13 years 5 months ago #34608 by mariusl
Replied by mariusl on topic Gmoccapy - A new screen for linuxcnc
jlviloria wrote: Marius'm using gmoccapy and is pretty good, though Norbert is improving it much more ... look had your same problem ...
The solution I found was gmoccapy.glade open the file, choose 'windows1, and look in "Commons", and there you will appear "height request" and choose 650,
and ready you will see only good in fullscreen
Jorge Viloria
Jorge,
I am waiting for my touch screen to arrive and then I will set it to that screen size. Thanks for the info though.
Regards
Marius
www.bluearccnc.com
13 years 5 months ago #34644 by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
Hallo Jorge,
I do think, you must change some lines in gmoccapy_handler too, because strating the screen will set the screen size to default.
Do you use realy the latest version?
I will change the default size on this weekend, I do hope to get time!
Norbert
13 years 5 months ago - 13 years 5 months ago #34646 by jlviloria
Replied by jlviloria on topic Gmoccapy - A new screen for linuxcnc
Norbert,
I had the same problem of Marius, when he felt fullscreen, did not open completely.
I did that and it worked perfect. i'm using Gmoccapy 0.9.3, I is working perfect, with some changes as you noticed.
1) change the position of the tool table.
2) remove the macros
3) change the starting position of the button home_all
4) add keyboard functions with the Control key. (F3 home) (F9 = manual) (F10 = mdi) (F11 = auto) (F12 = tooltable) (Ctrl_R = run) ("Escape" = stop program) etc.
5) Change the run-from-line (the copy of GScreen of Cmorley) for my need.
6) Add some buttons for my machine, jog turret, turret home, cycle time and local time.
Hi marius,
Not as fancy, but functional.
Please, How do you add NGCGUI?
Thanks for all your help.
Jorge Viloria
Last edit: 13 years 5 months ago by jlviloria.
13 years 5 months ago - 13 years 5 months ago #34647 by mariusl
Jorge
I dont see your picture. Did you attach it correctly? I would like to see what you did.
Regards
Marius
www.bluearccnc.com
Last edit: 13 years 5 months ago by mariusl.
13 years 5 months ago #34657 by cmorley
Replied by cmorley on topic Gmoccapy - A new screen for linuxcnc
[quote="jlviloria" post=34646
Jorge Viloria[/quote]
NGCGUI is not embeddable nor does it use GTK widgets, which means it can not be 'embedded' into Gmoccapy or Gscreen.
There was some work done on a GTK styled NGCGUI but I'm not sure what is going on with it.
I emailed the author about some issues but never got anything back.
Chris M
13 years 5 months ago #34662 by mariusl
Chris,
Will we have a way to do NGCGUI type stuff with Gscreen or gmoccapy? Thinks like wizards or code to do repetitive tasks like circular bolt patterns and the like. You know, all the nice things for a mill or lathe.
Regards
Marius
www.bluearccnc.com
Moderators: newbynobi, HansU
Time to create page: 0.671 seconds
