- mariusl
12 years 7 months ago #44466
by mariusl
Regards
Marius
www.bluearccnc.com
Replied by mariusl on topic Gmoccapy - A new screen for linuxcnc
Norbert
Please be patient with the panel :blush: I am having several problems with the manufacture. The bezel is a problem and some cash flow to bring a larger quantity of displays in from the east. Some small problems with internal cables as well. I will not forget your panel and the first production unit has your name on already.
Have a look at the screenshot in the tool information area. Some strange numbers.
Regards
Marius
www.bluearccnc.com
- newbynobi
- Thank you received: 394
12 years 7 months ago #44467
by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
Hallo Marius,
I have never seen such numbers on my PC !
May be it is one of your bit-coins, trying to escape
Can you reproduce that behavior? I guess it is more a problem on your computer.
Norbert
Norbert
- verser
- Thank you received: 69
12 years 7 months ago - 12 years 7 months ago #44468
by verser
Replied by verser on topic Gmoccapy - A new screen for linuxcnc
This problem occurs when in .ini file erase important lines or assigned too large values
Last edit: 12 years 7 months ago by verser.
- verser
12 years 7 months ago - 12 years 7 months ago #44469
by verser
For example here, these
or
# Highest value that will be allowed for feed override, 1.0 = 100%
MAX_FEED_OVERRIDE = 1
MAX_SPINDLE_OVERRIDE = 1.2
MIN_SPINDLE_OVERRIDE = 0.25
# Max and default jog speeds in units per second
MAX_LINEAR_VELOCITY = 18
DEFAULT_LINEAR_VELOCITY = 18
MAX_ANGULAR_VELOCITY = 18
- mariusl
12 years 7 months ago #44478
by mariusl
Hi Norbert
It is always there. I shut down the terminal and restarted linuxcnc and the number is there. It seems to be the same number all the time. Something generated from within the Glade maybe?
Regards
Marius
www.bluearccnc.com
newbynobi wrote: Hallo Marius,
Norbert
Hi Norbert
Regards
Marius
www.bluearccnc.com
- hobride
12 years 7 months ago #44479
by hobride
Replied by hobride on topic Gmoccapy - A new screen for linuxcnc
Off topic!
is that a bottle of vodka?
verser wrote: No, verser is nickname.
I promote your interface in Russian forum
cnc-club.ru/forum/viewtopic.php?f=15&t=4575&p=110957#p110957
Moderators: newbynobi, HansU
Time to create page: 0.781 seconds
