12 years 7 months ago - 12 years 7 months ago #44351 by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
Halo verser,
thanks for contributing,
could you please explain a bit more in detail?
I downloaded the files, but it is very cumbersome to search for the differences in the files.
As far as I see, you modify the complete glade file, why?
Please take a look at gmoccapy_plasma, as all the changes there are related with emmbedded-tabs, a custom handler file and a custom hal. If you follow that way, your changes will not be lost after every update!
I see you are using 0.9.9.9.16, be aware, if you update now you will get 1.0.4 and most of your changes will to be redone, as the file locations has changed.
You will find gmoccapy.glade and gmoccapy.py at /src/user_intf/gmoccapy, if you modify one of the files you will have to do a make after the modification!
Norbert
Last edit: 12 years 7 months ago by newbynobi.
12 years 7 months ago - 12 years 7 months ago #44356 by newbynobi
How about being able to open a gcode file with double click? I know it might actually get in the way of users using touchscreens, so an option to set double click behavior would be welcome. Without a touchscreen having to first highlight the requested file with the mouse and then confirming with a button on the other side of the screen isn't very comfortable.
Halo RafaƂ,
done, pushed today the changes to iconview.py.
Rest is still to be checked, but on my to do list ;-)
Norbert
Last edit: 12 years 7 months ago by newbynobi. Reason: typo
12 years 7 months ago #44357 by verser
Replied by verser on topic Gmoccapy - A new screen for linuxcnc
Helo Norbert,
I just like the interface of gmoccapy and quickly insert it necessary for me to function and
understood that I would lose the ability to update.
Now I will use your recommendation and look carefully gmoccapy_plasma and try to make right my additions in version 1.+
and write some readme.txt
12 years 7 months ago #44358 by newbynobi
If you need any support, just ask! I am very interested in the Z-Axis compensation, because I also like to mill PCB and know well about the leveling problem!
May be we can add that option as a separate INI config like we did with plasma.
Norbert
12 years 7 months ago #44359 by verser
..and yet - Gmoccapy is very very beautiful work, thank you very much Norbert and all those who are involved in the development.
12 years 7 months ago #44362 by verser
Ok, I got acquainted with a gmoccapy_plasma , it is clear all, soon make addition Z-Axis compensation as a separate INI config as EMBED_TAB_LOCATION = box_coolant_and_spindle
Moderators: newbynobi, HansU
Time to create page: 1.013 seconds
