12 years 7 months ago - 12 years 7 months ago #44305 by cmorley
Replied by cmorley on topic Gmoccapy - A new screen for linuxcnc
newbynobi wrote: gmoccapy 1.0 !!
I made it, gmoccapy reached stable state!
The main difference from previous versions is that gmoccapy is now stand alone, completely separated from gscreen.
This has two main reasons:
1. gmoccapy has become so complex, that it is not any more a typical gscreen skin, it is an own application.
2. I got a speed advantage because I do not need as much timers as before.
But take care!
Due to the change, all hal pin has changed their names from gscreen. to gmoccapy. and also the tooloffset pin changed their names.
I did update the WIKI according to the changes, so please read it!
I hope to get now a more easy product for support, because there will be less influence from other code parts and I can put more effort in new features.
I would like to express, that this decision has nothing to do with gscreen and its very good code and features and that this decision is completely conform to Chris opinion. Chris I thank you for gscreen and I will also in the feature have an eye on that, because without gscreen I would never have begone to code gmoccapy.
THANKS CHRIS!
Hope you will support me also in feature!
Norbert
Congrats to you Norbert for Gmoccapy 1.0 - alot of hard work you have put in.
I have enjoyed our work together - you have made Gscreen better and given more choices to the people.
Thanks for the shout out - I am happy I could help you.
Gmoccapy is an excellent screen. - Another step up for linuxcnc.
I am happy you are another official developer of linuxcnc too
Of course I will support you in the future.
Feel free to send idea/opinion my way - we don't have to always agree but ideas thrown about helps create better products.
Chris M
Last edit: 12 years 7 months ago by cmorley.
12 years 7 months ago - 12 years 7 months ago #44311 by hobride
Replied by hobride on topic Gmoccapy - A new screen for linuxcnc
Hello all,
i have installed the last update from buildbot today.
after that i have trouble with gmoccapy screen.
My ini file contained:
DISPLAY = gscreen -c gmoccapy -d
this worked for me until the last update.
now, after the update linuxcnc starts with the gscreen and does not show me the gmoccapy screen.
also:
DISPLAY = gmoccapy
does not works for me:
Print file information: RUN_IN_PLACE=no LINUXCNC_DIR= LINUXCNC_BIN_DIR=/usr/bin LINUXCNC_TCL_DIR=/usr/lib/tcltk/linuxcnc LINUXCNC_SCRIPT_DIR= LINUXCNC_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/linuxcnc LINUXCNC_CONFIG_DIR= LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs INIVAR=inivar HALCMD=halcmd LINUXCNC_EMCSH=/usr/bin/wish8.5 LINUXCNC - 2.6.0-pre0-5251-g1fda8e6 Machine configuration directory is '/home/cnc/linuxcnc/configs/lcf1' Machine configuration file is 'lcf1.ini' INIFILE=/home/cnc/linuxcnc/configs/lcf1/lcf1.ini PARAMETER_FILE=linuxcnc.var TASK=milltask HALUI=halui DISPLAY=gmoccapy Starting LinuxCNC... Starting LinuxCNC server program: linuxcncsvr Loading Real Time OS, RTAPI, and HAL_LIB modules Starting LinuxCNC IO program: io io started halcmd loadusr io started Starting HAL User Interface program: halui Starting TASK program: milltask task pid=7252 Starting DISPLAY program: gmoccapy Can't execute DISPLAY program gmoccapy Shutting down and cleaning up LinuxCNC... emcTaskInit: using builtin interpreter Killing task linuxcncsvr, PID=7198 Killing task milltask, PID=7252 Removing HAL_LIB, RTAPI, and Real Time OS modules Removing NML shared memory segments Cleanup done Debug file information: 7198 PID TTY STAT TIME COMMAND 7252 PID TTY STAT TIME COMMAND Stopping realtime threads Unloading hal components Kernel message information: [ 2001.034423] I-pipe: Domain RTAI registered. [ 2001.034429] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03. [ 2001.034431] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) . [ 2001.034474] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0). [ 2001.034476] PIPELINE layers: [ 2001.034478] fbb76e20 9ac15d93 RTAI 200 [ 2001.034480] c085cb20 0 Linux 100 [ 2001.050152] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>. [ 2001.050290] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes. [ 2001.050294] RTAI[sched]: hard timer type/freq = APIC/12500368(Hz); default timing: periodic; linear timed lists. [ 2001.050297] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2700162000 hz. [ 2001.050299] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns. [ 2001.050369] RTAI[usi]: enabled. [ 2001.080465] RTAI[math]: loaded. [ 2001.141751] config string '0xE800 out ' [ 2003.541097] RTAI[math]: unloaded. [ 2003.562558] SCHED releases registered named ALIEN RTGLBH [ 2003.592207] RTAI[malloc]: unloaded. [ 2003.692016] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0). [ 2003.694054] I-pipe: Domain RTAI unregistered. [ 2003.694105] RTAI[hal]: unmounted.
Last edit: 12 years 7 months ago by hobride.
12 years 7 months ago #44312 by mariusl
Replied by mariusl on topic Gmoccapy - A new screen for linuxcnc
The entry for the display should read
DISPLAY = gmoccapy
just change the current line by deleting the gscreen and the -d stuff. Also have a look at the Wiki page for more instructions
If that does not work make sure that you have run ./autogen.sh and ./configure from the /src directory before you do the make..
Regards
Marius
www.bluearccnc.com
12 years 7 months ago - 12 years 7 months ago #44317 by hobride
until now I've never compiled linuxcnc or gmoccapy self.
is that now necessary?
12 years 7 months ago #44318 by mariusl
Yes of coarse it is required. There is s lot of files that is being moved or deleted and the complete make proses will sort out all that for you automatically. Also if you do not compile you will not have the latest binaries in the correct places.
Do This every time:
git pull
cd /src
./autogen.sh
./configure
make
sudo make setuid
Regards
Marius
www.bluearccnc.com
12 years 7 months ago #44319 by hobride
ok thanks,
i will try this
Moderators: newbynobi, HansU
Time to create page: 3.394 seconds
