13 years 5 months ago #33887 by jlviloria
Replied by jlviloria on topic Gmoccapy - A new screen for linuxcnc
Norbert.
When compensated in X I assume the radius not the diameter.
This enabled the G8, entered the table, pressed Key touchoff digit tool X and the diameter of the workpiece. but places it on the radio.
I hope you understand me.
thanks for your great effort.
Jorge
13 years 5 months ago #33899 by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
Halo Jorge,
the command executed by the button is
G10 L10 P3 X2.356
The X value given is the value you entered and it will be the X value.
If you are in G7 Mode the value you enter is the diameter, else it is the radius.
So IMHO it is working like it should.
Norbert
13 years 5 months ago #34564 by mariusl
Replied by mariusl on topic Gmoccapy - A new screen for linuxcnc
This really looks very good. I tried to use the size options on the settings / tools page but it would seem to be ignored. I have a 1024 x 768 display but the bottom of the screen is never visible so I tried to resize the screen to fit. As I said, it seems to be ignored.
Regards
Marius
www.bluearccnc.com
13 years 5 months ago #34601 by newbynobi
Halo Marius,
I see the problem!
At the moment the smalest size is 979 x 782 Pixel and in hight you got only 768, that is why the bottom is cut off.
I will see if I can reduce the hight to 768. It is fix coded at the moment, so that the GUI will not be to small to show all widgets.
Please give me some time, to see what I can do.
Norbert
13 years 5 months ago #34604 by jlviloria
Marius'm using gmoccapy and is pretty good, though Norbert is improving it much more ... look had your same problem ...
The solution I found was gmoccapy.glade open the file, choose 'windows1, and look in "Commons", and there you will appear "height request" and choose 650,
and ready you will see only good in fullscreen
Jorge Viloria
13 years 5 months ago #34607 by mariusl
newbynobi wrote: Halo Marius,
I see the problem!
Norbert
Hi Norbert,
I think that most common screens these days are set to 1024 x 768. There are other resolutions but most of them seem to use the 768 size. The screens that are more square normally will provide 1024 x 1024 or better. It makes no sense at all.
Regards
Marius
www.bluearccnc.com
Moderators: newbynobi, HansU
Time to create page: 0.615 seconds
