is deprecated
builder.add_from_file(xmlname)
Xlib.protocol.request.QueryExtension
gladevcp: trouble looking for handlers in 'plasma': iteration over non-sequence
File "/home/marius/dev/bluearc/bin/gladevcp", line 129, in load_handlers
for object in objlist:
TypeError: iteration over non-sequence
WARNING:Config:Can't load Default loading default layout instead
/home/marius/dev/bluearc/share/gscreen/skins/gmoccapy/gmoccapy_handler.py:689: Warning: value "0" of type `gint' is invalid or out of range for property `max-messages' of type `gint'
self.notification.set_property('max_messages', self.widgets.adj_max_messages.get_value())
timeout 100
**** GSCREEN INFO: postgui filename: gmoccapy_postgui.hal
tool change False False 0
/usr/lib/python2.6/dist-packages/Onboard/KeyGtk.py:43: PangoWarning: pango_font_description_set_size: assertion `size >= 0' failed
font_description.set_size(self.font_size)
estopping / killing gscreen
/home/marius/dev/bluearc/scripts/linuxcnc: line 396: 827 Killed $EMCTASK -ini "$INIFILE"
Cleanup done
Regards
Marius
www.bluearccnc.com
- newbynobi
12 years 10 months ago #41497
by newbynobi
gmoccapy_0_9_9_6_1 - bugfix in plasma.py
ver. 0.9.9.6.1
- solved a bug in plasma.py, having a call without function
Norbert
ver. 0.9.9.6.1
Norbert
Moderators: newbynobi, HansU
Time to create page: 0.162 seconds
